Old 30th November 2013, 19:58   #1
Default Nissan Micra - ICE upgrade
Hello Gurus,
I am about to receive the delivery of the Micra CVT in a couple of weeks.
I wanted to upgrade the ICE and have a few doubts:
1) is it a good idea to upgrade all the 4 speakers within their stock locations, add an amplifier and a sub-woofer, but continue with the stock head unit?
2) if I go ahead and change the head unit, will I still be able use the steering mounted controls?
3) if I upgrade the ICE, will this void any kind of warranty?
4) Considering a budget of 40k to 50k, what kind of set up do you recommend?
I genres that I enjoy range from EDM, to ghazals, to popular Bollywood, to Pop, to indian classical both instrumental and vocal.
Automoti-vated is offline   (1) Thanks Reply With Quote
Old 30th November 2013, 22:05   #2
IshaanIan's Avatar
Thanked: 3,394 Times
Default re: Nissan Micra - ICE upgrade
Firstly let me congratulate you on the purchase of an automatic Micra. The Micra was already the top city runabout and now with the addition of a CVT box, it's even more so.
I am no ICE guru myself and I believe it will take me a good decade before I could hope to be one.
Anyway, I stumbled upon the thread and I do hope I can atleast steer you in the right path:
I do not believe you will need to change your Head Unit as long as you buy a decent amp. If you do however change the Head Unit, you can get adapters to make the steering mounted controls work easy job.
Now your budget is pretty good so you can look at brands like Polk, Hertz, Focal or Rainbow for the speakers and Rockford Fosgate or JL audio subwoofers. If you decide not to change the Head Unit, then you will also have enough money to buy a good 4 channel amp plus a decent monoblock to drive the sub individually
Remember not to compromise on wiring, damping where needed and quality of installation and you ought to be set.
Cheers and goodluck
IshaanIan is offline   (2) Thanks Reply With Quote
Old 1st December 2013, 01:44   #3
ramie2400's Avatar
Thanked: 58 Times
Yes you can upgrade the hu with a dash kit and steering integration module is availabe which works goods,the budget your considering is quite low to accomodate a desent sq setup.For your genre of music you will need to damp the car as micra will rattle bad after install.
If ICE configured correctly will sound very good in micra.
Ramie
ramie2400 is offline   (2) Thanks Reply With Quote
Old 1st December 2013, 09:50   #4
devilwearsprada's Avatar
Thanked: 919 Times
The Micra is a pretty good car. Congratulations of your purchase.
For your car, since you listen to multi genres which also include EDM and Bollywood and Rock. Your car needs to have Damping.
What I would suggest would be to get a good :
  1. 4 Channel Amplifier - Digital Designs 4 channel priced around 10k.
  2. A good Subwoofer- A Rainbow or a Infinity would run good.
  3. A pair of components for the front- Rainbow EL Components or Bull Components. The Tweeter location is on the top left panel and would sufficiently fit in a Rainbow tweeter
  4. A pair of coaxials for rear - Could use a pair of Rainbow Co-axials for rear.
Why I suggested this setup is because, DD + Rainbow is generally a good pair to start with. Neither too bright or flat. This setup is also used by SIDINDICA for his Punto. Check his long term ownership thread for the same or PM me for the details
This comes to around 43,000 after which you have suitable funds left for Damping and/or wiring[Preferably Scosche or Bull]. You can also contact Motor Concepts Delhi for competitive price checks as they are generally the lowest and the best, IMHO in Delhi.
Last edited by devilwearsprada : 1st December 2013 at 09:53. Reason: Tweeter Point.
devilwearsprada is offline   (2) Thanks Reply With Quote
Old 1st December 2013, 11:06   #5
Thanked: 284 Times
Some specifications on the stock unit would be nice
Some HUs will support steering controls out of the box but some are going to need an adapter. Your installer will probably recommend one if the controls don't work.
Most car dealers will straight away tell you that installing after market ICE will kill the warranty but by not splicing any wires and using the right kind of harness, I think you should be in the safe.
tjacob is offline   (2) Thanks Reply With Quote
Old 1st December 2013, 11:17   #6
ampere's Avatar
Thanked: 9,128 Times
Thats too high a budget. In my opinion you may not need it. May be 20K or so should be good. I would say spend the rest on some good leather seats.
ampere is offline   (3) Thanks Reply With Quote
Old 1st December 2013, 12:26   #7
khoj's Avatar
Thanked: 1,258 Times
See replies in bold within your quoted post.
