Closed Thread
Old 4th April 2007, 13:12   #376
navin's Avatar
Thanked: 4,266 Times
The fiberglass should be on the inside. wanring it is dirty work so wear gloves. better still keep an extra pair of gloves handy.
navin is offline
Old 4th April 2007, 13:23   #377
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by low_bass_makker View Post
hmmm....B&T sir where are you we need your expert advice on this........and I am going to use nails that is final as I would not be opening up the box in the later use......
about sealing resin bonded fiberglass would be a good option.....
No nails, only good screws. When tightened, the screw causes the wood to stress and the threads of a wood screw ensure that there is no scope for any movement of the wood surfaces when they are under pressure. Nails are tacky (pun not intended). Dont listen to Navin lol, you'll see nails on the surfaces, but you'll never know whats underneath. Screwing is a must, in all its interpretations.
Silicon is a good sealant although I rarely use it. Now I'm starting to sound like a carpenter, nevertheless, I make sure that the MDF is precisely cut so that there is no need for too much sealant. Some suspect areas can be sealed with a mixture of fine wood shavings and fevicol.
What is not mentioned is bracing. One brace could be the partition to divide your enclosure's volume into half since you will be having two subs. Besides that also, use 2" by 1" wood bars to join the two largest opposite wall surfaces of the enclosure to one another.
Bass&Trouble is offline
Old 4th April 2007, 14:32   #378
navin's Avatar
Hey B&T I did say I used screws, and yes that is a very good point you made about nails; LBM use screws too. The Fiberlgass is not only a good sealant but makes the cabinet stiffer too and although messy to apply does not add much weight to the cabinet. I used 2 layers (1.5mm each). Be happy I did not recommed concrete, B&T isn't that what your friend used?
Bracing. Well there is bracing and there IS bracing. The best form would resmeble the cabinet made famous by B&W a few years ago (they called it the Matrix). You can never be too thin, too rich, or have too much bracing.
LBM if you are really thinking about a god sub box, think non parallel surfaces, braced and damped. The box should be stiff (so it does not flex), light (so it stores as little energy as possible), and acoustically dead.
What type of panel joint are you thinking of? Dovetail? Dowel?
navin is offline
Old 4th April 2007, 14:42   #379
Thanked: 21 Times
You can never be too thin...
Tell that to Karen Carpenter...
gunbir is offline
Old 4th April 2007, 16:13   #380
Thanked: 294 Times
this is my enclousre size...I will be going for two separate enclosure like the last time...so no long planes of the wall will be there.....
low_bass_makker is offline
Old 4th April 2007, 17:23   #381
Thanked: 294 Times
Phaji who is this karen carpenter??????
Old 4th April 2007, 18:06   #382
Thanked: 21 Times
Arrey any carpenter that believes in karen is sharon, is Karen Carpenter
gunbir is offline
Old 4th April 2007, 18:39   #383
Sam Kapasi's Avatar
Thanked: 1,473 Times
I agree with B&T, the best way to nail this, is to screw it. Screwing will make the box firm and tight.
Sam Kapasi is offline
Old 4th April 2007, 19:21   #384
tsk1979's Avatar
Thanked: 16,015 Times
So you screw all your boxen? How often?
tsk1979 is offline
Old 4th April 2007, 22:38   #385
Thanked: 71 Times
Yes, we screw all our boxen. Not often, only once, when we make the boxen.
Let us know if you want to also, we can send you one in a flat pack and you could get going. Screwing is daunting business for the inexperienced, please wear adequate protection, or we can have Sam send you a manual.
Old 4th April 2007, 22:48   #386
tsk1979's Avatar
Ok are the end results different if boxen screwing is done without protection. Can you release a demonstration video on Youtube, Paper manuals are so passe, a virtual manual would be good with video, with and without protection
tsk1979 is offline
Old 5th April 2007, 00:37   #387
Thanked: 294 Times
Hmm a lots of graphic and virtual fantasy world are being created here.....
Ok guys now lets get to the real stuff....not screw and ba11s....ok will be posting the pictures of the enclosure in the half make conditons tomm....
Old 5th April 2007, 12:58   #388
navin's Avatar
Karen and her ilk had a mental disease. Anorexia is more mental than physical. And if you want instructions from Sam it wont be a manual it'll be bible.
navin is offline
Old 7th April 2007, 00:19   #389
Thanked: 294 Times
but the Sam Bhai has gone to KL for holidays lets us hope for his nice trip and safe return to the forum......
Old 7th April 2007, 00:23   #390
Thanked: 294 Times
ok guys here is the review of the beast STEG K-Series K2/04 amplifier....well it is good to hear that I have made a good decision to buy these amps....ok then here is the review...
Closed Thread
My DIY Beetle Restoration Saga 71Convertible Post-War 100 5th December 2016 21:24
My Used Cars Saga ramzsys Long-Term Ownership Reviews 34 8th July 2010 20:08
Milk Spill Woes- a tragic saga ascertain Shifting gears 43 3rd May 2009 11:10
Saga Of Palio 1.6 Breakdown eclectix 1st Long-Term Ownership Reviews 151 27th May 2008 11:36
