Old 18th February 2007, 12:40   #331
Vid6639's Avatar
Thanked: 20,991 Times
Why do you need a wiring harness? you can use the original harness and connect that to the HU harness.
Old 18th February 2007, 22:35   #332
Thanked: 13 Times
I was under the impression you would need use a second harness between the connections and the HU. Didnt realise that you could re-use the orignal harness. My bad.
Old 27th March 2007, 16:45   #333
Default Confused
Hi Guys,
I have a black swift VXi and i have ICEed it as follows,
HU: Pioneer 6850
Front: Infinity Ref6010cs components (90W RMS)
Rear: Infinity Ref9613i (100W RMS)
Now i am planning to add an Amp to my existing setup because i feel the speakers are not getting enough power and there is disturbance when i increase the volume. So i have shortlisted two amps from JBL one is CS60.4 and the other one is GTO75.4.
Now the problem is I am confused about which amp to buy (I have no plans off adding a Sub). One installer tells me that there is no use in installing a CS60.4 as the speakers will be under powered because the speakers can take 100W RMS and CS60.4 gives out only 60W RMS whereas a GTO75.4 gives out 104W RMS but another installer tells me that for this setup i dont require a GTO75.4 and CS60.4 is more than enough.
I am confused a lot about this guys and i am not able to decide. So PLS suggest me which Amp should i go for....
Thanks and Regards,
Vijay
vijayvk_84 is offline   Reply With Quote
Old 27th March 2007, 17:40   #334
scarlet.fever's Avatar
Thanked: 25 Times
The first installer is correct.You should use the 75.4.IT is a better amp and will give you the correct performance which u require.
So plz go for it.
scarlet.fever is offline   Reply With Quote
Old 27th March 2007, 18:07   #335
mobike008's Avatar
Thanked: 8,319 Times
@Vijay, Welcome to team-bhp and enjoy your stay here. Regarding your query:-
I am assuming your currently powering your Rear and Front Comps through the HU Amp, no wonder there is a distortion when you increase the volume. You certainely need a decent amp and you can look at these options
Economic Solution: Pio 6100 ( Rs.7K) and connect this 4 channel amp to front comps and rear speakers. If you decide to go for woofer in future, you can then power the rear with HU and connect those spare 2 channels for the woofer
Slightly Pricy Solution: Same as above but, JBL 60.4 ( ~ 9K)
Even Pricer Solution: Same as above but, JBL 75.4 ( ~ 13K)
Take your pick
Old 27th March 2007, 19:04   #336
hydrashok's Avatar
Welcome to TBHP ICE, Vijay!
A CS60.4/Pio6200 will be enough to make a substantial difference, and will cost just around 8K-8.5K. It will do for most people.
A 75.4 will really make your speakers rock! (Esp. as they are Infinitys). At an additional 5K. (It comes to around 13k plus). It is better bang for the buck than the 60.4. And later, if needed (if you change your mind), it can take a better sub than the 60.4 can.
You can choose depending on your listening requirements, and upgrade plans (if any). You may later feel (after a while) that "if the 60.4 is sounding like this, what will the 75.4 sound like? I should have gone in for the 75.4 then :(" [This happens to me all the time]. So if you're that type, and don't mind spending the extra green go for the 75.4
Also, when you are thinking about the cost of the amp, please also figure in an additional 2-3K for a power wiring kit, and 0.75K to 1k per set of RCA interconnects (you'll need 2 sets for a 4-ch amp). So, add about 4-5K to the cost of whatever 4-ch amp you're going to get.
Old 27th March 2007, 19:35   #337
Sam Kapasi's Avatar
Thanked: 1,473 Times
I am confused
Hello Vijay,
By the time I read your PM, you'd already bought the Infinity's. Good speakers, by the way.
If it is a difference you wanna make, then the CS60.4 will drive the speakers quite well. If you were going to add a sub, and wantede to drive the speakers in HPF only, then I would ask you to put a CS60.4 anyways.
But in full range, that 75.4 will make them sing out loud.
If you can afford it, go for it. Otherwise go for the CS60.4
Old 28th March 2007, 00:59   #338
Default Thanks a lot guys
Hi Guys,
First of all i would like to thank all you guys who replied to my post, i actually never expected so much replies.
As you all suggested i will go for JBL GTO75.4 i think it is worth spending another 4K because as hydrashok said i should not crib tomorrow.
I have few more query's. I had been to Auto Fusion to enquire about installation today met Mr.Anwar there(heard that he is one of the best installer in town) he told that he would charge Rs.1800 for installation(including damping the doors with foam and rewiring the existing connections). So is that price ok or should i bargain?
Is there any other better place in Bangalore where i can do the installation?(Budget not a constrain, all i want is good quality hassel free installation)
And how much would damping cost? What all should i damp in a Swift? TMC electronics has quoted Rs.900 for damping two doors and he said he will use damping material from a company called Wurth. Is it worth it?
Pls help me guys i am new to this ICE thing and it confuses me a lot....
Thanks and Regards,
Vijay
Old 28th March 2007, 09:40   #339
navin's Avatar
Thanked: 4,282 Times
You are lucky to live in Bangy. THere are a few good installers there. The Bangyboys will detail that list.
Anwar by all accounts is one of the better installers there. Trust him - tell him that you a "friend of Sam"; those 2 words scare most installers into doing a good job.
Old 28th March 2007, 10:19   #340
Vid6639's Avatar
yeah tell thouqeer and Anwar that Sam has told to come to Auto fusion only. thouqeer is aware of team-bhp as well.
Old 28th March 2007, 16:09   #341
Sam Kapasi's Avatar
The price is ok, methinks. Anwar is a good installer indeed. Only thing is this foam business. What foam?
And yes, do convey my regards to anwar. As a joke later, you can ask him if the price includes a new kind of tax.
Old 28th March 2007, 16:16   #342
Vid6639's Avatar
yeah its some closed cell black colour foam. few mm thick. For the boot where water is difficult to enter the tailgate he puts that old rags and stuffs them tight. Ofcourse for people on a budget.
Old 29th March 2007, 14:01   #343
babhishek's Avatar
Hi Guys,
After reading through this forum for the last few months, and personally getting my install done with an alpine-audion-hertz combo; I would say you are getting an awesome deal.
Anwar is damn reputed in TBHP and that speaks a lot for his skills.
I think 1800/- is perfect, I paid 2000/- for my install quite similar to yours from someone far less skilled/reputed than Anwar.
In short, go for it, and tip em some more!
:P
babhishek is offline   Reply With Quote
Old 29th March 2007, 14:02   #344
navin's Avatar
is this the stuff Anil sells?
Old 29th March 2007, 14:54   #345
Sam Kapasi's Avatar
nope .
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
