Old 14th December 2013, 22:06   #1
HimuraKenshin's Avatar
Thanked: 183 Times
Default FiberGlass Sub enclosure in a CNG Swift
yes guys, you read the title correctly, i have successfully made a fiberglass sub enclosure for a swift with a CNG kit
Pics follow.
Sorry for the bad quality pics, i did not document the entire process.
i will post daylight pics of the completed product tomorrow.
cheers!
HimuraKenshin is offline   (6) Thanks Reply With Quote
Old 14th December 2013, 22:48   #2
mints21's Avatar
Thanked: 1,180 Times
Default re: FiberGlass Sub enclosure in a CNG Swift
A good and nice innovation. Please try and put before and after pictures if you can. Also, do let us know what drew your attention of having such a thing in place. I am also concerned about the sound quality as the kenwood speaker/woofer is quite below the CNG cylinder. Do you feel the difference in sound quality. Best wishes.
mints21 is offline   Reply With Quote
Old 15th December 2013, 18:55   #3
Thanked: 183 Times
Hey,
Well, i was earlier running a slim sub under the cng tank, but slim sub drivers do not just cut it.
Hence i went in for a custom fibreglass install.
The kenwood sub sounds tight and punchy, the subwoofer placement does not really matter that much, usually in hatch backs it sounds best when it is firing towards the boot lid (because of cabin gain)
The subwoofer is cut of at 70Hz, all frequencies below 85hz are unidirectional, that means that our brain can not pin point the location where it is coming from..
HimuraKenshin is offline   Reply With Quote
Old 16th December 2013, 14:04   #4
DerAlte's Avatar
Thanked: 2,876 Times
Originally Posted by HimuraKenshin View Post
... all frequencies below 85hz are unidirectional, that means that our brain can not pin point the location where it is coming from..
LOL where did you get that? Of course it is possible to figure that out (at least it is coming from rear), unless there are multiple reflections interfering. The issue is of integration with the front image, which one uses TA to achieve.
Anyhow, congratulations. Fantastic DIY effort!!!
Old 16th December 2013, 16:02   #5
naturaldisaster's Avatar
Thanked: 90 Times
Mod Note : There are several spelling & grammatical errors in your posts. This negatively affects the forum experience for other readers.
Kindly ensure that you proof-read your posts prior to submission. Also, it would be a good idea to use spell-checkers.
naturaldisaster is offline   Reply With Quote Received Infraction
Old 17th August 2014, 09:40   #6
Thanked: 183 Times
Default Re: FiberGlass Sub enclosure in a CNG Swift
Thanks for the kind words.
Sorry for the late reply,just saw this. haha
Sorry for the wrong use of terminology, what i meant was that bellow 80Hz or so, is the point at which human hearing sound localisation ends. At lower frequencies to adjust localisation of sound, phase and amplitude come into play. This is because at lower frequencies the wavelengths are so large that the distance between our ears is far too small to perceive the difference
Old 17th August 2014, 10:53   #7
SunnyBoi's Avatar
Thanked: 2,767 Times
Great effort, have a few questions since I intend to do something similar:
1. How many layers of fiberglass did you put on the enclosure to make it rigid?
2. Where did you source the speaker ring?
3. How have you fixed the new enclosure so that it doesnt move about?
4. How did you measure the enclosure volume for the subwoofer?
SunnyBoi is offline   Reply With Quote
Old 17th August 2014, 11:08   #8
Thanked: 183 Times
Hey, thanks for the kind words, answering your questions one by one.
  1. The box is made up of chopped mat fiberglass, 3/4 layers all over.
  2. I sourced the speaker ring from a person near my house who makes sub woofer enclosures and speaker boxes, he is a friend so gave it to me for free. To measure the integrity of the box, you can use a scientific method called the stand test, you stand on top of the box, it shouldn't flex or break :P
  3. I fixed the enclosure in place with the help if wooden supports. it s not screwed to the body, but in fact held in place by 2 wooden strips that apply pressure on the enclosure from the CNG tank/stand.
  4. I measured the volume by pouring water inside it and then measuring the water. HAHAHAHA this also helped me in checking for leaks.
HimuraKenshin is offline   (2) Thanks Reply With Quote
Old 11th November 2014, 13:40   #9
Thanked: 13 Times
Hey must say you have got a very clean install in your ride.
I can understand the space constraints with a CNG kit fitted but you have overcome that as well as kept the looks of the install very clean.
sheldon4888 is offline   Reply With Quote
Fiberglass Vs Mdf Enclosure DjNik In-Car Entertainment 13 29th April 2011 18:16
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Need info on Sub and enclosure Gtea In-Car Entertainment 30 22nd December 2006 14:31
Fiberfill for Sub enclosure madbullram In-Car Entertainment 18 5th November 2006 00:50
