Old 14th January 2012, 10:56   #2161
navin's Avatar
Thanked: 4,282 Times
Default re: ICE upgrade : Maruti Swift
Originally Posted by hatchbacker View Post
Plan:
HU: Pio DEH-8350SD for SD and iPod. Design looks good/diff to me.
Front Doors: Infinity REF6530CS components
Rear Doors: Infinity KAPPA62.9i coax
No AMP/SUB.
Queries:
1. Does it stand any chance to sound good?
2. Is AMP necessary for this config?
3. Will using Hertz speakers improve sound?
4. Is wiring needed for above config or is it needed only when using AMPs?
5. How much will it cost?
6. One last basic/foolish Q: Do I need 2 component and 2 coax or just 1 comp and 1 coax for 4 doors?
1. It can sound good if the install is done well - aka damping, fitting, good wires etc..
2. An amp is not necessary but it will help.
3. Hertz have a very different sound signature from Infinity. Listen to both and choose what YOU prefer.
4. When you use an amp you need RCA wires from the HU to the amp. When you do not use an amp all you need are speaker wires.
5. Negotiate th cost with at least 2 dealers, preferably 3.
6. Each front door will need a component set (woofer and tweeter). Each rear doo will need a coax set. So you will need 4 speakers sets in all. Fortunately Hertz, Infinity and just about everybody sells speakers in pairs so you will need 2 pairs. 1 component set pair and 1 coax set pair.
FYI: When you buy the Component set you will find 2 funny looking black boxes with about 6-8 screw type connetors in the box. Do NOT throw these away (like a friend of mine did with the packaging). You need these boxes for the woofer and tweeter. Your installer will know what to do. If he does not PLEASE find an installer who does.
Old 14th January 2012, 12:06   #2162
Thumbs up re: ICE upgrade : Maruti Swift
5. Negotiate the cost with at least 2 dealers, preferably 3.
Navin, thanks a lot for prompt help.
hatchbacker is offline   Reply With Quote
Old 16th January 2012, 20:54   #2163
naveenroy's Avatar
Thanked: 782 Times
Default Looking for good audio system for Swift
Hello guys,
Am looking for a great audio setup for the Swift. I am based in Bangalore and am a bit confused about options that are available, prices, dealers etc.
It will be only for audio - not interested in video and other stuff.
naveenroy is offline   Reply With Quote
Old 17th January 2012, 09:26   #2164
rjstyles69's Avatar
Thanked: 795 Times
Default Re: Looking for good audio system for Swift
naveen budget please. With regards to installers please check the tbhp directory here for installers in Bangalore.
Old 17th January 2012, 09:50   #2165
vigsom's Avatar
Thanked: 603 Times
there are umpteen threads on great audio set ups in the old Swift ; the same would hold good for the new one.
Yes,if you have a zxi and want to upgrade the HU,then it would require a custom dash kit
Old 17th January 2012, 10:33   #2166
navin's Avatar
Was not LBM the "How to ICE your Swift so the roof blows off" expert?
Old 17th January 2012, 23:02   #2167
arun_sharon's Avatar
Thanked: 24 Times
Hi
I am planning to put a sub which can go under the driver seat of my swift. Got an option of arc audio active sub for 16k . Looks very sinilar to xenos active sub. Need advice on the options available for under seat installs. Also any one came across the arc audio sub if so how is the quality
Rds
Arun
arun_sharon is offline   Reply With Quote
Old 15th February 2012, 09:48   #2168
Thanked: 23 Times
Dear Team,
Need your help here in improving the bass effect in my Swift VDi
This was my initial set up:
Head Unit: Pioneer AVH-P3200BT
Door Speakers: JBL (Normal door speakers)
Rear Speakers: Coaxial JBL 210W
Recently I upgraded the Door speakers to Component Spearkers and the rear Coaial to Pioneer.
Here is my current set up:
Component Speakers: INFINITY REF6530CS
Rear Speakers: Pioneer TS A934H (500 W)
Due to the upgrade to the component speakers and the rear more powerful coaxial’s I don’t deny the fact that there is a huge improvement in the sound quality. However I am still not able to get the optimum bass. I am now planning to go for a 2-channel JBL amp and a Pioneer/JBL 1300 W Sub. The 2 channel will drive the sub alone.
I am not sure if this would be an ideal upgrade with the limited budget I have. Could you please guide me on how to go about this? Also it would be great if you could also suggest on the recommended brands for the amp/sub.
Thanks a lot for your help !!!
kk28 is offline   Reply With Quote
Old 15th February 2012, 11:33   #2169
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by kk28 View Post
... planning to go for a 2-channel JBL amp and a Pioneer/JBL 1300 W Sub. The 2 channel will drive the sub alone.
I am not sure if this would be an ideal upgrade with the limited budget I have. ...
At 75% of the cost of a 4-ch amp, a 2-ch amp does not make much sense. Instead, get an economical 4-ch amp and connect the sub AND the front components to it. A decent 4-ch amp should cost you 4.5-5.5K (JBL, Pio, Sony etc.). Amping the fronts will get you a bit more bass from them. You will also need to reckon with cables and labor. Some damping will also help, at least in the front doors and the boot lid.
