Old 18th December 2006, 17:50   #196
Thanked: 25 Times
Hi all.
Round II
1. If i go for the following config, wud i need a AMP ?
HU: Pio 6890
Front Comps: Hertz DSK 130
Rear Coax: Blau 122
ALso if do away with rear coax and Instead go with Hertz DSK 165 only in front , would i need an AMP at the moment? (I can always do a rear fill a few months down the line)
Please remember i do not wish to spend more than 16K at the moment!
Elito11 is offline   Reply With Quote
Old 18th December 2006, 18:39   #197
Thanked: 17 Times
First of all, the Pio HU you mean here is 6850 I suppose. There's no 6850 in Pioneer's current line up.
With your both setups (W/O rearfills) mentioned above, an Amp is not necessary. But an amp can work magic to your setup as it will play a lot cleaner than your HU output. If you dont have rearfills and amp now, then tell the installer to connect the woofers' crossovers to HU's rear output and tweeters' crossovers to HU's front output. And connect the crossovers to their respective speakers.
Why DSK130 and not 165? They will sound better than 130 and will fit well in the stock location of the Swift.
I would suggest you use a Hertz DCX co-axial with your DSK for rearfill.
Old 18th December 2006, 18:49   #198
Thanked: 25 Times
Hello Speedzak!
Yeah Pio 6850. Thanks for the corection.
Well I wud have gone for a DSK 165 but i doubt the whole thing wud fit in 16K!.
As for the AMP...... after 2 months maybe!!
Also i have heard gr8 thing abt Blau IC 122, infact a friend has them in his car..sounded good. But if DCX Co-axial is a better fit...why not..will hear em out both!
P.s. - I have a GETZ, its just i thought i might get a quicker response here, so i kinda posted in the swift thread ( i guess i need a signature!!)
Thanks ..now i only need to get to 'Driven'!!
Old 18th December 2006, 20:23   #199
hydrashok's Avatar
Elito, stay away from the Blau IC 122. I think they stopped the "In Car" series a year or so back, so if you get one now it is likely to be old stock. I had an IC 122 in my front door for a very short time before I got rid of it. I didn't like the sound that much (but that's just me). Blau's entry level stuff is called the GT series now. Not so very good in comparison with the other speakers from other brands in the same price point.
Even if you have to wait a while, go for the DCX130 for the rear-fill. You won't need to switch speakers later, and the sound will blend better with the DSKs in front.
Like Zak said, an Amp is not a necessity, but is a definite desirable. Adding an amp will add a lot of body to the sound. But again, you can always add it later, without having to change anything else in your setup.
And, don't even think of DSK130s when you can do DSK165s. They will not cost thaaat much extra. 165s will give better bass than 130s. If you're getting the Pio and the DSK165s only now, you will be able to finish the setup in 15K.
Old 18th December 2006, 22:20   #200
Thanked: 25 Times
Hydrashok....ur THE MAN!! . Thanks dude...ur passion is admirable
Will go for a HU+Front comps for now and in a month or two add the rear fills and the AMP!!
Elito
Old 19th December 2006, 01:03   #201
Autophile's Avatar
Originally Posted by aZa View Post
Zak !!! DRIVEN is like 40-50 odd kms oneway from NOIDA but Yes if you are in delhi then DRIVEN is T-H-E place to be for ICE'IN and some nice Wada Sambhar heheh!
40-50 Kms from Noida . aZA get your cars odo meter checked before you spend money to add a tachometer
Autophile is offline   Reply With Quote
Old 19th December 2006, 01:38   #202
Thanked: 21 Times
And I definitely remember sharing some butter chicken with you there...
Old 19th December 2006, 02:07   #203
Thanked: 17 Times
So, shall we start it all over again? Which one do you want? Butterchicken or......?
BTW, get a DSK165 and a Pioneer 6850 for now. And Mr. Driven will do a perfect install.
Next, you can upgrade to an amp, rearfills, good cabling and subwoofer(s).
Old 19th December 2006, 14:25   #204
navin's Avatar
Thanked: 4,282 Times
Is it me or something I did. I never getr invited for butter chicken or beer parties. :-(
Old 19th December 2006, 14:51   #205
iraghava's Avatar
Thanked: 156 Times
Well Navin, considering you said on the other thread that you don't socialise anymore I guess people are scared of you After you are the Old Man of ICE!!
But yeah you have an open invitation to the next Delhi Beer/Alcohol Fests, please join us if you can!!
Old 20th December 2006, 10:20   #206
Thanked: 25 Times
Hi All
Was looking around and found this article
Great 6-1/2 Inch Component Car Stereo Speakers
Hence was wondering how much any of these would cost. Esp JBL P650c
I am guessing 5.5K..is it so?
Also if i DO (just fantasizing) go in for a 4 channel AMP right now as well. How much wud a standard product cost?
Thanks!
Old 20th December 2006, 10:28   #207
Vid6639's Avatar
Thanked: 21,057 Times
nope elito much more the power series is the top of the line JBL speakers and they are not available in india.
the P650 may set you back by probably around 10-11K.
Old 20th December 2006, 10:31   #208
Sam Kapasi's Avatar
Thanked: 1,473 Times
Thanks!
What what elito!!
The P (power) series of JBL feature higher than the GTO series. 5.5K will just about get you a set of the popular, good quality GTO components.
P650C should cost you about 12K, methinks.
Old 20th December 2006, 10:43   #209
hydrashok's Avatar
Elito, I don't think the JBL P650c mentioned in that article is available in India (unless it is available under another model name). The model priced near this price (approx $165 ~ Rs.7300/- as per the link in that article) would be the GTO607 (The 607 costs 6500/-).
The Infinitys mentioned are also not available here (under the same model name anyway). The equivalent would be the Infinity Kappa 60.7cs.
BTW, the article does not mention a date (of publishing) so it is likely to be a little dated.
A good entry-level 4-ch amp would be the JBL CS60.4 at 9K. A bit higher, JBL GTO75.4 at 13K. You have other options from Pioneer and Blaupunkt from 7K to the 13K (I mentioned for the JBL). I'd vote for JBL, though.
Additional costs that come with a 4ch amp would be 2 sets of RCA interconnects (2k total for Audison) and of course the Amp wiring kit (3k for Audison. Same for the JBL wiring Kit. Audison would be better. Scosche and Twister are other options). So an additional cost of about 5K should be added to the amp's price when you consider a 4ch amp. I'm not adding installation here, because you'll most likely get it done inclusive of the total amount.
Edit: Whoops! Sam has answered while I was writing this. Sam, long time no see?
Old 20th December 2006, 10:49   #210
Thanked: 25 Times
@ Hydrashok: It sayz the best comps of 2005. So i guess its early 2006.
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
