Old 13th August 2007, 21:50   #886
I have the following setup in my swift
pioneer hu 4900 with ipod cable
JBL gto 607c for fronts
JBL 6" coaxials for rear doors CS2165
JBL 60.4 4 channel amp
JBL 12" CS1204T bass tube in the boot
Now I noticed that in the back seat I am getting mostly the boom sound, not the clear music as in the front, what can I do to correct it?? and also suggest me good amp settings. audio GURUs help me on this.
gmano is offline   Reply With Quote
Old 13th August 2007, 23:59   #887
Thanked: 294 Times
what is the EQ setting in the HU.
Old 14th August 2007, 06:02   #888
I tried changing the EQ settings in the HU but the problem remains same.
Old 14th August 2007, 09:21   #889
Sam Kapasi's Avatar
Thanked: 1,473 Times
You have a 4 channel amplifier and 4 speakers and a subwoofer.
  • Make sure that the rear speakers and subwofer are not attached to the same channel (which has LPF on)
  • The right way to connect this is to connect the front components to the front channel of the amplifier (HPF on at 80hz) and Subwoofer connected to rear channel (LPF on at 80hz)
  • Rear speakers will be connected to the rear channel of the HU. However you will find that due to the limitations of the amp on the HU, the rear may be soft. You can:
  • either buy a monoblock amplifier for the subwoofer and use the 60.4 to drive the front components and rear coaxials or
  • lower the gains on the CS60.4, both on the front compos and the rear subwoofer. This will cause the rear coax to sound louder BUT
  • do not expect the rear coaxials to sound as clear as the front components. The speakers are different, the positioning in the car is different
Old 14th August 2007, 11:35   #890
Awaiting Email Confirmation
Hi! Thank you all for your sugestions.
After going through different options, suggestions, I've decided to go for the following setup which is giving me pleasure of music in my car. You still have option to correct me if I'm going out technically.
I've also noted the prices in Bangalore (grey). Please let me know if I'm carried away (by price) by the shop people.
HU: Pioneer 6950-Rs.7,000/-
fron speaker: Infinity-6620 component system (as suggested by DerAlte)-Rs.6,000/-
Rear Speaker: JBL-T595 (9x6, 150 RMS)-Cost-Rs.7,500/-
Amp: JBL 60.4 -Rs.5,000/-
Infinity 6022i (6 1/2' co-ax) was quoted Rs.4,200/-
netpark is offline   Reply With Quote
Old 14th August 2007, 13:15   #891
navin's Avatar
Thanked: 4,282 Times
Originally Posted by netpark View Post
Hi!. I'm new to this forum and I need your advice for my car (swift)
Here are my choice and please guide me.
HU: Pioneed 6950
fron speaker: Infinity-6622i (6 1/2 inch)
Amp: JBL 60.2 (2 channel for rear speakers)
Please advice me if this configuration is good or Bad??????
For a few Rs. more you could have got the 6020 instead of the 6022 and the 60.4 instead of the 60.2. Net additional outflow would be about 8K but hainvg components and powering all 4 speakers would push the performance up a couple of notches.
Old 14th August 2007, 15:38   #892
DerAlte's Avatar
Thanked: 2,879 Times
The grey prices seem OK.
Navin, I think @netpark is referring to 6020 that I had suggested, the '6620' must be a typo.
But now since he wants to put in T595 we have to suggest the JBL 75.4 or some more powerful amp for him. Also, maybe the T696 as Sam suggested, instead of the T595. Besht! Sam-bhai, T696 kitte mein milta?
@netpark, where did you get the grey quote from?
Old 14th August 2007, 22:18   #893
Thanks Sam sir. I will check the connections morrow.
If I want to buy a mono block amp, which one is suited for my setup? or can I buy a 2 channel amp and connect it to the sub?
are the rear coaxials good (what I am using) or I need to change them also?
Old 15th August 2007, 02:02   #894
Eddy's Avatar
Thanked: 5,069 Times
Default Basic ICE for Swift
Basic Information
Car: Swift VDI
Budget: 10 - 12 K.