For sub, avoid a tube. Instead, get a pre-built ported box from JBL or Polk. Polk also has a small sealed box with 8" woofer which may be you can fit under the front seat - will not go really gut-shaking low, but good enough if you are on a budget.
Old 15th February 2012, 12:23   #2170
Thanked: 23 Times
Thank you DerAlte for the quick response.
Couple of questions.
1. Could you please explain how the amping of the components helps increasing the bass? I was under the impression most of the bass comes out from the rear coaxials. Considering the set up that I have (500W Coaxials at the rear), would it not make sense to amp the rear?
2. Need your advice on the type of sub. Should I go for a sub with the custom built box or the ones that come prebuilt? There is a model available in Sony which comes with the pre-built box. (I am not referring to the tube)
3. I also need your advice on damping. I have heard a lot about it but not sure how it can be done.
Thanks again for your help!!
Old 26th February 2012, 09:51   #2171
HimuraKenshin's Avatar
Thanked: 183 Times
Exclamation Maruti Swift ICE help
Hey guys,
This is the first time i am posting here.
I got my ICE installed almost 9 months back. I was pretty stupid back then about audio and i think i got cheated.
The front components installed were JBL i think GTS 265 C. the crossover is as small as a pendrive.
For the rear fills there are jbl coaxials.
I have an MTX subwoofer with its own ported enclosure.
A pioneer headunit and a sony 4 channel amp.
Let me start of by saying that i was happy in the beginning, but now im simply annoyed with the sound. its just too bright. The treble hurts my ears and the bass is flabby and the bass also clips.
Im attaching some pics of the equipment i have.
please suggest an upgrade without changing the HU or the amp.
Also please take into consideration that my max budget is 11K
ICE upgrade : Maruti Swift-img2012022600059.jpg
ICE upgrade : Maruti Swift-img2012022600060.jpg
ICE upgrade : Maruti Swift-img2012022600061.jpg
ICE upgrade : Maruti Swift-img2012022600062.jpg
ICE upgrade : Maruti Swift-img2012022600065.jpg
HimuraKenshin is offline   Reply With Quote
Old 26th February 2012, 20:14   #2172
DerAlte's Avatar
Default Re: Maruti Swift ICE help
Originally Posted by HimuraKenshin View Post
... but now im simply annoyed with the sound. its just too bright. The treble hurts my ears and the bass is flabby and the bass also clips. ...
Your listening tastes have matured, so you should be happy for that!
1. Bass: can't expect anything else from a tube. The clipping may be due to a high gain setting. Q&D solution: stuff some old socks rolled up in a tight wad up the bass port (the side opposite the sub). This should reduce the 'flabbyness', and also reduce the clipping (does it sound like slapping?). The side effect will be it will reduce the loudness of the bass, but that may not necessarily be bad, up to a limit you can increase the gain at the amp to compensate. While this will not drastically improve the bass, this should do while you build up the budget to replace the tube with a decent sub in a sealed box
2. Treble: now this is a rather tricky problem, since this is an inherent property of those components. The solution (again, apart from replacing the components) is to either pad the XO, or another Q&D solution: add a couple of layers cloth in front of the tweeter. You could also reduce the Treble at the HU (Parametric Equalizer)
You can do it yourself - try it.
BTW, what is that red wire with a terminal lug not connected anywhere (in front of the sub)? Better cover it with electrical tape to prevent something untoward happening in future.
Old 26th February 2012, 21:27   #2173
Thanked: 183 Times
The red wire is just a spare. not connected anywhere. :P
I would like to upgrade the sub and the componenets. could you please suggest a combination.
I had a look at the boston compos today as well as a JBL Subwoofer with an enclosre(the one with the 2 bars as the speaker grille)
Old 27th February 2012, 10:08   #2174
navin's Avatar
but now im simply annoyed with the sound. its just too bright. The treble hurts my ears and the bass is flabby and the bass also clips.:
Ha the curse of the audiophile bites.
2. Treble: now this is a rather tricky problem, since this is an inherent property of those components. The solution (again, apart from replacing the components) is to either pad the XO, or another Q&D solution: add a couple of layers cloth in front of the tweeter. You could also reduce the Treble at the HU (Parametric Equalizer).
DA, Sometimes I wish I could be happy with a set of Acoustimass speakers like most of my friends and relatives are. This "maturing" thing is a curse - we the affected (or infected) dream of Sonus Faber and Martin Logan. It is curse I tell you.
Some XO's have a -3db terminal for the tweeter section. Check your XO.
A spare for what? Power? Dont leave it hanging like that.
Old 27th February 2012, 12:53   #2175
DerAlte's Avatar
... I had a look at the boston compos today as well as a JBL Subwoofer with an enclosre(the one with the 2 bars as the speaker grille)
1. Components: Boston is good. Audition Infinity Reference, Morel Maximo, Bull, Auditor, Polk (the db series, not the Momo series) etc.
2. Sub: Audition others first - Infinity Reference, Polk, Bull etc. in a sealed box. Some are available in a pre-built sealed box, for others one can get a suitable local MDF box
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
