Old 5th October 2006, 15:44   #61
Thanked: 295 Times
Originally Posted by Bass&Trouble
LBM, where do you source your images from?
I mean this quality, and what do you use to size them so accurately close to one another? Is it that Imageshack re-sizing option? If so, what size is most appropriate for posting images on forums like ours?
sir took them from crutchfield
http://www.crutchfield.com/S-kDqeHTB...&display=L#Tab
I did not mentioned the source as these are porducts pics not a copyright thing...
Old 5th October 2006, 15:49   #62
panky12345's Avatar
Thanked: 151 Times
Or one whole dual/ quad voice coil sub.
Dual 2 ohms! am i right? to present a 4 ohm load in bridged mode. though it can be wired to present a 1 ohm load, but i think thats the minimum for 504 (4 ohms).
Old 5th October 2006, 15:57   #63
navin's Avatar
Thanked: 4,351 Times
no I think B&T meant 2 4ohm coils. bridge the 504 to 2 channels and connect each bridged channel to one coil of a single sub. electrically these are 2 different subs but mechanically one sub.
the other choice B&T mentioned is a quad coiled sub. these are rare. in thise case each channel of the 504 will power one coil of the sub. or you can bridge the 504 and series the coils in pairs to make it a dual coiled sub etc... confusing?
though so that is why i did not mention these options. B&T has taken up my OLD mantle i.e baffling the world. I have taken up Sam OLD mantle.
Old 5th October 2006, 16:15   #64
Bass&Trouble's Avatar
Thanked: 74 Times
I deliberately left it at that because I knew you would take care of the baffling part, and do it well!
Old 5th October 2006, 16:38   #65
Thanked: 295 Times
In restricted spaces (not to be confused with small spaces), one can also use a shallow subwoofer.
this is a shallow sub .......
http://www.illusionaudio.com/docs/luccent_subs.htm
with this type of box...
Old 5th October 2006, 23:24   #66
rsjaurr's Avatar
Thanked: 27 Times
You mean helping ICE [may be HOT] "install" in dark with torch.....thook lagake etc stuff ???
rsjaurr is offline   Reply With Quote
Old 6th October 2006, 14:30   #67
navin's Avatar
Sam's OLD Mantle was unbaffling my baffling replies. Sma's got a new Mantle nowdays. WE all know what that is.
Old 6th October 2006, 17:05   #68
Thanked: 26 Times
just a note: the 504 is a 4 channel amp. you can only bridge 2 ch. at a time. so it can power 2 subs, 1 sub and 2 fullrange speakers, or 4 fullrange speakers.
small correction sony 504Z right?.... it can only work in 4/3 channel mode.... means you can only bridge 2 of the channel among 4.... so basically it can power only 1 sub and 2 full range or 4 full ranges!
regards,
ant.
anToNIcHeN is offline   Reply With Quote
Old 7th October 2006, 14:43   #69
Thanked: 74 Times
regards,
ant.
No ant, it has 4 channels, so you can bridge 2-2 chaneels and make it 2 channel. Or you can bridge only 2 channels, use the other 2 in stereo mode and have 3 channels. All possible.
Old 7th October 2006, 14:50   #70
Thanked: 26 Times
Well let me just clarify... are we talking about Sony XM-504Z amplifier right?
B&T are you sure of this?... coz i owned the same model sony amp.... and its rear channels ONLY could be bridged!.. Front channels could only be run in stereo mode.
Old 7th October 2006, 14:54   #71
angelfire's Avatar
Yes....guess ant is right..think only the rear channel can be bridged....atleast thts wats there in the manual....just confirm on that B&t..
angelfire is offline   Reply With Quote
Old 7th October 2006, 15:19   #72
Thanked: 74 Times
Hmm, sorry. You guys seem to be right. Although that's very strange.
However I asked a rather renowned installer and he said it is possible. I'm quite confused.
Old 7th October 2006, 15:27   #73
jkdas's Avatar
Thanked: 1,437 Times
should be...just bridgable for rear ( channel b) and it should have LPF.
If it was brigable on both, then they would have marketed it as 2/3/4
Old 8th October 2006, 19:40   #74
Thanked: 74 Times
Guys, I was dead sure the amp could be bridged on both pairs of channels...and I am right!
It's strange that Sony markets it as a 4/3 channel amplifier, I remembered having bridged both pairs of outputs earlier in some installs. From the circuit I remember that the front and rear sections are pretty much identical, and hence both bridgeable. This is true, since I checked today, they can be bridged and the amp can operate as a 2-ch amp. The only difference between the front and the rear is the absence of a LPF circuit for the front channels. This is not an issue when the head unit can provide a sub out. The fronts can be bridged, the circuit is totally symmetrical.
Tip: For bridging the front channels on the 504, use the same terminals as that on the rear. That is the correct polarity.
Old 8th October 2006, 19:48   #75
angelfire's Avatar
Thanks a lot B&T on that....one more question...the sub out has to be fed to the front channel right????...
How did you come up with your username? haryan Shifting gears 1071 29th April 2017 23:49
Why did you sell your car? gemithomas The Indian Car Scene 72 16th May 2010 22:56
Why did you buy a diesel? dadu The Indian Car Scene 142 10th August 2009 16:08
need your feedback on the setup i have shortlisted tazz_rules In-Car Entertainment 0 2nd November 2008 17:55
Did your dealership tell you about ABS and Airbags during delivery of your car? amit Road Safety 24 10th February 2008 12:44
