Old 23rd August 2009, 18:54   #1936
abhinav.gupta88's Avatar
Thanked: 310 Times
Originally Posted by Epic View Post
Hi Abhinav,
Yes the car is a Swift. Rears to help fill the entire soundstage.
I would rather recommend you not to fill in the entire sound stage if no one sits in the back and bi-amp the carbons.
I think you should talk to b&t about this and hear his views.
Old 23rd August 2009, 19:26   #1937
CaliforniaKnight's Avatar
Thanked: 46 Times
Pardon my ignorance, but what do you mean by bi - amping?speakers to be powered via 2 amps?If yes, wont they damage them?
Thanks.
CaliforniaKnight is offline   Reply With Quote
Old 23rd August 2009, 19:42   #1938
tush's Avatar
Originally Posted by greenh0rn View Post
Tush, about your enclosure query- its design, as long as it is a sealed enclosure, is a simple matter of getting the internal volume right. There is no rocket science involves as such and in fact many guys like to build their enclosures themselves (a simple nice DIY job). Even you could do that, if you have access to tools and time. Else, your dealer will be happy to get one made for you. Remember, it's just the volume of the enclosure that matters, so all you need is a carpenter- even someone who isn't terrific at his job!
Thanks for throwing some inputs on it.
Originally Posted by abhinav.gupta88 View Post
You can go in for the Infinity Reference 475a.
Preety good amp, good alternate to the 1004.
Available for around 12k i suppose.
Yep I have that in mind. Hence before putting down the money I am taking help from Team Bhpians, as its said and I do believe in "Well begun is half done".
I read in a thread that there are even amps significantly cheaper then 14000/-(in my case i was looking for JBL 1004) and give better or equal performance.
Is that true? If that is the case which are those amps?
tush is offline   Reply With Quote
Old 23rd August 2009, 19:47   #1939
Thanked: 310 Times
Bi-amping is like 2 channel for the Midbasses and 2 channels for the tweeters crossed by the crossover.
It can be through 1 4 channel amp, 2 2 channel amps.
Some speakers do have cross overs which have bi-amp settings.
So they cannot get damaged ( if given the power they can handle)
Explained with pics.
In the 1st image you can see there is IN -, IN + which is the input ( Amp to crossover) , WF- , WF + which is woofer output ( crossover to mid bass) and TW- , TW+ which is for tweeter output ( cross over to tweeter)
This is a speaker set which does not get bi-amping features.
In the 2nd image , you can see TWIN + , TWIN - which is tweeter input , MIDIN + , MIDIN - which is midwoofer input and MID + , MID - , TW + and TW- which are outputs for mid bass and tweeters.
In this you can clearly notice that tweeter takes in a seperate input and the mid bass takes in a seperate input.
Thus the Tweeter input would take 1 channel and the mid bass input will take another channel.
and as there are 2 channels ( left and right), a total of 4 channels ( 4 or 2+2) is required for bi-amping.
This speaker has a feature of bi-amping and is usually better than a normal setting.
Old 23rd August 2009, 19:49   #1940
Thanked: 310 Times
I think there arent too many amps in the sub 14k range which are as good performance wise as the JBL 1004.
Maybe the Ground Zero has one , infinity 475a can be had. or maybe some in the DLS etc range. ( not sure)
Old 24th August 2009, 08:55   #1941
Tushargohil's Avatar
Thanked: 71 Times
Post Swift ICE Help !!!
Hello GURU,
This is Tushar from Bangalore,
Guys I need your help, I am expecting to deliver my swift VDI before September 2nd week hence looking for good ICE configuration,
ICE (Budget 30k)
1. HU Pioneer AVH 5100 (Touch Screen MOSFET 50W x 4) (Bought it
from US 400$)
2. Front Looking for Components Speaker
3. Rear - Looking for Coaxial 3/4-Way Speaker
4. Damping (for now front only)
5. Amplifiers (For front speaker and subwoofer)
6. Subwoofers
Thanks,
Tushargohil is offline   Reply With Quote
Old 25th August 2009, 19:12   #1942
Thanked: 310 Times
Is the 30000 without the HU or with the HU.
