Old 7th June 2007, 01:57   #616
Thanked: 294 Times
Originally Posted by Wimwian View Post
Thanks Hydra, unfortunately haven't found anybody in Kolkata who can gimme a demo of the THc172s... even the blau demo shop doesn't have them set up so as of now, i'm going with the JBL's
Still trying to make a choice between the Pio and Blau HU's... the Pio comes with a lot more features and sounds more VFM... but i'm in love with the Maui design... also, not sure how many of those Pio features i'll end up using... damn, this is tough!!
I would preffer the pioneer HU against the blau.....as it will have better menu options and more features when compared to blau.......also the pioneer sound better than the blau but it is my opinion... so listen before buying...
Old 7th June 2007, 14:16   #617
ebmrajesh's Avatar
Thanked: 26 Times
Originally Posted by austere_sly View Post
Swift stock location has space for 6" speakers, but 6.5" can be easily accommodated with the help of spacers.
Its a crossover and not a speaker. It will send higher frequency to the tweeters and lower frequency to the woofer. It doesn't need to be in the open and can be easily put under dashboard or inside of door panels.
@austere_sly: thanks for clarifying my doubts. Now i am clear with my requirments. I will go ahead with the recommended specifications.
ebmrajesh is offline   Reply With Quote
Old 7th June 2007, 20:26   #618
Thanked: 19 Times
Originally Posted by Sam Kapasi View Post
Hello Vijay.
The GTO1202D is a dual 2 ohm sub. You can connect it successfully to the 75.4 bridged or the 301.1.
In both cases make sure you connect it as 2 series 2 = 4 ohms.
The 601.1 will be overkill.
Thank you Sam sir.
Can you please tell me the approximate cost of GTO1202D Sub and GTO 301.1 amp??
By the way how can i connect a USB Pen drive or a IPOD to my Pioneer DEH6950IB??
The manual tells that it needs some interface cables, but i am not able to find those. Where can i get it from? What might be the approximate cost??
Thanks in advance,
Vijay
vijay_k is offline   Reply With Quote
Old 8th June 2007, 12:44   #619
navin's Avatar
Thanked: 4,286 Times
Originally Posted by vijay_k View Post
Thank you Sam sir.
About 20K for the set (along with a good box).
Bob.
navin is online now   Reply With Quote
Old 8th June 2007, 12:56   #620
Thanked: 11 Times
there are two options to connect ipod to headunit.
1 - Get a pioneer cable for 1k. Cable will have 3.5 jack and it will connect to hu via aux in port. You will have to change songs from ipod and will have to charge ipod from car charger.
2 - get a pioneer ipod adapter for 5k. In this adapter you can change songs directly from headunit and ipod will charge with same cable.
Mugen_Power is offline   Reply With Quote
Old 8th June 2007, 14:16   #621
austere_sly's Avatar
Thanked: 9 Times
Methods are same which I was going to write, but I will have to differ on price front.
1 - 3.5 mm jack's Aux In cable comes for 30 rs. Even if you go for branded one, max it should be is Rs 100.
2 - CD-I200 cable which will be used as interface cable for ipod will cost $30 at this site.
Pioneer Electronics - Sound. Vision. Soul
Getting this one India could be Rs 200 above or below $ 30.
austere_sly is offline   Reply With Quote
Old 8th June 2007, 14:17   #622
Thanked: 294 Times
for IPOD Mugen Ji has given the two possible ways .......I would prefer the later one with which one can control from the HU itself....
for the USB pendrive you need a adapter to connect it to the HU and it is something like this......CD-UB100
Old 10th June 2007, 01:56   #623
Thanked: 19 Times
Thanks a lot for the replies guys.
I have one more question for all ICE gurus...
What is the difference between a single voice coil and a dual voice coil in a sub woofer?
Is a dual voice coil sub woofer as good has having two single voice coil sub woofers?
What are the main points to be considered before selecting a good sub woofer?
Thanks in advance,
Vijay
Old 10th June 2007, 02:31   #624
Thanked: 11 Times
All the basic information you need in in this thread. ( Post #2,3,4 )
Old 10th June 2007, 19:39   #625
I am gonna buy a Swift Zxi.
I have checked this thread till this page.
I am a bit confused as to what config should I go for?
I have kept aside 20k for ICE.I basically listen to a mix of songs, but am more of a hard rock & hip hop & RnB guy.I plan to limit the speakers to the doors only.
Also one more thing,I have a 8GB memory stick and a N91 but NO IPOD,so in this case which player would be best for me?
So could all the gurus please advice as to which HU + speaker config would suit my needs.
Also one question out of why is SONY xPLOD not preferred,and I see pioneer being a clear choice with most of the guys out here?Am not a fanboy of sony,but asking this just out of curiosity.
Thanks.
--eminemence.
eminemence is offline   Reply With Quote
Old 10th June 2007, 23:03   #626
Sam Kapasi's Avatar
Thanked: 1,473 Times
hello eminememeiniemce!!
And welcome to this naughty corner of TBHP.
Yes we are guilty of not recommending sony HUs. Not that they are bad, but the general opinion is that Pioneer, Clarion, Blaupunkt, JVC, Kenwood make better HUs.
For you I would recommend the following
1) A nice HU with an Auxilliary input (for your mobile)
2) A 4 channel amplifier
3) a pair of 6" component speakers
4) a Pair of 6" coaxial speakers.
You'll have money left over to take someone special out. But that will be another story.
Old 10th June 2007, 23:22   #627
Any particular models for the HU,amplifiers and speakers in mind(I would then directly ask the dealer directly if he has them else bye bye).
For that there is already a monthly allocation done.
Thanks for the reply.
--eminemence[It's not thaaaaaaaaaaaat lengthy and confusing ].
Old 11th June 2007, 09:59   #628
navin's Avatar
HU: Pio, Blau, Clarion, Kenwood and JVC. (Alpine might be outside the budget) at 6K. If you ask me for model numbers you'll get all wrong information.
Amp: Blau GT4 Special (recomended by B&T) or Pio 6200 (a fav here) at 7K
Speakers: 7K for 2 pairs of 6" coax. I would recomend JBL's CS series (Sam cannot recommend JBL as he represents them but they are good speakers) or Blau's THc series. The general verdict here is that Pioneer is bettered by JBL and Blau (but I would still give them a careful listen) and Sony should be avoided.
Old 11th June 2007, 16:39   #629
ebmrajesh's Avatar
Thanked: 26 Times
Default 6950 Vs 7950 - iPOD support - feature difference??
Can someone pls give me the difference between these two features in [COLOR=#868686]DEH-P6950IB and DEH-P7950UB Pioneer HUs[/COLOR] ..
iPOD direct control (in 6950) Vs
iPod® direct control with CD-IU50 (in 7950)
And whats any approximates costs of these two models?
Old 11th June 2007, 17:37   #630
Thanks navin, for the specifics.
Am now gonna go for the hunting...
--eminemence.
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
