Old 27th June 2006, 18:14   #1
Sankar's Avatar
Thanked: 4,655 Times
Default Dynamat alternative?
Is there a cheaper Dynamat alternative available locally? I'm looking for a sound deadner to use on the doors and the entire floor of the car to cut vibrations and road noises. I need the self sticking type i need. Any idea which brand and where to look for? Price per square foot would also be helpful.
Thanks.
Old 27th June 2006, 18:33   #2
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Try Wurth damping pads .. Dont remember the prices though .. Sound Factor next to LCD has them ..
Old 27th June 2006, 19:40   #3
jkdas's Avatar
Thanked: 1,436 Times
Wurth costs 3000rs for 6 sheets, forgot the size of teh sheets. AZaudiocomp too have one.
Old 27th June 2006, 20:02   #4
Sankar's Avatar
What's the size of the sheets? Isn't there a cheaper alternative available. I want to cover the floor section of the car completely, then the door and maybe under the hood, mainly to improve upon NVH levels.
Is there any option other than the self sticking sheets to apply to the floor section. I want something that'll stick properly to the floor (i don't want it to come off for any reason). On second thought it's okay if it's not self sticking. Help me with the options please.
Thanks.
Old 12th July 2009, 14:59   #5
arjyamaj's Avatar
Thanked: 24 Times
What's the size of the sheets? Isn't there a cheaper alternative available. [...]
Is there any option other than the self sticking sheets to apply to the floor section. [...] On second thought it's okay if it's not self sticking. Thanks.
I used to go hiking and trekking quite often a while back. During those trips I would use a rubber mat to put my sleeping bag on. This would provide quite a bit of insulation, especially in sub zero temperatures. Its made of tough rubberised foam and a coating of industrial strength adhesive (or your regular fevicol) should be enough to stick it on to whatever surface you'd like to dampen.
Its much cheaper than any of the specialised branded options. A 6x3 sheet costs about Rs 150-200
Problem is, I have no idea where to get the said sheets. I'd know where to get them in Calcutta (where I grew up) but apart from there, no clue. Maybe at hardware shops?
arjyamaj is offline   Reply With Quote
Old 12th July 2009, 15:40   #6
frankmehta's Avatar
Thanked: 2,334 Times
http://www.team-bhp.com/forum/produc...er-thread.html
we already have a thread here.
this will help you mate. there is a long drawn discussion here. please refer to it.
Old 12th July 2009, 15:48   #7
greenhorn's Avatar
Thanked: 1,519 Times
http://www.team-bhp.com/forum/diy-do...-yoga-mat.html
this might be a more viable DIY approach
greenhorn is online now   Reply With Quote
Old 12th July 2009, 20:25   #8
DocG's Avatar
Dude very simple, go to a TATA service station, and get the Wurth underbody treatment done. It should serve your purpose.
If you wish to attack the problem in a more aggressive manner, for the underbody I'd suggest a spray on damper or sludge damper. These would give you much better results than the sheets, however might work out slightly more expensive.
DocG is offline   Reply With Quote
Old 13th July 2009, 10:36   #9
HRT_FPV's Avatar
I've seen Wurth sheets peeling off after a while. I've installed Scosche Accumat on my Fiesta and it is doing a really good job. I used about about 3 sheets for my boot and front door and with each sheet costing 2000 Rs, it totaled up to 6500 Rs including installation.
HRT_FPV is offline   Reply With Quote
Old 13th July 2009, 19:45   #10
Sankar's Avatar
Its a three year old thread, the car which was to be damped has been sold off. Anyways when i'm on my feet again (literally) i'll be buying another set of wheels. Thanks for the tips guys.
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ???? hotstuff In-Car Entertainment 34 30th April 2016 00:37
I want to develop the Indian version of Dynamat. UPDATE: Sample is ready for testing! AbhiJ Modifications & Accessories 153 5th June 2009 18:41
Fibre Glass Or Dynamat ? absynthguzzler Modifications & Accessories 5 19th January 2008 11:33
infinty subw for sale with dynamat extreme rsjaurr Shifting gears 16 20th March 2006 13:33
