Old 27th June 2006, 10:52   #1
navin's Avatar
Thanked: 4,351 Times
Default High power HUs
http://www2.panasonic.com/webapp/wcs...s&displayTab=S
the above link got me thinking. Now those who know me know that this is not something I oft do.
30W rms (ok it is at 1% distortion) is not bad for a HU. Anyone know of a HU that puts out more?
Old 27th June 2006, 11:40   #2
jkdas's Avatar
Thanked: 1,437 Times
Ah, look at these of the same product
Pre-Amp Outputs (Front/Rear/Subwoofer) :dual outputs (5V/60 ohms) Subwoofer Output Level/Impedance 5V/60 ohms !
why 60 ohms! And a snr of 100 above is excellent right?
Old 28th June 2006, 12:28   #3
navin's Avatar
60 ohms is an odd impedance. Usually you'd look at 10-20k ro so as most amps have an input impedance in that range.
Old 28th June 2006, 13:01   #4
Rehaan's Avatar
Thanked: 25,081 Times
So how does that work Navin?
Wouldn't it be getting VERY hot, or is it using a different kind of amplification?
cya
R
Old 28th June 2006, 18:52   #5
Sam Kapasi's Avatar
Thanked: 1,490 Times
No No Rehaan,
JKD has pointed out the PRE-amplifier output in peak to peak voltage. No pre amp components produces heat (rather needs to)
Don't confuse the Power output (measured in WATTS) with the pre amplifier output (Measured in AC VOLTS peak to peak)
It's odd for a company to state the Pre Amp output @60 ohms.
Generally the input impedance for most amplifiers is about/around 20000 ohms. So for example is you connected two amplifiers on the same set of RCA outs you would effectively have an input impedance of about 10000 ohms.
It would be near impossible to find any electronic device (eq, DSP, amp, processor etc) that had an input impedance of 60 ohms.
That's why Navin found it strange.
Old 28th June 2006, 19:42   #6
Rehaan's Avatar
Hey Sam,
My question didnt arise after looking at the preamp outputs, but the 30W RMS that is mentioned ... ?
cya
R
Old 28th June 2006, 21:17   #7
jkdas's Avatar
Originally Posted by Rehaan
Hey Sam,
cya
R
I found teh answer Class T amp! like in my PA275! yahooo. Its comming back in HU.
Old 28th June 2006, 23:11   #8
Sam Kapasi's Avatar
Sory Rehaan, I thought you were referring to JKs post. I am old and senile too.
Old 29th June 2006, 12:48   #9
navin's Avatar
Sam, remember I got 10+ years on you and I could assume a lot more chemicals in my system (coming as I did at the fag end of the "Love Generation"). Now imagine my state of mind. No you dont need to imagine - it is evident in the quality of my posts on this forum. Thanks to guys you others can gleam something useful from my rantings.
I dont think the Panny HU is Class D. I too wonder about the heat issue and that is why I have been loathe to recommend such HUs. Still this is a topic that must be investigagted before we discard such products as hocus pocus.
Old 29th June 2006, 13:35   #10
jkdas's Avatar
It is actually Class T not D. I googled and found it so in many sites
http://www.crutchfield.com/S-cZYnshC...300&I=133C8803
Old 29th June 2006, 17:17   #11
navin's Avatar
Anyone got any opinons on how it sounds?
Old 6th July 2007, 09:10   #12
Just revisited the crutchfield link now, it has earned very good feedback over time (4.5 stars out of 5 from 23 people!)
santosh.s is offline   Reply With Quote
Old 6th July 2007, 11:15   #13
navin's Avatar
santosh. I dont read ragazine feedback. i trust you also rely on your own ears. ragazines have other priorites incl the "Audiophile" ones.
Old 6th July 2007, 12:28   #14
Thanked: 295 Times
but the features looks good for the HU. and the internal amp is said to be 31 watts RMS but with what other figures are not mentioned.
Old 6th July 2007, 12:58   #15
I think you meant "magazines"? that is true, it is hard to believe them due to their vested interests. But the link points to a net shopping site, and I respect user feedbacks, especially if it is a collective opinion from a lot of people over a period of time and unless there is something apparently fishy (one has to filter out overly positive comments out of excitement or sarcastic comments out of frustration)
Clarion HUs discussion! nitrous In-Car Entertainment 81 22nd November 2015 11:05
Bluetooth HUs - audio quality? vebmetal In-Car Entertainment 23 13th May 2009 16:55
Alpine 9853 and other iPod compatible HUs d.kiran In-Car Entertainment 12 9th October 2007 09:11
What is the level of control in USB HUs? vebmetal In-Car Entertainment 18 12th September 2007 15:04