Hello Gurus,
Almost everyone will advise you to change the stock HU but it is really not necessary unless one is really nuts about the sound.
Yes, just get an adaptor compatible with the HU and the OE interface. Any half decent ICE shop will have this.
No, as long as you do not cut any wire in the OE harness.
O.E. H.U. + hi Lo converter + Amp + front components + sub in a sealed enclosure in 1" MDF.
Get a decent wiring kit, infact there is a Kicker 8 gauge on sale in the classifieds here at a decent price. You could also enquire about flat subs which can be mounted under the front seat.
As to which make to buy, there are multiple choices and the best would be to go down the shop discuss with the seller, audition if possible and then buy. For damping I would recommend Dampmat, this is very good value for money and also Waterguard in lieu of the MDF mounting rings. This guards your speakers against water damage.
Last edited by GTO : 2nd December 2013 at 15:48. Reason: Please do NOT reply within a quote
khoj is offline   (2) Thanks Reply With Quote
Old 1st December 2013, 18:34   #8
DerAlte's Avatar
Thanked: 2,879 Times
... 1) is it a good idea to upgrade all the 4 speakers within their stock locations, add an amplifier and a sub-woofer, but continue with the stock head unit?
4) Considering a budget of 40k to 50k, what kind of set up do you recommend? ...
* The OE HU in Micra CVT is not bad at all sound-wise. It has BT, Aux-in and USB, but is a bit rudimentary interface-wise. BT audio works well. Change the HU if you can't live with the interface, and you want a touchscreen and richer interface. Since this is a standard 2DIN unit, even a dash kit is not required to put in an after-market HU
* If you are changing the HU, it is not difficult to interface with the steering market controls - after-market adapters are available for the same
* Changing the OE speakers is likely to give you most gain at lowest investment. If you are adding an amp & sub, it will enhance the experience
* Warranty will not be void if you are putting in drop-in replacements. Just ensure that the installer doesn't cut / splice wires in the original harness wires
* Damping the doors would be a good idea, especially the boot hatch if you are putting in a sub
DerAlte is offline   (2) Thanks Reply With Quote
Old 21st December 2013, 11:57   #9
Default Re: Nissan Micra - ICE upgrade
Dear IshanIaan, ramie2400, devilwearsprada, tjacob, ampere, khoj & DerAlte,
Thanks a tonne for your replies & inputs!
Am new to team-bhp forum, and pleasantly surprised (and a bit overwhelmed!) by the wishes as well as the specific & helpful responses!
Got the delivery of my car on the 12th Dec and been excited owing my first car!
The stock music system is decent, at best!
I quite like the head unit, though the speakers manage to make even good music sound a bit hollow!
From all your responses, here is what tentatively has formed as a plan in my mind
Stage I
Retain the head unit
Replace the front speakers with good components in stock location
Replace the rear speakers with good co-axials or components in stock location
Put in a good amplifier for all 4 speakers
Replace the stock wiring with good wiring
& Check output.
Stage II
Install a good sub-woofer
Install a good amp for the sub
& Check output
Stage III
Incase it still does not feel up to the mark, consider replacing the head unit
What is your opinion about this plan?
Also, i reside in Mumbai, could you pls recommed a reliable & expert installer, who i could go to, to explore my options?
Old 21st December 2013, 18:45   #10
khoj's Avatar
The plan sounds good. As for an expert installer, I would recommend Ramie (ramie2400). He should be able to help you out, he is well known in this line of business.
Made in India Nissan Micra global recall: 9,600 Micra compact cars with faulty sensor rkg The Indian Car Scene 1 25th February 2012 09:22
Heart vs. Head - Nissan Micra or Maruti Ritz? UPDATE: Booked the Micra W.A.G.7 Hatchbacks 38 29th December 2010 20:28
Pics : Met a Nissan Micra / March today Stratos Super-Cars & Imports in India 55 22nd August 2009 02:40
Nissan Micra head for India....... The Hurricane The Indian Car Scene 1 26th May 2008 06:52
150,000 for Nissan Micra jkdas The International Automotive Scene 9 26th November 2005 23:40
