Old 19th January 2014, 02:29   #1
Akshay1234's Avatar
Thanked: 7,242 Times
Default Alpine Processor Issue : Help Needed
Hey guys, so I had installed an Alpine PXE-H650 processor in my Accord almost 2 years ago. It had worked flawlessly till a few months ago until I faced an issue.
Sometimes when I started the car no sound would come out of the music system. But after driving for a while when I restarted the music system it would work fine. Slowly the delay got more and more until the sound stopped until I restarted my car the next time I was using it.
Now the amps were getting power, so I thought it may be some electrical issue.
I dropped by Bass&Troubles place, and he said it was a processor issue. He asked me to go to Chandrika electronics who may be able to fix it. When I called that chap he said he wouldn't even look at it. So now I'm in a fix.
Heres the thing, if the processor fuse is pulled out and put back in it suddenly works fine. But I obviously can't do that everytime I start my car. Also on the processor remote, there is an aux and an hu button. When there is no sound if I press the hu button sound comes from the left front speaker.
Sometimes it still works fine when I press the HU button on the processor remote.
I don't really want to buy a new processor, since I'm not sure how long I'll keep the car.
Any suggestions on what I should try, or whom I can show the processor to?
I will have a word with Bass&Trouble again, and try to reset the whole thing and tune it again when he has time. But I have a feeling it wont work.
So navin, ramie, lbm and all you guys please give me your suggestions.
Thanks.
Old 19th January 2014, 13:58   #2
joybhowmik's Avatar
Thanked: 1,928 Times
Default Re: Alpine Processor Issue : Help Needed
Thanks.
Sir, I am no electronics whiz, and certainly no expert on these things, but from what you described so far if I may offer a suggestion.
Pic Courtesy:http://www.onlinecarstereo.com
If your device is the same as the picture , there is an ISO power connector at the back. Can you check if there is continuity in the power lines to/from the fuse. A regular multimeter continuity test will do.
If that checks out OK, then I guess it's time to check out the rest of the circuitry starting with the power circuitry behind that ISO connector. Best of luck!
joybhowmik is online now   (1) Thanks Reply With Quote
Help me choose a processor >I7 Vs Phenom VC FX process lohithrao Gadgets, Computers & Software 16 14th November 2011 16:09
New HU JVC AVX-44 Installed, Can I add a alpine 701 processor? Piyush_Vroom In-Car Entertainment 9 16th January 2009 22:57
Need help with processor madbullram Gadgets, Computers & Software 38 29th May 2008 13:29
Which Processor, Motherboard & RAM? shuvd Gadgets, Computers & Software 47 4th May 2008 23:52
