Old 5th July 2006, 12:10   #136
Thanked: 17 Times
Originally Posted by kb100
Sure will be nice to see Zuhiemi's knowledge getting E-X-P-A-N-D-E-D ..
He's started referring Hertz these days. That's something I never expected from him in this life. Yes, recommending something other than Alpines!!!
Old 5th July 2006, 16:47   #137
Thanked: 17 Times
Guyz! After Civic is launched, I'm holding my hands tight.
Seems to be rock solid car with less road noise etc.. and seems it has got plenty of horses and is well suited for high end ICE.
Will go for a test drive tomorrow.
It comes with in dash 6cd changer which can read MP3/WMA etc. I think it's from Alpine and a PXA-H701 processor and a DVA 5210 can be added for better overall sound and some visual excitement too. And the speaker fitment positions are well placed too I think (Front & rear doors). Maybe 2 way 6" components can be stuck in front and a decent co-axial set for the rear!
Ok I'm assuming a lot of things after a visit to their website. So will get more pukka info by tomorrow or tonight.
Old 5th July 2006, 17:45   #138
Thanked: 294 Times
the pxa can be attached to any stereo on this earth which preferably has got line out also but u have to buy the rux in order to control the pxa. with this combination one can keep his company HU and can further expand as one like........4-way system , 5.1 system , front and rear and sub system. any thing u think is possible with a pxa......
Old 5th July 2006, 19:03   #139
Thanked: 17 Times
Exactly LBM, When I meant it can be hooked to PXA-H701, it's without the RUX controller. If the HU is from Alpine then PXA can be controlled from the HU itself.
Old 6th July 2006, 18:05   #140
Thanked: 17 Times
Gurus!!! My system is going to get some blessings from GUNBIRji & JBji soon. And I've kept my options open. And I'm seriously thinking of getting 2 12" Subs to replace my 12" Bandpass Sub. And I'm studying about Plexiglass installation.
Now, Please inform me: Which box will be best for a 2 SUB setup? It should fit in my ALTO's boot. Does going for a sealed setup require big size boxes? Or is it ported which has to be bigger? As I like some bit of SPL too, what would you recommend??
Old 6th July 2006, 18:17   #141
Thanked: 294 Times
first of all which sub r u going to use.......... Every thing will be calculated from that. And the sealed one are smaller than the ported one and the bandpass are bigger than the ported one. U will achive higher spl in a ported when compared with a sealed one but there will be some loss of sq on that. ....
Old 6th July 2006, 18:29   #142
Thanked: 17 Times
Yes sir! But how much loss?
Is it really a considerable loss?
Which one will produce tight, punchy bass?
I'm planning to use Hertz ES300D 12" Subwoofers. Or Alpine type R 12".
Old 6th July 2006, 18:42   #143
Thanked: 294 Times
loss will be like that the woofer would not be able to play below the tunned freq for eg if we say the box is tunned at 35 hz the enclousre will not be able to produce 35 hz and below as to produce these freq the sub will have to move a lot to achive them and thats why there will be a loss of SQ there..
but if u use a ported u will ge atleast 6db gain in the output than the sealed one I have tried and test the both the boxes and I am sure about that......
naturally the ported will be giving u a punchy bass.......
Old 6th July 2006, 19:07   #144
Thanked: 294 Times
Both the subs are different in there audibale response. here are some differences.
Power handling -> alpine is 1500/500 and hertz is 700/350.
Xmax -> alpine is 18.2 mm and the hertz is 14.5 mm
sealed box requirement -> alpine is .57-1 cuft. and hertz is 1cuft.
ported box requirment -> alpine is .75 - 2 cuft and hertz is 1.27 cuft.
senstivitiy-> alpine is 85 db and the hetrz is 97db
rest gunbir will tell the diff more clearly as he has listened to both of them.....
But I personnaly feel it u can adjust a box of nearly 3.5 - 4 cuft. go for the alpine sub........
Old 6th July 2006, 19:54   #145
Thanked: 17 Times
Should I fit in capacitors? Is it really necessary for this 2 sub setup?
Old 6th July 2006, 21:08   #146
rsjaurr's Avatar
Thanked: 27 Times
LBM,i think u meant "naturally the ported will not be giving u a punchy bass."
rsjaurr is offline   Reply With Quote
Old 6th July 2006, 21:39   #147
Thanked: 294 Times
Ya rs-jar the ported enclousre will be giving a punch bass.........here is a small writeup on enclousre from pioneer cataloge.......
Old 6th July 2006, 23:02   #148
navin's Avatar
Thanked: 4,286 Times
No .
navin is online now   Reply With Quote
Old 7th July 2006, 01:02   #149
Thanked: 17 Times
Originally Posted by navin
No .
My installer was forcing me so much! He warned me about fading lights etc.. He even told me the AC will be affected too!!! Yes, that is if I dont fix in a capacitor with this 2 amp, 2 sub setup. Was he just making business?
I know this happens a lot with installers. They try and convince a person to buy things which is not much needed. Am I right?
I'm also planning to change my cabling. I'll be putting in connection audison cables from battery to speakers all the way!
My Sub is currently connected using Monster cable (From amp to sub) Should I change those too? or simply add another parallel line from the amp to 2nd sub?
Old 7th July 2006, 01:11   #150
kb100's Avatar
CHANGE CHANGE CHANGE... Change everything... cables... wires... sub... speakers... HU... and then maybe.. house... wife... (... Like I might have to.... lol!)
one thing DO NOT let anyone CHANGE the fact that you DO NOT NEED a cap..
kb100 is offline   Reply With Quote
Cleaning and Maintaining Head Units souravbasu In-Car Entertainment 43 13th November 2009 23:21
Alpine head units AV DVD mxx In-Car Entertainment 13 20th October 2008 15:59
The Quick and Dirty on Car Head units & Amps navin In-Car Entertainment 51 21st March 2007 09:15
MP3 flash card compatible head units? Why not? navin In-Car Entertainment 32 19th October 2005 00:36
Let's tweak PIONEER Head Units zzzehar In-Car Entertainment 54 26th September 2005 09:48
