Old 20th October 2009, 16:33   #2011
khoj's Avatar
Thanked: 1,258 Times
JD,
Just came back after scouring the local markets, not a single guy knows what they are selling. Speaker level input woh kya hai ? speaker toh neechay lagega ya phir peeche uske level per input kaise hoga woh to aagey dibbay mein se hi hoga. Speaker mein sirf amp se output aayega, period.
I will go to the Alpine co. shop in southextension tomorrow & hopefully will find the answer there.
Old 20th October 2009, 22:35   #2012
jithudigitised's Avatar
Thanked: 96 Times
Please look at the pic below for Speaker Level input which is on the left side of the RCA inputs.
ICE upgrade : Maruti Swift-jvc-front-shot.jpg
In this pic the Speaker Level input adapter is connected to the amp.
ICE upgrade : Maruti Swift-sli-adapter-connected.jpg
Now you may have get a fair idea for what to search for.
jithudigitised is offline   Reply With Quote
Old 21st October 2009, 00:26   #2013
khoj's Avatar
JD,
Thank you for the pictures, this is great now that I know what exactly to look for. I will provide an update on my search tomorrow.
Thanks again
Old 21st October 2009, 18:59   #2014
khoj's Avatar
Hi JD & Navin,
I have been able to locate amplifier with the speaker level inputs. It is a Kenwood 8401 with a max output of 600W. Link attached. Kenwood Corporation | Car Electroics | Power Amplifiers | KAC-8404
I would appreciate if you could confirm whether the above amp will do the job. Also if you could let me know the rating for the component speakers that would go with this amp. I would also be connecting the JBL 1100W tube subwoofer to the same. Did not like the boxed enclosures due to size & weight etc.
[quote=navin;1537853]1. Yes the stock Swift system is not heavily EQed hence you can easily add an amp and better speakers. The amp would have to one that has spekaer level inputs because the OEM head unit does not have RCA pre outs.
Interestingly this guy had an OEM unit taken off a Ritz which is identical to the unit offered on my swift (at least in looks). Now this unit had the RCA preouts. My swift is a 2008 Sept model and I checked with the local (MSM (Maruti Service Masters) per them the units in term of connectivity are identical across the Ritz, swift and Sx4 except for additional steering mounted controls for the Swift and SX4.
I look forward to hearing from you guys.
Old 21st October 2009, 23:35   #2015
Thanked: 96 Times
Well i think the link you attached and amp you specified are entirely different.
So which is the amp : 8401 or 8404.
If you are going to any local MASS, then you can ask them to remove your head unit to have a look at the rear of the HU,whether it has a RCA out or not .
Regarding the component speakers you can select among Illusion electras,JBL,BUll etc which comes in a price range of 5K-7K.
When selecting the speakers,amps,subs look for its RMS power rather than its max power.
So happy choosing.hehe
Old 22nd October 2009, 00:04   #2016
khoj's Avatar
Whoops! my mistake JD, the amplifier is the 8404 indeed as in the link. So. I will go ahead with the same. Now what do you think of the Rockford Fosgate speakers. They have just been introduced in the Indian market but I have seen these being used almost exclusively in the Overhaulin shows on T&L channel.
Old 22nd October 2009, 10:53   #2017
Default Swift ZXi ICE Upgrade
[FONT=&quot]Hi Khoj,[/FONT]
[FONT=&quot]I too have Swift ZXi (Sep'08). I upgraded my ICE couple of days back.
* FYI: Swift ZXi has 1 Pre-out.
Thanks to DerAlte for all the inputs he gave me in choosing the right upgrades for my car.
Here is what I upgraded for time being:
Infinity Ref6030cs Front Comps
JBL GT5-S644 4 Channel Amp
Polk db 1240 Sub
Audison Wiring Kit
Basic Damping for Front Doors and some fillings for rear door[/FONT]
Installation was done by one of the popular installer among the members in Team-BHP.
Two issues I faced while installing on ZXi is:
1) No remote cable in ZXi that can switch off Amp when you switch off the HU. So we had to provide a separate switch for Amp to be switched off/on. This can be resolved when I upgrade my HU!
2) The issue which I see now is the "hisss" noise in the front comps (which is near to me!) when I press the accelerator when the car is in idle condition with HU switched off. I don't know how we can solve this issue.
May be Team-BHP gurus can help me sort these issues!
Thanks,
Deepak
deepax is offline   Reply With Quote
Old 22nd October 2009, 11:52   #2018
khoj's Avatar
Hi deepax,
Thanks for sharing the info, so it is now confirmed that the HUs for Swift & Ritz are identical.
Regarding the two issues that you mention, I was wondering whether
1. An amp with signal sensing power on feature would negate the need for the on/off switch.
and
2. regarding the hissing sound, try the following link where Jithudigitised has spoken about the same including its source and resolution in his DIY project. http://www.team-bhp.com/forum/diy-do...ower-wire.html
Old 22nd October 2009, 13:52   #2019
Thanked: 96 Times
About the rockford fosgate speakers, i haven't heard them,so can't comment.
For the speakers, i would recommend you to audition among them and select according to your taste of music.
Old 22nd October 2009, 14:14   #2020
Hey Khoj,
Thanks man... I think I got the solution for the problem, need to go back to the installer and get the 2nd issue sorted.
Old 22nd October 2009, 23:04   #2021
khoj's Avatar
Originally Posted by deepax View Post
Hey Khoj,
Hi deepax,
Your thanks should go to Jithudigitised, I merely pointed out the thread.
BTW when you go to the installer do try to find out whether an on/off switch would be required even if we were to use a signal sensing power on Amplifier.
Old 23rd October 2009, 12:02   #2022
Hi deepax,
Right khoj!
Thanks Jithudigitised.
I will be sorting this noise thing in couple of days.
Khoj, I will check the point you mentioned when I visit the installer.
Old 9th November 2009, 16:38   #2023
Epic's Avatar
Thanked: 424 Times
Hey guys,
After alot of posts, discussions, Pms and confusions. Here is what i have planned my upgrade to be with the help of B&T: -
Current Set-up
Head Unit : Pioneer 6950
Fr Comp : JBL GTO 606Ce
Rear 6X9s : JBL GTO 937
12" Sub : Infinity Ref 1200T (Installed in a sealed box)
4-Ch Amp - JBL GTO 75.4 (Driving the Compos & 6X9s)
Monoblock - JBL GTO 301.1 (Driving the sub)
Proposed upgrade
Head Unit : Pioneer 6950 (Will upgrade to a highend later when budget permits)
Fr Comp : Illusion Carbon Nd 6.1
Rear Coaxials : DLS Performance 428 two way 8" coaxials
12" Sub : Ground Zero GZRW 12XD-AL (Installed in a sealed box)
4-Ch Amp - JBL GTO 75.4 (Driving the Compos & Coaxials)
Monoblock - VSL P610.1 (Driving the sub)
Damping has already been done. 4-channel amp will also be upgraded later when budget permits.
What do you guys think of this setup?
Epic is offline   Reply With Quote
Old 9th November 2009, 16:48   #2024
navin's Avatar
Thanked: 4,286 Times
I dont see anything wrong with this. what advice did you want?
Old 9th November 2009, 17:02   #2025
Epic's Avatar
Thanked: 424 Times
Should I change the headunit & 75.4 amp? If yes, for a setup like this, which amp & headunit would you suggest?
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