If its with the HU.
Then 14k won't fetch you compoos, coax, Amps and sub.
If its for 30k
Here's a small suggestion from my side.
Keep 5k for wiring + damping.
Front compos - 6-7k ( Illusion , JBL etc)
Rear Coax - 4k ( JBL / Pioneer etc)
Sub - JBL 1215 or similar - 4-5k.
Amplifier - JBL 1004 - 9k ( grey)
You can use 2 channels for the fronts and 2 channel for the sub.
It would sound pretty decent IMO.
Old 25th August 2009, 19:42   #1943
Thanked: 71 Times
If its with the HU.
If its for 30k
Thanks for replying Abhi,
This is what I have shortlisted
Front compos - TS-D1720C 17CM PACKAGED COMPONENT SPEAKER SYSTEM
Rear Coax - 4k TS-A643 - 16 cm 4-Way Speaker
Sub - JBL 1215 or similar - 4-5k. (Not decided as I am concern about space)
Amplifier - JBL 1004 - 9k (grey) (Not decided)
Thanks,
Forgot to mention you yes i have 30k budget without HU (HU i bought is Pio AVH 5100)
Last edited by Jaggu : 25th August 2009 at 21:01. Reason: Back to back posts. Wait for approval so that you can edit original post during New member status, Thanks
Old 25th August 2009, 22:03   #1944
Thanked: 39 Times
Have you listened to these speakers, in your own car preferably? Listened to any other speakers from a competing brand? Auditioning different speakers is highly recommended before you buy stuff- helps avoid disappointment/frustration/heartburn in the future.
greenh0rn is offline   Reply With Quote
Old 25th August 2009, 22:44   #1945
Thanked: 310 Times
I have heard the pioneer components and they are not too good.
I'll suggest you the JBL combo instead.
JBL 608c , JBL 938.
Good VFM stuff.
Old 25th August 2009, 23:33   #1946
Thanked: 71 Times
Post
Point is taken, to honest with you I have never use component speaker before all I use was coaxial 2 ways so all to gather this would be new experience
JBL 608c , JBL 938.
Good VFM stuff.
Abhi,
One quick question i am going for PIO AVH-P5100DVD Do I need to consider any special speaker for that for good combination of HU & Speakers?
Old 26th August 2009, 00:12   #1947
Thanked: 310 Times
It isn't such.
All depends on your taste and preference.
Choose the speakers which you feel sound the best to you.
Old 26th August 2009, 12:43   #1948
Thanked: 71 Times
Checking. India JBL for good speakers.
Old 27th August 2009, 00:11   #1949
tush's Avatar
Okay guys been to another ICE shop today.
Was very keen on explaining me that I should go for Focal components.
Well it were 12k so were out of my budget. So he said he doesnt recommend anything below JBL Power series let aside Illusion EL 6.1 that I have been thinking off.
Another thing that he was pushing was for Focal Solid 4 which is a 4 channel amp. He says its much better then JBL 1004.
For Subwoofer I asked him for GZ 30T. He said dont go for it as it has no enclosure and getting an exact matching density enclosure for this is a kir kir.
Based on my requirement of tight and deep bass he says dont go for 12" go for 10" as it will give you deep and tight bass and not boom boom.
For this he recommends MTX Thunder Subwoofer 10".
He said he doesnt recommend damping on my setup since as per him I am not going for any high end stuff which is very powerfull to cause any vibs in the door.
How much truth lies in this persons talk ?
Seems things are forcing me to up my budget
Old 27th August 2009, 01:23   #1950
Thanked: 310 Times
A swift without damping is bad even for a 10" sub getting around 200w.
Let alone giving it more power.
As for the enclosure.
Ask bass&trouble.
He would be happy to get one made according to specs and send it across.
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
