Old 16th October 2014, 19:01   #211
Thanked: 2,522 Times
Originally Posted by gearhead_mait View Post
Just back from a trip to Kumaon. I must say SJ1000 did its job perfectly. What a dashcam!!!
The clarity of the videos are fantastic, specially if you connect the laptop to an HDTV using HDMI cables. The wide angle is an icing on the cake.
Highly recommended.
Did you experience any sort of shakes as depicted in the opening post of this thread?
And how many hours worth of footage does a 32gb card contain? Were you emptying it out at regular intervals to retain the videos?
Dry Ice is offline   Reply With Quote
Old 18th October 2014, 01:18   #212
gearhead_mait's Avatar
Thanked: 1,381 Times
Default Re: SJ1000 Action / Dash Camera - An extended review
As the trip was made on a hired car, so here the Sj1000's played the role of a handycam. So the videos of the trip won't do justice to the shaking problem.
I have been using the SJ1000 as a dashcam in my car, and I would say that although the shaking is reduced by adjusting the screw of the mount, but still it is present , specially in the roads of Kolkata.
I can answer this part (and more).
32 gb card suffices 4 hours of continous recording at FHD.
As for the battery, it would last for about 2 hours non stop. I used it in a staggered manner in the trip (like a handycam) and everyday the charge lasted the whole day.
gearhead_mait is offline   (1) Thanks Reply With Quote
Old 18th October 2014, 02:22   #213
akshay4587's Avatar
Thanked: 1,686 Times
I used SJ1000 to shoot some video's on my recent trip to ladakh.
I used a slightly modified cell phone mount for the camera and the video's came out pretty decent. Video was shaky only on stretches where the road was really bad,and the fact that i was driving a Thar with bumpy ride slightly aggravated the shake, however pretty happy with overall performance.
akshay4587 is offline   (2) Thanks Reply With Quote
Old 20th October 2014, 10:54   #214
Akshay - Could you please share a pic and/or the online listing of the cell phone mount you were mentioning for SJ1000?
I am seriously considering removing the shakes from the videos.
gearhead_mait is offline   Reply With Quote
Old 10th December 2014, 18:04   #215
tsk1979's Avatar
Thanked: 16,422 Times
So, I finally have the SJ M10 with me. Its SJ4000 in a smaller body. Will review it and post in this thread.
After my SJ1000 broke, I decided SJ4000, but then I discovered SJ M10. Same chipset, but smaller.
Old 13th December 2014, 12:10   #216
sumeshmani's Avatar
Thanked: 105 Times
Congratulations on the purchase.
Where did you buy it from? Did you buy the wifi version?
No pressure, I am waiting for the review
Please do post photos of the cam with the mount.
sumeshmani is offline   Reply With Quote
Old 13th December 2014, 17:13   #217
tsk1979's Avatar
Here you go
http://www.gearbest.com/action-cameras/pp_113683.html
This does not have WIFI
I wanted an entry level camera without all this wifi and stuff
Here is a coupon code GBM10LG which will make it cheaper to 77$
But there is no car mount or charger. I am using my old mount. Since it takes any cell phone charger, that is not missed much. Car mounts are about 2-3$ extra
Old 14th December 2014, 11:48   #218
Thanked: 337 Times
A detailed review is in order, and will be much awaited.
I intend to buy one such camera though I'm apprehensive about the load on electricals with the camera drawing power from the 12V socket and the MMI navigator / Cellphone (as a navigator) drawing power from the USB port on the Manza's ICE at the same time. Will it trip any fuses?
Cheers !
Ironhide is offline   Reply With Quote
Old 14th December 2014, 12:31   #219
paragsachania's Avatar
Thanked: 12,358 Times
Cheers !
I have Dash Cam, MMI, Rear 12v Socket mostly charging Phone all the times.
These are not the devices that will trip your fuse. Also,the Dashcam draws 5V power that is stepped down at its Charger end.
Trick is that the 12v x Amps of Fuse = Wattage.
A high wattage device is likely to blow the respective fuse (10Amp Fuse and you are using more than 120w Load).
With Dashcams and car chargers, this is very unlikely as they are not high wattage devices.
paragsachania is online now   Reply With Quote
Old 14th December 2014, 14:33   #220
tsk1979's Avatar
5V is voltage.
If you have a 10AMP fuse It just means that if your device has an issue and pulls 10 amps, the fuse will trip
At 14.4V, 10amps is about 140W.
Dashcamps are typically about 3-5W
1A at 5V USB.
That's it.
Some big screen devices pull 2A at 5V which is 10W. This again is quite les
At 14.4V 1A at 5V translates to about 300-400mA of current. That's it.
