Old 8th October 2006, 20:04   #76
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by angelfire
Thanks a lot B&T on that....one more question...the sub out has to be fed to the front channel right????...
The sub out from the head unit is to be connected to the left channel input of both the front and the rear channels of the amplifier.
Old 9th October 2006, 11:30   #77
navin's Avatar
Thanked: 4,286 Times
hey even if the amp cant be bridged build a bridge ckt only requires one opamp.
navin is online now   Reply With Quote
Old 9th October 2006, 14:49   #78
Thanked: 26 Times
Originally Posted by Bass&Trouble
Guys, I was dead sure the amp could be bridged on both pairs of channels...and I am right!
It's strange that Sony markets it as a 4/3 channel amplifier, I remembered having bridged both pairs of outputs earlier in some installs. From the circuit I remember that the front and rear sections are pretty much identical, and hence both bridgeable. This is true, since I checked today, they can be bridged and the amp can operate as a 2-ch amp. The only difference between the front and the rear is the absence of a LPF circuit for the front channels. This is not an issue when the head unit can provide a sub out. The fronts can be bridged, the circuit is totally symmetrical.
Tip: For bridging the front channels on the 504, use the same terminals as that on the rear. That is the correct polarity.
B&T from what i remember..... there was no markings on the amp that it could be bridged! (front channel)..... If you have opened the amp and checked then it must be true!.... Yes.... Front channel only has a HPF.... and rear channel has LPF switch!!...
just wondering... why would sony want to market it as 4/3 channel amplifier!!....
anToNIcHeN is offline   Reply With Quote
How did you come up with your username? haryan Shifting gears 1071 29th April 2017 23:49
Why did you sell your car? gemithomas The Indian Car Scene 72 16th May 2010 22:56
Why did you buy a diesel? dadu The Indian Car Scene 142 10th August 2009 16:08
need your feedback on the setup i have shortlisted tazz_rules In-Car Entertainment 0 2nd November 2008 17:55
Did your dealership tell you about ABS and Airbags during delivery of your car? amit Road Safety 24 10th February 2008 12:44
