Old 6th June 2006, 22:59   #1
kooldude's Avatar
Default loss in bass
hi guys
i recently installed a pio 4850 hu and am happy with the sound it is good but i feel a loss in bass because when i used to run it in my cassette player it was way much. MY speakers are jbl cs 496 rear and gto 506 front.
Audio gurus help
kooldude is offline   Reply With Quote
Old 6th June 2006, 23:13   #2
Sam Kapasi's Avatar
Thanked: 1,490 Times
From what i gather, you feel you had more bass with your earlier casette based HU and after putting your 4850 you feel that you have low bass.
This sounds a little strange. I would put it down to a bad installation.
To be sure, the rear speakers are wired out of phase. Here's a simple test:-
Reverse the wires on ONE speaker only (Connect the + into the - and vice versa)
Remember on ONE speaker, left or right. And then sit and listen to your music in the car again. If the bass is back, your speakers were out of phase.
Old 6th June 2006, 23:29   #3
Bass&Trouble's Avatar
Thanked: 74 Times
And if the sound does improve, you need to clobber your installer over the head for...
1. getting such a simple thing wrong.
2. not being able to realize that it was wrong after the install was done. I assume he must have atleast heard it once after he was through.
Old 6th June 2006, 23:43   #4
amit_sound's Avatar
Thats called a expert suggestion!!!! Simple....
amit_sound is offline   Reply With Quote
Old 7th June 2006, 10:13   #5
Rehaan's Avatar
Thanked: 25,081 Times
Kooldude,
If it isnt a problem with the phase, how about just turning up the Bass setting on your HU ?
cya
R
Old 7th June 2006, 10:17   #6
Thanked: 295 Times
I was thinking before but hate to write this head also has a LPF . It might e switched on also................
Old 7th June 2006, 10:39   #7
jkdas's Avatar
Thanked: 1,437 Times
good point low_bass_makker
Old 7th June 2006, 12:17   #8
Sam Kapasi's Avatar
Yeah LBM, Thats a good point. Ok so where is kooldude? We're waiting to hear what happened.
Old 22nd June 2006, 17:56   #9
kooldude's Avatar
sam i tried this out but it did not work
need help again guys
Old 22nd June 2006, 18:01   #10
Thanked: 17 Times
Tried switching off the HPF, LPF etc...?
Check with different EQ settings.
Turned LOUD on?
See if all your speakers are working. Did your installer cut any speaker wires or damage any speakers accidenatlly?
Old 22nd June 2006, 18:08   #11
iraghava's Avatar
Thanked: 156 Times
Read the thread for more suggestions already given by LBM, Speedzak & Rehaan
Originally Posted by Rehaan
Kooldude,
cya
R
Turned LOUD on?
Old 22nd June 2006, 18:12   #12
kooldude's Avatar
me and rehaan both tried everything out but nothing was in my favour
Old 22nd June 2006, 22:06   #13
Thanked: 295 Times
try running this track
http://rapidshare.de/files/23800309/..._Test.wma.html
in this track first the sound will be of in phase u should hear bass and later out of phase no bass should be there. Play it and tell what happes....
Old 23rd June 2006, 13:43   #14
Rehaan's Avatar
Hey guys,
As kooldude says, we had stopped by on our way back from the alibaug meet to see if we could figure out what was causing the "loss in bass" problem.
There was no LPF on his HU, just a HPF, which was off.
His head unit had +/- settings for freqs like 40Hz, 60Hz, 85Hz, 120Hz, BUT the weird thing was that if you increased one to +3 all would increase to +3 so dont know if that was just some pioneer tactic, or i was doing somethign wrong.
Personally i felt that the bass was sufficient for a HU + 4spkr setup, but i guess kooldude feels it is less since he has moved from an alpine HU to a pioneer which might not have the same punch and low down refinement as the alpine ??
cya
R
Old 23rd June 2006, 13:55   #15
jkdas's Avatar
If alls fine, then, maybe he needs to check out similar setups with Pio and Alpine HU. There would be difference in teh way a HU delivers andit varies with different company HU and models.
Ford still in loss, to slash production, shutter plants junkishya The International Automotive Scene 3 2nd November 2012 00:12
Loss in power at low RPM Sri_009 Technical Stuff 11 3rd June 2010 15:55
Newer cars: Value for money or loss thereof? Ram The Indian Car Scene 17 3rd March 2008 14:28
Headphones & Hearing Loss navin In-Car Entertainment 5 12th September 2006 11:16
Richard Burns - No More ! Sad Loss Badcheetah Int'l Motorsport 11 2nd December 2005 14:09
