Closed Thread
Old 14th December 2007, 11:24   #1201
Thanked: 294 Times
Originally Posted by moralfibre View Post
Sir, any reason for placing the sub facing the hatch lid? I saw two videos on you tube where its placed facing the roof:
Nice sub in the right hands sir. Have fun with it.
In some time a new placement will be seen. That also which is never used here till now. But it will take some time.
Originally Posted by Sam Kapasi View Post
Sir that line was patented by me. And never was there a truer example. Well done LBM!
After all, LBM is the mascot of the ICE section.
Thanks Sam Bhai.
I'd put a rubber gasket between the wood and steel ring. and lock the nuts with loctite.
Yes Sir. I would be doing this when I am finishing the box. As the carpet is still pending till now.
low_bass_makker is offline
Old 14th December 2007, 11:27   #1202
Thanked: 294 Times
Hydra, when a car is bursting at the seems (not seams) it will be producing a lot of Rattle and Hum (no matter what the damping is). It wont be music.
LBM, I'd seriosuly condier a MDF/FRP/Marine Ply composite box. Atleast for the baffle. If it was me I'd have used a FRP/Carbon fiber composite.
Sir right now I am giving the sub 2400 watts and till that stage 1 inch MDF is good enough. But when more power will be given to this monster I will surely think of some thing stiff.
a ha! so when you want to open the trunk you turn the sub on and it blows the hatch open right?
Not tried till now but my driver door is doing the same thing.
Old 14th December 2007, 11:28   #1203
Thanked: 294 Times
Originally Posted by amit_sound View Post
Sorry for the late reply LBM bahi....my net was down..
Well congrats on getting that Monster..
You have installed the plutonium in the swift....what about the hydrogen ones? Where are you installing them?
Whats the next amp for this monster? I know we have to start guessing again
The hydrogen are for my friend, He is putting them in his Viva. Will surely post the pics of the same.
Old 14th December 2007, 11:47   #1204
Thanked: 21 Times
And now your fantasies are revealed
gunbir is offline
Old 14th December 2007, 13:56   #1205
DerAlte's Avatar
Thanked: 2,879 Times
Does it require its own power station, or just a 1000A alternator will do?
He could buy the old 100MW unit from Badarpur TPS, mount it on a trailer and hitch it to his car. Or even the older 60MW units from Faridabad or Indraprastha.
I think LBM has joined the Greens and is trying to make an Air-powered car, saving the world from noxious HC emissions. Play a symphony in the city for low speed driving, hip-hop on the highway for high-speed driving.
Reminds me of that Cement ad with the stunned truck driver: imagine LBM-bhai stranded somewhere holding the steering wheel, everything else from the car, other than the sub-box, having parted company sometime before.
LBM-pra-ji, twadda jawaab nahin! Keep it up - the world is waiting! 170dB now?
DerAlte is offline
Old 14th December 2007, 14:06   #1206
Bass&Trouble's Avatar
Thanked: 71 Times
I have just reported your post to the mods.
They shouldn't allow someone to be so funny. Uhhhh, my stomach is aching.
Bass&Trouble is offline
Old 14th December 2007, 14:39   #1207
clipto333's Avatar
let me remind you your patented line. its "well done oh crazy sikh" lol.
clipto333 is offline
Old 14th December 2007, 15:09   #1208
clipto333's Avatar
lbm,
considering swift's charging system, do you think your amp can give out 2400w rms? can the alt and the battery keep up with the current demand of the amp?
Old 14th December 2007, 15:32   #1209
Originally Posted by clipto333 View Post
lbm,
Hey Clip, i think i can answer this one -
The STEG is rated at 2400RMS at 11.x volts not at 14.4volts like other amps and LBM plays loud only with the engine running. he also has a voltmeter installed so he can monitor the voltage at all time....
saintsinner is offline
Old 14th December 2007, 15:47   #1210
Ajaybiz's Avatar
Thanked: 148 Times
Does it require starter also to switch on the System same as some big electric motors seen in factories or near by "Aata Chakki" shops .
Ajaybiz is offline
Old 14th December 2007, 15:47   #1211
tsk1979's Avatar
Thanked: 16,422 Times
Swift has a 60A alternator(I think). Lets say this is 60A at 14.4V which means the max power which the alternator can dump out is 14.4*60 = 864W
Even with engine running, its going to seriously overload the system.
tsk1979 is offline
Old 14th December 2007, 16:16   #1212
clipto333's Avatar
i dont know if he has changed the meter but the one i saw wasn't accurate. :-)
yes he does keep tab of the voltage using a dmm. and playing that amp with the engine off he will need to jump start the car everytime. i don't play my pio 944 with engine off even at low vol.
i think your equation is wrong. let me find the equation navin posted earlier.
Old 14th December 2007, 16:58   #1213
Thanked: 294 Times
the meter is accurate but is has some error in the reading which is .3 volts. If it is showing 14.6 then real reading is 14.3 so it serves the purpose very well.
About the steg giving out 2400 watts, Like I said I play for short durations the battery supply the juice like in the case of a starter If I keep cranking any car for 15 mins the battery will drain out. also alternator has no job to play in that case. It had been that I am playing the setup for longer durations like half hour or even 15 mins the battery would die out and then I would need a High output alternator.
Old 15th December 2007, 01:54   #1214
clipto333's Avatar
oh yes lbm. i remember you told me when we met in palam vihar about the minor error. sorry.
why don't you upgrade your charging system lbm? considering the amount of money you have spent on the audio system, a high output alternator is not a big expense IMHO. you won't be restricted to a 5 minute rear seat torture. you can torture a person as long as you want or till the person vibrates to death. lol.
what spl figure are you aiming for lbm? 160+ db? or 170?
Old 15th December 2007, 10:23   #1215
navin's Avatar
Thanked: 4,286 Times
at 150+db 5 min can seem like eternity, why, it might be "for all eternity".
navin is offline
Closed Thread
My DIY Beetle Restoration Saga 71Convertible Post-War 100 5th December 2016 21:24
My Used Cars Saga ramzsys Long-Term Ownership Reviews 34 8th July 2010 20:08
Milk Spill Woes- a tragic saga ascertain Shifting gears 43 3rd May 2009 11:10
Saga Of Palio 1.6 Breakdown eclectix 1st Long-Term Ownership Reviews 151 27th May 2008 11:36
