Old 17th February 2014, 13:57   #1
Thanked: 172 Times
Default 12v Charging Point and Sound Distortion
My senior has top of line innova with company fitted music system. It has two charging points at front. The problem is while FM stations are being played and he plugs his mobile into charging point-passenger side one, there is very huge distortion in sound. Now, if he plugs the charger onto the other side-driver side, the distortion is gone. We have tried doing it with different brand of mobiles but the problem remains same.
Any help or solution in mind
su1978 is offline   Reply With Quote
Old 17th February 2014, 18:54   #2
Thanked: 2,060 Times
Default re: 12v Charging Point and Sound Distortion
- Longer charging cable to keep phone away from antenna connection.
- Check antenna cable connections at the back of music system - if everything is well or exposed copper wiring in any cables?
- Check antenna fitment - its the radio signal interference that is causing this issue. Where is the antenna by the way? In my opinion, if the antenna is further away from charging point and phone placement the interference will low. How about fitting a cool looking antenna on the car away from phone area and run the signal cable in as concealed manner as possible?
Did you visit the service station? What did they say?
abirnale is offline   (1) Thanks Reply With Quote
Old 17th February 2014, 20:08   #3
paragsachania's Avatar
Thanked: 10,566 Times
Remove that charging socket causing the trouble, pull off the Ground cable and try to fix that to some other ground location. May be use a better/thicker gauge wire for better grounding and see if the issue persists.
Most of the whines/distortions produced due to the 12V socket or for that matter Amplifiers are due to improper or poor grounding.
paragsachania is offline   (2) Thanks Reply With Quote
Old 19th February 2014, 15:47   #4
greenhorn's Avatar
Thanked: 1,318 Times
Default Re: 12v Charging Point and Sound Distortion
have you tried a different (possibly original) Mobile charger? A badly designed Mobile charger would put out a lot of EM interference
greenhorn is offline   (1) Thanks Reply With Quote
Old 25th February 2014, 18:13   #5
Thanked: 172 Times
Thanks a lot for your advice sir. We have tried changing the charger but the issue persists. The current charger in use is an original Samsung charger. The phone used is Samsung Galaxy S-2. Even we tried doing it with a Nokia phone and a roadside 100 bucks charger but problem persists.
Alto Lxi : My Point A to Point B - Done 25000Kms AltoHoncho Long-Term Ownership Reviews 21 28th March 2017 15:54
12V or 24V Android Technical Stuff 5 6th December 2008 05:55
Is FIAT Charging Exhorbitant Rates for Spares? And Tata for service/labour charges? gemithomas The Indian Car Scene 34 18th November 2008 12:49
Help with some distortion rocksterraghu In-Car Entertainment 6 11th March 2007 02:07
12v Impact Wrench for changing Tyres - Opinions please. s0uljah Tyre & Alloy wheel Section 4 14th April 2006 19:53
