Old 29th July 2006, 13:16   #61
binz's Avatar
Thanked: 412 Times
Thanks! Is the config i posted decent enough?(note it HAS to be all pio except for the amp)Could you gurus please suggest what kind of amp i would need to power the whole thing.Also i want the sub to fit in the rear parcel tray,will a 10" go in??
Originally Posted by speedzak
And one more word; All the people who start off with a fake will mature to better stuff one day. We expect the same for you Mr. Binz!!!
So go on!!!!
Yea!!Lemme start earning first!
binz
Old 29th July 2006, 19:08   #62
binz's Avatar
Thanked: 412 Times
Geez guys!What would it take to get sum suggestions??
Old 29th July 2006, 19:48   #63
jkdas's Avatar
Thanked: 1,436 Times
for teh baleno? 10 inch IB install should do fine. You may need to seal the boot efficiently. May need some cutting too for the tray.
Get a Pio amp. A mono block if you can afford or a good 4 channel to run teh frnt and teh sub in bridged mode.
Old 29th July 2006, 20:16   #64
binz's Avatar
Thanked: 412 Times
NOooooooo....read the posts below.Its for the swift we booked 3 days bak.
Old 29th July 2006, 20:21   #65
jkdas's Avatar
emm, sorry dude.
YOu want a IB install? or a boxed sub? I use a 10inch JBL sub (GTO1000B) fed by a Blau amp. I would suggest the same as its easy to setup and sound good.
If you want jsut one amp, I would suggest Pio 6150. Use 2 channels for frnt speaker and teh other two in bridged mode for teh sub. Also, if you could see my garage pix, you will see that my Pio amp is fixed to the back of the rear seat.
Old 29th July 2006, 20:58   #66
binz's Avatar
Thanked: 412 Times
emm, sorry dude.
Well....i want everythingbut unfortunately i cant afford em!
The current plans were to get 6x9 coax at the back,6"comps at the front and have a 10"sub on the parcel tray.want to put the sub here coz we need the boot space.Lastly wanted to go in for a fake alpine amp to power the sub and the rear while the front would run off the hu(just temporary till i can afford proper amps).
Old 31st July 2006, 00:34   #67
redarrow's Avatar
Talking
Hey Guyzzz Plzz Suggest Me A Good And Reliable Audio Setup For Around 15 To 20k And Good Shops In Pune !!I WILL GET MY BRAND NEW SWIFT IN 2 DAYS
redarrow is offline   Reply With Quote
Old 31st July 2006, 09:19   #68
cooldude1988765's Avatar
Thanked: 108 Times
Hi my cousin is buying a new swift and needs help for his audio install.
Budget 20K
Hu has been decided pio 6850 for 8.5k
please help on the speakers.
He plans to add a sub at a later stage ...
cooldude1988765 is offline   Reply With Quote
Old 31st July 2006, 11:47   #69
navin's Avatar
Thanked: 4,284 Times
11.5K (20K less 8.5K) for 4 speakers is a good budget.
He should hear Infinity, Boston, Hertz, Blaupunkt's Velocity, Alpine (R series) etc. and decide what suits him best.
6" components in the front mated to 6" coax in the rear would be my bet. The components would be about 7K and the coax about 4K.
Old 31st July 2006, 18:45   #70
Thanked: 108 Times
navin sir can you give me the model nubers and which cable to use ??
Is there a better HU for that kind of budget ??
Old 1st August 2006, 11:22   #71
navin's Avatar
cooldude,
a) I am horribly bad at model numbers or prices
b) I'd implore you to listen to atleast 3 brands before making up your mind
c) the Pio Hu is not a bad HU just make sure you are getting it with bill and warranty there is a lot of grey market stuff floating around. other good HUs are from Alpine, Clarion, and am told that even Sony, Kenwood and JVC are making decent units (I have not heard much excpet for the Alpines).
Old 1st August 2006, 11:30   #72
Thanked: 294 Times
Originally Posted by cooldude1988765
Budget 20K Hu has been decided pio 6850 for 8.5k
please help on the speakers.He plans to add a sub at a later stage ...
Cool dude get the 6850 it is a good hu with furture expansions options. Like Navin ji said listen to atlest 3 set of speakers before installing. Go for componets in the front with tweeter near the a-pillar base and in the rear u can go for co-ax speakers this all will be done in less than 20k.
OT-> this is the first time some one is completing his ICE setup with less than assigned buget (if he plans to add a sub later and drive speakers with the hu).....lol
Old 1st August 2006, 11:39   #73
binz's Avatar
Thanked: 412 Times
Ya ya Im still a kid....nothing wrong in experimenting!When i have a big budget,ill come to you guys for advice.
binz
Old 1st August 2006, 12:05   #74
Thanked: 294 Times
Binz i was not talking about u sorry man if it hurted u.....
any ways u are talking about IB with a 10 inches in a swift. If i was u i would never do that. because in swift there is a little gap between the rear seat and the boot door and it will be a very difficult task to seal the boot from the cabin. Go for a enclousre setup it will yeild u best results....this will only add a enclousre to ur budget only.....
Old 8th August 2006, 17:30   #75
Hi I jus bought a swift and need help for the audio install.
My budget is 20k
I have two setups in my mind to be completed under 20
1. a HU, front component speakers and rear coax
2. a HU, front component speakers, sub and an amp
which setup would you guys recommend and please suggest the models also, although I am more inclined towards the second option...
I like listening to rock and techno and i like listening loud
I do have an option of upgrading the system later
Kaustuv is offline   Reply With Quote
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
