Closed Thread
Old 8th November 2007, 13:32   #886
Thanked: 294 Times
Hmm since sub arrival will take some time here is a update on the mid bass remounting done.
Earlier the midbass was below the door panel mounted like this..
but I wanted to mount it from above the door panel as some sound was playing inside the door panel. So I mounted a ring on the earlier spacer to fill the gap between the door panel and the door frame.
the door panel was cut and damped more...
and here is the final result
The midrange and the tweeter mounting are still pending as the frame is yet to be made but will be done soon.
The mounting was done with help of my friend Harpreet (Bullet guy at the meet)
low_bass_makker is offline
Old 8th November 2007, 18:15   #887
Bass&Trouble's Avatar
Thanked: 71 Times
Thumbs up
Holy Moley!
That looks very good to me. Almost the best way to fasten a midbass to a Swift door. I am sure there's a tremendous improvement.
One question - did you ascertain that there is no leakage where the mdf and 'what looks like Aluminium' ring make contact with each other?
One more question, do you have a pic of the part where ET steps out?
Bass&Trouble is offline
Old 8th November 2007, 18:22   #888
Thanked: 13 Times
Nice work bhaiya, the midbass must be fitting snug. Also like the way the ring/grill is finished.
So at this stage how much damping has gone in?
s0uljah is offline
Old 8th November 2007, 18:53   #889
hydrashok's Avatar
Looks good, l_b_m. I'd seen an identical install in a Swift (with 3-ways, that I'd mentioned earlier someplace).
The spacer-extension-method was used there also for th mid-bass (but it was all-MDF spacer). Now if only the lazy-@$$ owner of that Swift would post pics!
hydrashok is offline
Old 8th November 2007, 20:44   #890
iraghava's Avatar
Thanked: 156 Times
Now that lazy-a$$ owner wouldn't just happen to have a beard bigger than LBM's, would he??
iraghava is offline
Old 8th November 2007, 23:06   #891
amit_sound's Avatar
LBM what subs have u ordered?
amit_sound is offline
Old 8th November 2007, 23:37   #892
Thanked: 294 Times
Originally Posted by Bass&Trouble View Post
Holy Moley!
ya there is nearly 20-30 % in the midbass output.
no there is no leakage as double tape was applied between them
Hmm next time I will surely take.
Old 8th November 2007, 23:40   #893
Thanked: 294 Times
Approx 20 sq feet in each door.
I would love to see that. May be I might learn something from it.
Old 8th November 2007, 23:42   #894
Thanked: 294 Times
Very soon my friend ..
Old 8th November 2007, 23:59   #895
amit_sound's Avatar
hmm....aachi baat hai...tadpa ley, aur tadpa ley.
So still a month for you to speak up haan..
Kaash main police main hota.....toh tere ko uuthva kay, interrogation kar kay uugalva leta
Chalo anyways, Best of luck....Atleast tell ki u getting SPL or SQL this time?
Old 9th November 2007, 00:05   #896
Thanked: 294 Times
thank you sir....This time SQL again as I can go loud and clear at the same time.
Old 9th November 2007, 00:38   #897
Gill's Avatar
Thanked: 12 Times
HI LBM,
Nice work on the door pannel,would love to know how you changed the grille of swift door pannel,and why you used steel spacer that too on woden ring,did u wanted to increase the weight for speaker mounting so that the midbass gets solid base!!
Tell you something 99% of people on this plannet demonstrate and rest does experiments,you are in 1% category!!
Cheers!
Happy diwali to all,Safety is must esp for childern!
Gill is offline
Old 9th November 2007, 00:39   #898
iraghava's Avatar
Thanked: 156 Times
Says the man who himself is keeping his new setup a secret!!
Amit - If you were in Delhi, we would have already picked you up & tortured you over some Alcohol & Kukkad & by now gotten to know what you're getting for your car
iraghava is offline
Old 9th November 2007, 00:40   #899
iraghava's Avatar
Thanked: 156 Times
P.S. LBM - If I'm not mistaken that's a milled Aluminium spacer, right?
iraghava is offline
Old 9th November 2007, 01:14   #900
amit_sound's Avatar
hmm...iraghava, yes i am upgrading....
But i will start discussing it in another thread. This one is for LBM.
bol LBM bol..... hehehe
Closed Thread
My DIY Beetle Restoration Saga 71Convertible Post-War 100 5th December 2016 21:24
My Used Cars Saga ramzsys Long-Term Ownership Reviews 34 8th July 2010 20:08
Milk Spill Woes- a tragic saga ascertain Shifting gears 43 3rd May 2009 11:10
Saga Of Palio 1.6 Breakdown eclectix 1st Long-Term Ownership Reviews 151 27th May 2008 11:36
