Closed Thread
Old 10th August 2006, 14:11   #196
navin's Avatar
Thanked: 4,286 Times
Car doors dont have a lot of volume. Every driver has a optimal volume in which it operates best. I would think that in small doors a 6.5" woofer might even be better than a 8" (depending on T/S characteristics).
navin is offline
Old 10th August 2006, 16:18   #197
Bass&Trouble's Avatar
Thanked: 71 Times
You're right about a 6.5" woofer (read as midrange/midbass) being more comfortable, but even a 8" midbass/ midrange operating over 80 Hz would have no problem. The advantage would be it's ability to handle more power in the 80-250 Hz range compared to any 6.5". There is however not much sense in having this in the rear door.
But I think, considering the small volumes that ID subs are generally comfortable with, the ID8 should do well in a car door as a sub. But you'll have to throw in ****loads of damping.
I lust at the idea of having a setup in a big car where I could probably have 2 ID8s (I don't know any brand that makes a better budget 8" subwoofer) in a clamshell isobaric enclosure (to make the enclosure volume even smaller than what those pups take) in the front, right where most cars would have a console, and a nice 3-way (8" midbass + 4"/3"/2" cone or dome midrange + 1" DT) in the doors. That would be quite a setup. I had tried this a long time back, but the results were distasteful since I didn't have the right sub drivers, and good damping.
I also wish that most cars were developed with a rear engine so that I could pop subs in the trunk upfront, but then I was always known as the King Of Wishful Thinking.
Bass&Trouble is offline
Old 10th August 2006, 17:20   #198
Thanked: 294 Times
the king of upfront bass.......
or this can be considered also in the dash......
low_bass_makker is offline
Old 10th August 2006, 17:22   #199
Thanked: 21 Times
Originally Posted by Bass&Trouble
I could probably have 2 ID8s (I don't know any brand that makes a better budget 8" subwoofer).....
....but then I was always known as the King Of Wishful Thinking.
Yeah B&T, thats like THE dream setup... and would you know, I'm known as the King of Wishful Thinking around these parts...
gunbir is offline
Old 20th August 2006, 22:08   #200
Thanked: 294 Times
yaar KB just finishing the setup , but the iridiums position changed and they running very nice......will give a detail report about them soon....here are some pic.......
this aluminum cover was just installed today evening as I get time on sunday only.... hope this cover looks nice (plz comment), alpine logo is going to be put on the top surface.....
now the wire dressing part has yet to be done and the power distribution block is going to be removed from this place as it is not looking nice....
rest the major thing is yet not done DAMPING.....till now not a single step taken in that direction except this......
seen it in the market will be helpful to damp the door panel only what say guy will it work for the door panel........
Old 20th August 2006, 22:20   #201
kb100's Avatar
What are those YELLOW wires?... What cables are you using?... And what is the squarish aluminium lookiing metal thingy under the aluminium plate?...
kb100 is offline
Old 20th August 2006, 22:48   #202
Thanked: 21 Times
If you mean the one on the left, thats the Alpine H701 processor.
gunbir is offline
Old 21st August 2006, 00:42   #203
Thanked: 294 Times
hope this helps.....
Old 21st August 2006, 00:46   #204
Thanked: 294 Times
the yellow wire are the 4 mmsq or 12 gauge industrial wire will be changing to some good stuff
all the speaker wire is of AR (acoustic research) 16 gauge....rest power cable of audison and the rca is also DIY with good rca plugs and co-axial wire......there will be major change in the whole car wiring soon.......
Old 21st August 2006, 00:49   #205
Sam Kapasi's Avatar
Thanked: 1,473 Times
Where did you get AR cabling from my brother?
Sam Kapasi is offline
Old 21st August 2006, 00:58   #206
Thanked: 294 Times
delhi gk showroom where we meet it is home audio cable but the outer is quite thick.....and at sharp points extra care has been taken to prevent damage....
Old 21st August 2006, 01:01   #207
Sam Kapasi's Avatar
Thats what I thought....
It is good speaker wire you know. Well done.
Old 21st August 2006, 01:19   #208
Thanked: 11 Times
Hey LBM,
What Is The Use Of Alpine H701 Processor ??
Cheers,
Mugen_Power.
Mugen_Power is offline
Old 21st August 2006, 10:56   #209
Thanked: 294 Times
It is a very powerful multimedia manager capable of doing wonder in car if tune properly tho........here is the web link of the same......http://www.team-bhp.com/forum/car-en...-pxa-h701.html (Alpine PXA-H701)
Old 11th September 2006, 12:53   #210
jkdas's Avatar
Thanked: 1,436 Times
Originally Posted by sk456
Hi guys... I finaly got my Upgrade on my set up.. got a awesoem 3 way install with HErtz 3 ways on the front soundstage...
It was an terrific install by Gunbir..JB and DRIVEN.... took abt 5-6 hrs but the result was a sweet sweet soundstage.... I especially liked the clean Mids and tight mid bass ..which are perfect for the strong vocals/rock I normally hear.... I actaully mute the rears nowadays ( have Infinity reference 6x9 ) in the rears...... the frotn soundstage gives me everythg I need......
The pics are already there on the thread posted by JKD...
http://www.team-bhp.com/forum/249233-post77.html
was it just cut and fix? I mean no spacers needed?
jkdas is offline
Closed Thread
My DIY Beetle Restoration Saga 71Convertible Post-War 100 5th December 2016 21:24
My Used Cars Saga ramzsys Long-Term Ownership Reviews 34 8th July 2010 20:08
Milk Spill Woes- a tragic saga ascertain Shifting gears 43 3rd May 2009 11:10
Saga Of Palio 1.6 Breakdown eclectix 1st Long-Term Ownership Reviews 151 27th May 2008 11:36
