Old 16th August 2009, 22:37   #1906
navin's Avatar
Thanked: 4,284 Times
Originally Posted by Epic View Post
Rear 6X9s : Illusion, Ground Zero OR DLS (Still have to decide) - Suggestions are welcome.
Monoblock Amp : JBL 301.1 (Driving the sub)
dont know which DLS model you are looking at but between the Illusion and GZ for the rear I'd take the GZ. Also if you can afford it get the GTO3501 instead of the CS 301.1
Old 16th August 2009, 22:47   #1907
DjNik's Avatar
A 3501 wont do any good to him as he will have to run the sub at 4 ohms as the 3501 is not a 1 ohm stable amp.This would just get him a output of 225wrms, which is cerainly low for a 500 rms sub.
DjNik is offline   Reply With Quote
Old 17th August 2009, 10:05   #1908
navin's Avatar
1 ohm stable amps (a la Steg, Brax, etc..) are not cheap. Either that or he gets a woofer that has 2 x 4ohm coils to get 2 ohms.
Old 17th August 2009, 10:51   #1909
DjNik's Avatar
Certainly 1ohm amps are not easy to find, Epic you should have a look at Kenwood 9104D which gives 500wrms at 4 ohms and would be suitable for you.Should cost you about 15k.
Old 17th August 2009, 11:26   #1910
Ajaybiz's Avatar
Thanked: 141 Times
Try getting a 10" Infinity sub REF1052 or REF1062 these subs can be wired to 8 or 2 ohms and RMS is also according to your 301.1 amp around 250 and 275 W RMS.
Many other brands are available in US online sites.
Ajaybiz is offline   Reply With Quote
Old 17th August 2009, 16:49   #1911
Epic's Avatar
Thanked: 424 Times
To tell you the truth guys, I had no intention of changing either of my amplifiers but all your suggestions state otherwise. I am totally confused now and back to square one :-(
Epic is offline   Reply With Quote
Old 17th August 2009, 23:09   #1912
Bass&Trouble's Avatar
Thanked: 71 Times
From Epic's description to me of the sound he expects, my impression is that he wants something clean and crisp - not SPL. I plan to run the 301.1 amp in 4 ohm mode, getting 204 W rms as opposed to the 2ohm output of 290 odd.
Old 18th August 2009, 10:37   #1913
navin's Avatar
the 3501 might not put out more power but I believe it has better damping factor and current delivery. woofers are very inductive loads...but B&T you know all that ...
Old 18th August 2009, 13:50   #1914
Epic's Avatar
Thanked: 424 Times
Well. I think B&T had hit the nail on the head! Thank God atleast one member, i.e. ME; has come to a final conclusion on the setup required instead of increasing confusion which is usually the case :-) hahahaha.....
Thanks B&T :-)
Old 18th August 2009, 17:59   #1915
Flying Bong's Avatar
Headunit : Alpine 9887 (Prefer a Pioneer so still have to decide) - Suggestions are welcome.
I've owned both the 9887 and the Pio P880 and prefer the Pio. It's a matter of personal taste of course... it would be a good idea to audition both units before deciding.
Flying Bong is offline   Reply With Quote
Old 18th August 2009, 18:55   #1916
Thanked: 294 Times
+1 vote for the Pioneer P80 HU.
Old 18th August 2009, 20:50   #1917
Epic's Avatar
Thanked: 424 Times
But my friends, is the Pioneer P880 still available in Mumbai? Ive heard it is very hard to find a second hand let alone a brand new P880 today. If anyone knows where i can purchase a brand new P880, please let me know.
Old 18th August 2009, 22:43   #1918
karankapoor's Avatar
Epic, P880 is the older model the new model is p800 or you can search for p80rs or p80rsII (new model). contact Bass&treble maybe he can help you to find one in mumbai
karankapoor is offline   Reply With Quote
Old 19th August 2009, 13:31   #1919
Thanked: 63 Times
Guys, Need a little help from you.
I need to get the setup done for my swift.
Before the details, I need to inform you that my wife knows play back singing. What I meant was she's been through the musical classes and hence can make out all the nitty gritties of music and sound. So for her sake atlast, I need a simple setup.
I shall add amp and sub later.