Self Driven
Music preference: Normal FM songs, old hindi songs, soft rock. Loud music only once in a while when favorite songs play
NOT ready to sacrifice my boot space/modify door panels
Particulars
* I am a complete novice when it comes to ICE and the technicalities that are associated with it. All I need is a system that plays my kind of music and fits into my budget.
* I am not into heavy metal, rock kinda music so I assume even a good basic system will do.
* Important: I do not want to compromise on the boot space. Also, is it possible to fit the rear speakers anywhere except a tray where they are generally fit ? The tray (IMO) would contribute to rattles which are anyways associated with the swift. So can they be fitted in the door or somewhere ?
* Do I need tweeters ?
PS: I know that you guys probably discuss more "happening" systems but do give in your suggestions
PS: I did go through the Basic ICE systems in various budgets wala thread but require some specific answers here.
Thanks in advance
Eddy is offline   Reply With Quote
Old 15th August 2007, 11:45   #895
DerAlte's Avatar
Originally Posted by Eddy View Post
Basic Information
Car: Swift VDI
Budget: 10 - 12 K.
@Eddy (Bauer?): No, if you read through the posts, you will realize that there is no conceited "happening" systems preference here. Anything goes, as long as the owner is happy, with Appy, narangy or lappy, desi or videshi, or without!
Tweeters: yes, they enhance the stereo image and the listening pleasure (like salt to food). They don't have to go chilla-chilla - as long as they make Asha Bhonsle sound like her and not Usha Uthup or Kiri Te Kanawa. Decent component speakers are enough, not Pio TS20.
For your budget, you can get
* Pioneer, JVC or Blaupunkt HU (app 5K)
* 6.5" components in front door stock location: Blau GTc 172HP or JBL CS2165C (3.5-4K)
* 6.5" coax in rear door stock location: Blau GTX173HP or JBL CS2165 (2.5K)
OR, if you want some more bass
* 6x9 oval 3ways on plank/tray: Blau GTx693HP or JBL CS3196 (3.5K) (The tray won't rattle if fixed / damped properly; one can always use a 1" MDF plank)
Listen to some setups, whether in friends' cars or dealers, before you make up your mind. Look for deals - but don't buy without listening. Get it installed by a good installer, not someone who chops of connectors, twists wires and puts electrical tape.
Old 15th August 2007, 12:04   #896
navin's Avatar
nicely done old man! BTW Eddy, the plan will cost you about 1K as well but it is well worth it.
Old 15th August 2007, 13:49   #897
Eddy's Avatar
@ Deralite: Thanks for the advice.
-- The prices you have mentioned are with or without B/W ?
-- Which tweeters do you suggest ?
-- Any particular model of HU that I should consider ? Do they come with an I-Pod / MP3 player input ?
@Navin
Yep, an increase of 1 K is fine for a good system
Also, how much does installation etc cost ?
Old 15th August 2007, 15:23   #898
Sam Kapasi's Avatar
You could buy the CS300.1, this will be fine. You can also buy a small 2 channel amp, but this will not be enough for the woofer.
Yes the rear coax are fine, you can leave them be.
Old 15th August 2007, 19:45   #899
DerAlte's Avatar
* Yes, with B&W for Blaupunkt and JBL, maybe JVC, not Pioneer
* The 6.5" component speakers (Blau/JBL) include the tweeter, you won't have to buy them separately
* HU (MP3 players other than iPod, and iPod if no USB available, connect via headphone jack to the AUX line)
- Pioneer 4950 or 5950 (iPod & USB adapter extra)
- JVC KD-G435/436/535 (iPod separate cable, no USB, front AUX jack)
- Blaupunkt Maui MP36 / Mumbai MP26 / San Diego MP27 (iPod separate cable, no USB, rear AUX connector)
Old 16th August 2007, 09:59   #900
Sir, Thanks for your advice. Can you tell what will be the cost of CS 300.1 ?
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
Pimping My Ride Swift ICE Upgrade vrrraju In-Car Entertainment 34 28th January 2009 15:13
ICE Upgrade-Swift JBL'ed thirst4torque In-Car Entertainment 4 13th March 2008 12:21
swift ICE upgrade - come share my joy :) ibcool In-Car Entertainment 20 18th October 2007 13:10
