Old 14th May 2007, 13:35   #481
Thanked: 21 Times
Originally Posted by austere_sly View Post
HU : Pioneer 5950 IB
Front : Hertz DSX 165
Rear : Hertz DSK 165
A correction here, it must be DSK165 in the front and DCX165 in the rear. And you're right about Driven. They know they're job well.
Old 14th May 2007, 16:02   #482
navin's Avatar
Thanked: 4,286 Times
Originally Posted by partypest View Post
... and what do i do with the tweeters of the 4 inch?
you mean to say the 4" are components? in that case why not see if the installer can mount the tweeters in the rear doors.
Old 14th May 2007, 16:19   #483
austere_sly's Avatar
Thanked: 9 Times
Thanks Gunbir for correcting me. It is indeed DSK165 in front and DSX165 in
rear. I guess the time of posting i.e. 3:12 am (which is normally the time i
am slept) can be a good excuse for mistake.
Just a queston here : Almost 100% of my music is downloaded one with
bit rates usually 160 kbps. I try to download songs with highest bit rates.
During installation i was suggested to play uncompressed format i.e. wav
file. Its not possible for me to get CD's of all songs. What i wanted to ask is
that is there any thing which can be done to compensate for the loss of
quality by playing compressed format
. Also my PIO HU can play mp3 ,
wma and aac. Will it be any useful if i play my songs in wma format
after converting from.
austere_sly is offline   Reply With Quote
Old 14th May 2007, 16:22   #484
Thanked: 9 Times
can these be placed on the B pillar above seat belts aiming at the passenger at rear seat. (I am not sure if that pillar is called B Pillar)
How will the listening experience change if the direction of those tweeters is changed from rear seat to that of passengers at rear seat.
Old 15th May 2007, 10:46   #485
"Almost 100% of my music is downloaded one with
file. Its not possible for me to get CD's of all songs. What i wanted to ask is that is there any thing which can be done to compensate for the loss of quality by playing compressed format. Also my PIO HU can play mp3 ,wma and aac. Will it be any useful if i play my songs in wma format after converting from."
YES, Installation guys are right. Uncompressed format of songs(Normal Audio CD & WAV files) are much preffered to get hight quality audio. Since normal Audio CD (CDDA) contains PCM uncompressed data, they have good clarity. WAV file is actually PCM Uncompressed data + WAV header. You can extract WAV file of particular song from normal AudioCD by using some free softwares.
Regarding Compressed formats (MP3, WMA, AAC), all are targetted to reduce the size of file by sacrificing its quality (Lossy compressions). So in this case, clarity will be reduced. If you need to much high audio clarity , then you need to install HU with DVD-AUDIO (Special DVD media type targetted for high quality audio, 5 channel, 96Khz, 9.6mbps, Loseless compression using MLP & DVDA-LPCM) playback support. we had supplied for above mentioned HU to US based manufacturer for his 2007 model .
MP3 bitrate - ya you are right, we get mostly 128kbps or 160Kbps tracks. But you can get high quality variable bitrate tracks with 256Kbps encoded using LAME encoder. Heard it, you feel the diff.
ROCK n ROLL with ur 5950 :-)
mashoforu is offline   Reply With Quote
Old 15th May 2007, 13:16   #486
anshurao's Avatar
Thanked: 53 Times
Disclaimer:
1. What is the exact model number of your current sub?
2. Do you like the Boston sound? Some love it some dont.
Those Bostons sound good, i kinda like them ..if not love them. Thanks Navin
anshurao is offline   Reply With Quote
Old 15th May 2007, 18:35   #487
Thanked: 9 Times
@mashoforu :
Between Variable Bit rate and Constant Bit Rate , what should i choose ?
mp3, wma or aac ?
What to do compensate for the songs which are 128 kbps or 160 kbps I already have ?
Old 16th May 2007, 10:52   #488
navin's Avatar
Just a queston here : Almost 100% of my music is downloaded one with bit rates usually 160 kbps.... What i wanted to ask is that is there any thing which can be done to compensate for the loss of quality by playing compressed format. Also my PIO HU can play mp3 , wma and aac. Will it be any useful if i play my songs in wma format after converting from.
No there is no method to make MP3 sound significantly better. However there is a whole forum dedicated to this and you can ask there (www.hydrogenaudio.org).
Also if you are looking for CD quality sound and still want to save space and have tags try lossless formats like FLAC or WavPack. You will need software to let your ipod or MP3 player recognsie this format as well.
Old 16th May 2007, 11:24   #489
tsk1979's Avatar
Thanked: 16,422 Times
How will 320kbps mp3 sound, as good as CD?
Old 16th May 2007, 11:25   #490
If I am not wrong, most lossless formats compress CD quality files to roughly 50% of their original size or whereabouts. (as compared to 10% @128kbps, which is like having a 10 cd changer)
I know that there is "lossless" option in WMA itself (wma-9 onwards). Though WMA is widely supported by current HUs, I don't know how many (if at all) can decode lossless format. Any idea? If so, wouldn't it be the easiest option to go lossless?
santosh.s is offline   Reply With Quote
Old 16th May 2007, 12:49   #491
Thanked: 9 Times
Some pics of my swift install. I realized this later that I should have taken more. But since it was the first time i was seeing an ICE install done, i was
more intrigued by seeing it done rather than taking pics.
Old 16th May 2007, 13:56   #492
mp3, wma or aac ?
- In VBR, Bitrate will be peak in specific part of audio track where we need more emphasis or audio clarity needed. In CBR, bitrate will be always at its peak. So in terms of size, VBR is much smaller than CBR of same peak Bitrate.
- in case of size
mp3 > WMA > AAC
- Try to use track with max bitrate for gud clarity
For getting gud clarity Mp3, You can try to convert the any WAV file into MP3 using Lame Encoder which is available in Net(using different bit rate setting).
@TSK1979
More bitrate more will be the clarity.
@santhos.s
WMA 9 suports WMA9 (lossy compression), WMA lossless and WMA Pro (Multichannel).
Generally HU supports only WMA 9 lossy.
Old 16th May 2007, 14:59   #493
Thanked: 21 Times
Thumbs up
Based purely on our own tests, we think WMA9 VBR (Q98) Lossy is ways ahead of LAME MP3 in SQ. I suggest others try / compare it (if you havent already) and I would be pleased to know your thoughts on this.
Old 16th May 2007, 15:09   #494
tsk1979's Avatar
Well LAME mp3 is lossy compression, For actual comparison of apples to apples a lossless compression should be compared with lossless compression.
For example WMA(Lossless) with FLAC
@TSK1979
Well thats true, what I meant was that will it give CD quality?
Old 16th May 2007, 15:57   #495
Thanked: 21 Times
I could get you to audition the same MP3/WMA disc Vs Audio CD in two separate cars with different ICE systems. On one, you will be hard pressed to find any difference, on the other the difference will be clear as day. So eventually it depends on the equipment one's using.
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