Budget: As of now figured out to be INR 12000
Requirements: HU with Bluetooth facility to pick up calls from my handset. I receive calls on the go and hence this basic requirement.
Speakers : As of now, planning for Bull Audio. Front at stock locations, Rear 6 * 9 on MDF Panel
Damping : Needs to be done
Wiring harness.
I leave the floor to you to guide me in the right direction for these requirements
I am a mechie and hence have no idea about electronics/electiricyt which I cannot see :-}
Note: Possibility exists for increasing the budget if my wifey requirements can be met.
Love to hear from you
lambuhere1 is offline   Reply With Quote
Old 19th August 2009, 15:07   #1920
tush's Avatar
Originally Posted by tush View Post
Hi Abhinav and Gurus I have uped my budget by 5k, so now i have total 25k to spend excluding HU. Might not mind few grands give and take.
I just went for some information about the above ICE in market. Came to know that JBL 1004 is discontinued and no longer available. For Blau "Modern Car" says that the company is closed(band ho gayi company aab blau nahi milta). Is that true?
I went through the Specs from the website for Blau and catlog for JBL. I didnt understand which one would be more good. As the price difference between the two is significant.
JBL 1004e
100W*4 - 4 ohms
150W*4 - 2 ohms
Blau GTA4 Special MKII
Max. Power 4 Channel @4 Ohm (Watt): 4x120
Max. Power 2 Channel @4 Ohm (Watt): 2x400
Max. Power 4 Channel @2 Ohm (Watt): 4x180
RMS Power 4 Channel @4 Ohm (Watt): 4x60
RMS Power 2 Channel @4 Ohm (Watt): 2x180
I was recommended the following AMPS by another ICE shop
Infinity Reference - 475
Harmon Kardon - 470
Ground Zero MK4
Rockford Fosgate Amp P15412
Vibe P450.4
Blau P450.4
Yes I will try out some other dealer.
Abhinav the rates you have mentioned are MRP for Illusion and GZ 30T it seems. I got the following approximate quotes with B&W
Illusion EL 6.1 = 5500
GZ 30T = 6000 - 7990. Here the ice shop person said he is not sure about the exact rates as this is just launched model and not available with him. So he gave the higher Band just in case which is MRP.
JBL 1004 - Though not available he said it would be around 13k
Seems I am not getting the correct market prevailing rates as he wanted me to finalize there and there to give me the exact quote. Cannot accept stuff at MRP.
Dynamite Damping for front 2 doors - 2500
JBL AMP wiring kit - 2000
Illusion component speakers wire - 1000
Rates apart first need to look for some more ICE shops for options.
BTW when I told that my HU has TA and will he be able to set it he was not clear in answering this question. I feel ICE shops here in Pune are just sales minded people and hardly technical. Dont mind going mumbai if thats the case then.
Wake up Pune you are still laging behind Mumbai
FYI - Just went through JBL India website and dont see JBL 1004 amp listed there.
Originally Posted by abhinav.gupta88 View Post
The 2nd option is better.
Is it 20k for Comps + Amp + Sub or 20k for Amp + SUb
20k for Comps + Amp + Sub would mean 13k for Amp + Sub if you choose the Illusions.
I'd say go for the GZ 30T to complement it - 8k and a Blaupunkt GT4MKII with it. - 5k.
1000-2000 more in wiring + install. So that would make it around 21-22. IMO , you'll love it.
20k for Amp + Sub could fetch you a JBL 1004 and a GZ 30T. This would be a much better imo. JBL if taken in grey would cost around 9 and the sub as mentioned would cost 8k. So you'll be left with 3k for install + wiring. You could get a bit damping if budget allows you or add that later ( which you'll have to assuming your car is the one in your avatar.)
I'll advise you to go in for the JBL + Illusion + GZ combo. It will sound totally rocking.
Hello Gurus,
I was occupied in some work so could not revert back.
This is where I had reached the last time as per above quotes.
I have a question thats irritating me. Courtesy my friends and family.
Is the sound level produced by the above equipment, justified as per the space inside the car.
I am more for SQ.
I am a noob, so answer my stupid question so that I can justify the(more) increment in my budget as well.
tush is offline   Reply With Quote
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
