Old 28th May 2006, 15:25   #1
harmon_bro's Avatar
Default 10" Vs 12" Subs
Hi all,
What difference does it make having a 10" or a 12" sub in a car. Now for instance, I hook up a Lancer with two 12" subs and another Lancer with two 10" subs, will it make any difference bewteen these 2 cars?
- Vikram
harmon_bro is offline   Reply With Quote
Old 28th May 2006, 15:43   #2
aZa
aZa's Avatar
Thanked: 17 Times
Its just not size of the woofer, its the quality and size of enclosure, quality and power of the amp, wiring and the car a hatch or sedan or suv.
Old 28th May 2006, 16:00   #3
Thanked: 294 Times
aza has given a complete ans with a nearly 7 variables..............
Old 28th May 2006, 16:24   #4
harmon_bro's Avatar
Iam looking at fixing 2 subs for the Lancer, yet to decide on a Alpine or a JBL. Please suggest the amp that would match for the respective subs rated by you. Finally, the size that I should go for....
- Vikram
Old 28th May 2006, 16:44   #5
Thanked: 294 Times
Man first tell us the model number of the sub after that we can decide about every thing else...............
Old 28th May 2006, 16:56   #6
harmon_bro's Avatar
Alpine 10" - SWR-1022D
JBL 10" - W10GTie
Alpine 12" - SWR-1222D
JBL 12" - P-1220e
Old 28th May 2006, 17:16   #7
Thanked: 294 Times
http://caraudiosecurity.com/shop/pro...s_id/3892.html -> SWR-1022D
http://www.autosound.no/JBL/Subwoofere/w10gtie.htm -> W10GTie
http://caraudiosecurity.com/shop/pro...s_id/3890.html ->SWR-1222D
http://caraudiosecurity.com/shop/pro...s_id/2042.html ->P-1220e
The model u have chosse is a complete mixture of diff variety...
First if u are going to compare some thing u must have some similarites in between the alpine ur selected are 2ohms and the jbl 10 inch are 4 ohms dvc and the 12 jbl is a svc. Man first select what config of vc do u need
1) 4 ohms dvc
2) 2 ohms dvc
3) 4 ohms svc
Because this will effect the chossing of the amp. because if u selected a two pcs 2 ohms dvc then it can be wired to a single amp at 2 ohms but if u take 4 ohms dvc sub then the juice of the amp could not be taken out because u cannot wire two 4 ohms dvc sub to a single amp with 2 ohms setup so u will be needing 2 amps......
I think u have gettin my point. Also the 10 inch jbl is the a very heavy sub as compared to ur 12 inch jbl . so please select the nearest which u get......
Old 28th May 2006, 18:56   #8
Bass&Trouble's Avatar
Thanked: 71 Times
Partly right, partly wrong. Like LBM says.. too many variables. Assume all external factors are to remain constant, the performance of the subs would depend on which 10" you are pitting against which 12". Even if the 10 and 12 in consideration are from the same series of the same brand, it is quite possible that the subs may be greatly different in performance. On the other hand, on several occassions, manufacturers make 10s and 12 from the same series with identical motors and voice coil size. Hence only the diaphragm is larger and the basket. In this case, the power handling is the same, only you get higher sensitivity because of a higher radiating surface area and hence more bass for the same amount of power input. Two subs from different lines or brands would be radically different in the way they perform, the enclosure requirements etc.
If generalized, 10s should be more popular with someone who doesn't want extremely low bass (a 10 would have to travel more than a larger sub to produce lower frequencies at the same spl, and hence need more amplification power to get this going in a small enclosure). This does not mean that there are no 10s that can do 20Hz from a small sealed enclosure, but just that they'd need greater power to do it as loud as a comparable 12, 15 or 18.
Old 28th May 2006, 19:29   #9
harmon_bro's Avatar
Thanks Bass&Trouble, its very nice of you to highlight some sensible information up front.
Thanks again.
- vikram
Old 29th May 2006, 11:55   #10
Sam Kapasi's Avatar
Thanked: 1,473 Times
I agree.
And Do not understand why you have selected a 10" from the GTi series and the 12" from the power series. They are 2 entirely diffferent subs. GTi are competition series subwoofers.
8" and 10" subs available in the market? Invinsible In-Car Entertainment 19 25th November 2009 23:53
2 Subs - Dual Mono or Stereo - "Kb ka dB" kb100 In-Car Entertainment 847 1st October 2007 07:52
Please Review Soomoku Subs & Speakers SoundManiac In-Car Entertainment 68 19th June 2007 21:03
12" Subs for Sale blueraven316 Shifting gears 20 7th February 2007 16:49
