Old 24th July 2013, 06:16   #1
Thanked: 21 Times
Post Line Output Converter (LOC) and EQ Question
I have a question for the guru's here.! I have an NVX EQ7 LINK
I noticed it has an Speaker level input so i was wondering instead of using a LOC to add an amp, could i just by-pass that step and run it directly through a AMP? the car is for the ANHC FYI.
Diamond_dawg is offline   Reply With Quote
Old 24th July 2013, 10:35   #2
DerAlte's Avatar
Thanked: 2,879 Times
Default re: Line Output Converter (LOC) and EQ Question
Originally Posted by Diamond_dawg View Post
... NVX EQ7 ... Speaker level input ... instead of using a LOC ... run it directly through a AMP? ...
I presume you mean you will connect the Equalizer to the Speaker Out of the HU, and connect the Front / Rear / Sub Out RCA of the Equalizer to the Amp. If so - yes, that is how it should be connected.
DerAlte is offline   (1) Thanks Reply With Quote
Old 25th July 2013, 00:20   #3
Thanked: 21 Times
Default Re: Line Output Converter (LOC) and EQ Question
Thanks for the reply DerAlte.
Another question i have is how are EQ considered these days? reading on an old thread by LBM (LINK) i was wondering do they make a difference these with stock and non-stock HU's.
Old 25th July 2013, 11:41   #4
DerAlte's Avatar
... how are EQ considered these days? ... do they make a difference these with stock and non-stock HU's. ...
The modern EQs using DSPs work wonders on the output of stock / OE HUs. Almost all stock HUs give an internal bias to match OE speakers. If one replaces OE speakers with aftermarket ones (which are far better than OE speakers), the bias will give an unnatural output. Many EQs first remove this bias before applying user preferred sound profile.
If you don't want to replace neither the OE HU nor OE speakers, then an external amplifier will give some improvement. An EQ wouldn't have much leeway to play with since the constraint would be the capability of the OE speakers.
With aftermarket HUs, the objective with an EQ is to tailor the sound to personal preference.
Removing a Catalytic Converter (Cat Con) - Do you guys think its worth it? ananthkamath Technical Stuff 111 13th June 2017 09:51
Amps with high-level inputs VS Line output converters TNAWAYAJ In-Car Entertainment 12 8th November 2013 12:08
Wagon R: Noise from Catalytic converter? EDIT: Cat Con is GUILTY. bblost Technical Stuff 26 12th July 2012 15:08
Voltage converter for Belkin wireless router. Please advise! andescondor Gadgets, Computers & Software 16 30th November 2009 12:41
Which 3GP converter? Shan2nu Gadgets, Computers & Software 6 19th November 2008 21:33
