Old 19th December 2008, 08:18   #1741
sudhirbhan's Avatar
Thanked: 9 Times
Originally Posted by vrrraju View Post
I think at that price you can get a higher end HU from Pioneer. Since you are planning for an AMP then you will have to consider for good cabling both for the RCA interconnects as well the Amp power kit. You will have to budget even for that.
Thanks so much for your detailed response Raju. Any idea what model of Pioneer HU I can expect to buy for approx 6500? I am looking for one with USB compatibility. Also pointers on the amount to be budgeted for RCA interconnects and amp power kit would be really appreciated.
Bangalore guys, any suggestions regarding a reliable dealer in Bangalore from whom I can source the Pio HU and JBL amp (60.4) / speakers (608C and 637/8) at a reasonable price. I am planning to source the hardware from Bangalore and getting it installed in Mangalore.
sudhirbhan is offline   Reply With Quote
Old 19th December 2008, 09:59   #1742
DjNik's Avatar
You Can get the Pioneer 3050 at about 6K
I would reccomend dont go in for the 608c try and increase your budget a bit and go for the EL 6.1,Youll love them.
You cn get the scosche 8ga amp kit at about 2.5k and interconnects @700.
DjNik is offline   Reply With Quote
Old 19th December 2008, 14:59   #1743
sudhirbhan's Avatar
Thanked: 9 Times
Thanks DjNik. By how much would I need to stretch my budget for the EL6.1 -> these are illusion audio speakers, right?
Old 28th December 2008, 01:38   #1744
Fountainheader's Avatar
I've booked a Swift Zxi today and the sales guy tells me that the HU cannot be removed since its integrated with the steering.. Guess the make is Kenwood. Never heard since no showrooms have Zxis on display :(
But I am looking at disposing off for a better 2-din one. Any idea how much I can expect for the same ?
Fountainheader is offline   Reply With Quote
Old 28th December 2008, 13:11   #1745
Can anyone please help me here. I have the option of getting a 2-din HU from the US. If only this Zxi OEM one can be easily removed.
Also how about the stock speakers on the Zxi ? Do they need an upgrade. I dont plan to buy a Sub since I need boot space.
Old 28th December 2008, 18:25   #1746
Epic's Avatar
Thanked: 424 Times
Default Bass Tube Cone Fallen Off!!
Hi Guys,
I have a very wierd problem. I am using the Infinity 12" Ref 1200T Bass Tube in my Swift and i all of a sudden found an 80% drop in bass and punch. I inspected the connections to the tube and the tube itself and noticed throught he mesh grill that the cone had fallen inwards. The cone is not torn or damaged in any way and the tube still gives bass but i do not understand how this has happened. I will be having the tube inspected by an expert to know if it can be repaired of do i have to buy a new one. What do you guys think?
Epic
Epic is offline   Reply With Quote
Old 28th December 2008, 21:33   #1747
navin's Avatar
Thanked: 4,282 Times
1. take this up with your installer.
2. if your installer is not cooperative PM Sam Kapasi as his represents Infinity in India.
Old 15th January 2009, 17:51   #1748
username's Avatar
Hi Gurus,
I will be getting my Swift VDi delivered in early March... I am looking to get a music system. I dont have any idea on what all to look for... Can someone help me in this?
Thanks in advance.
username is offline   Reply With Quote
Old 16th January 2009, 10:24   #1749
navin's Avatar
Originally Posted by username View Post
Hi Gurus,
The swift has stock locations for 4 speakers (one in each door) in it's doors. These locations are quite good. If you find you need more bass think about adding a 12" or even 2 8-10" subs in the trunk.
Obviously your budget, taste in music, and use of system will determine which components and accessories you get.
Old 16th January 2009, 10:30   #1750
Hi Navin,
I have a Zxi and I dont plan to replace the HU as of now. I'm looking at a 2-din from the US later this year. But I do plan to upgrade the stock speakers.
I'm the only one using this car, and most of the times, the only occupant too. My music taste is more into rock - Metallica, Maiden, Floyd, G&R etc. I dont really need the thump and dhing-jhing stuff. So no subs and amps.
I am more keen on comps for the front and co-ax for the rear. I have a budget of around 12-15k which includes damping/installation too. Any recommendations for the same boss ?
Old 16th January 2009, 11:28   #1751
navin's Avatar
Hi Navin,
I'd reserve 6K for the damping and install and 9K for the speakers for which you can get a great set of 2 components and 2 coax from the likes of JBL, Blaupunkt , Illusion, Bull, etc.. JBL and Blaupunkt are available at a wide variety of dealers. For reviews on Illusion and Bull search this forum.
Before you choose the components howevr I'd suggest you find a GOOD installer. I'm begining to fear that while ICE install is NOT rocket science GOOD installers are not as common as I previously believed.
Old 16th January 2009, 11:50   #1752
True. I've never heard any reviews on good installers in Chennai. Hence planning to travel to B'lore to Evo for the install.
9K would be with b/w ? How about the Alpine Type-R speakers ? Getting a great deal on Amazon currently. But US products would provide no international warranty I guess.
Old 16th January 2009, 13:19   #1753
tush's Avatar
I have a somewhat similar taste but i also listen what sounds good to my ears even if its POP, HIP HOP, classical or instrumental music. I am not sure if i would go for amp and subs, but i want to keep those options open in case for future if i decide. As far as i know illusion should be good for such music from what i learnt from different forums. I have not yet figured out which HU would be best for this music taste. My requirement is USB, custom equilizer settings and yes i would try and make it a point to listen to ACD as they are the purest source for music as far as i know.
I am no expert but navin and other audio experts in this forum can guide us.
tush is offline   Reply With Quote
Old 16th January 2009, 18:32   #1754
Thanked: 28 Times
Hi all BHP Audio experts,
I got KDC.BT7539U Kenwood head fron Gulf.Now I am searching for speakers.
Following are my specs:
1)Light music and not interested in big BASS.
2) Swift VDI
3) Not interested in plank,just planning to install on existing speaker slots of front and rear door.
4)Where can I get good installer for Kenwood in Bangalore?
5)Budget is not more than 5 to 6K.
6)No amplifier needed.
Please give me the make(Speaker), which suits my head unit and dimensions and available good dealer location .Here is the Head unit details.
Kenwood - KDC-BT7539U
balechaparka is offline   Reply With Quote
Old 18th January 2009, 19:13   #1755
Epic's Avatar
Thanked: 424 Times
Hi Guys,
Epic
Hi guys,
Ive had the tube inspected and the subwoofer seemed to have displaced from its mounting. I found it very very wierd because firstly the casing for the tube is made of card board or some material similar to it. Secondly the subwoofer was'nt screwed in place but i believe was stuck instead. Ive been using this tube for almost 2 and a half years now and i guess in time it had become loose and fallen inside the tube. I am shocked with the quality of building this bass tube and that too from a reputed name like Infinity. Are all bass tubes made like this and with similar material?
Anyway, i was advised to scrap the tube and use the subwoofer in a box instead. Is this ok or is this subwoofer meant to be installed in a tube only? Also my tube was ported but my box is not. Will this make any difference in sound quality? Very frankly, i did'nt find any difference in the sound quality but we did have to make a few adjustments on the monoblock amp to get more punch as the setting usd on the tube did'nt seem to suit the same sub in a box. What does this mean? Ive also been told that a non-ported box gives more punch. Kindly advise on the same
Epic
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