Your socket can take about 15A before tripping. Or 10A in some cars.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 24th December 2014, 19:19   #221
tsk1979's Avatar
Default SJ M10, my SJ1000 replacement
With SJ1000 going boom(things break when handled hard you see), I needed a replacement.
Well, there is my mobious, works great, stellar community support, and stellar image quality too... But you see, that I use for a special purpose.
Primarily, timelapses, and other funky stuff.
I still needed something which can be used underwater, and used as a backup cam.
To be frank, I wanted a SJ4000, without WIFI of course, but the bulk was putting me off. The SJ1000 was also pretty heavy, and this I do not like. So, enter the SJ M10.
Same chipset, similar mounts but lighter and smaller. Not as small as the polaroid cube, but then polaroid cube costs quite a bit more.
So how is the image quality?
Well, its quite good. It has to be, its one of the best chipsets in budget cams.
Sure, it tends to underexpose a bit, but you can up the exposure a notch if that's what you want.
Anyways, here are a couple of sample videos
First we look at how it performs as a Dashcam.
I have taken 4 different scenes
First is against the sun, second is normal, third is to show the slight vibration which might creep in, but its fixable, and last but not the least, the night shot capability.
Second, we will see how it does underwater.
As you can see, the white balance is handled perfectly, so is the exposure. Why would you spend over 250$ on a camera not even as capable?
The casing held up for many days of underwater use. No leaks at all.
Other things to note
  • You get waterproof case and action mounts, no car mount or charging cable
  • A car mount can be had for 2-3$, as for charging, your cell phone micro USB charger will do fine
  • When using the non waterproof mount, insert a small strip of paper between the mount and the camera at the bottom, and all the shake will go away
  • Increase exposure by one notch if you are using it for show off videos rather than documenting your driving. It makes the image brighter and more pleasing
Time for a few pictures
The full collection of mounts and sticky tapes. There are quite a few. For your helmet or handlebars, all you need is there. For your dash, however you got to buy the windshield mount separately. Do note that there is an additional waterproof case cover with the mount.
And last but not the least, there is the cradle mount, which you will use to mount to a tripod or a car suction cup. Good to know that this is much much better than SJ1000. Side by side comparison.
Where to buy?
I looked at ebay first, but with a couple of reputed sellers refusing to ship to India, it was time to turn to gearbest. The price of 89$ was higher, but then coupon codes to the rescue
CODE:GBM10LG
NOTE: Buy Shipping/Freight Insurance. Its 2-4$ only but is very very useful if your item breaks in transit!! Due to some weird reason they do not advertise that you can buy this, but before placing your order email them or contact support and tell them to add insurance to your cart!! I repeat, do this because India post really mishandles packages.
Customs Duty : Postman will collect duty(usually less than 1000rs). No need to go to customs office. Many people report no duty being levied.
tsk1979 is offline   (3) Thanks Reply With Quote
Old 24th December 2014, 21:44   #222
harsha.muvva's Avatar
Thanked: 404 Times
Default Re: SJ M10, my SJ1000 replacement
Thank you very much for the detailed review.
I am planning to purchase action cam and usage will primarily be on bike(handlebar,tank or helmet mount).I was contemplating between GoPro hero 4 or Sony AS100V(sony mainly because of the GPS function it offers).But I am unable to decide if it is worth going for these expensive ones considering my limited usage.So thought of purchasing something basic(less expensive), use it for a while and then upgrade if needed.This SJ M10 seems perfect choice for me especially considering size and also from the videos I saw the quality is good enough
However I would like to know about the battery life of it.How long does it last on one full charge? and also how many days did it take to reach you?
The only drawback I could see is that we cannot have a preview of the outcome, unlike gopro/some high-end ones with which we can see via mobile or on the screen.But given the price I don't think we can complain much
harsha.muvva is online now   Reply With Quote
Old 24th December 2014, 22:26   #223
tsk1979's Avatar
It took 2 weeks to reach. Battery life is about 75 minutes. Spec says 90, but I got around 75 minutes.
But then it also depends upon usage etc., and can vary.
AS for preview of the outcome, I am not sure I follow. This cam has a screen.
Old 25th December 2014, 02:52   #224
Thanked: 404 Times
Sorry for the confusion, I somehow failed to notice it :dead horse
Thanks to you, applied the discount coupon and opted for the shipping insurance as well.Cant wait to lay my hands on it
Old 25th December 2014, 03:26   #225
Thanked: 19 Times
Fellows, what cam do you suggest for handlebar mounting on a tbts 500, a vibration magnet? I need something that record 720p if required and must be weather sealed. Appreciate any response.
prasanna.vps is offline   Reply With Quote
Transcend DrivePro 200 Review - Dash Cam / DVR SirAlec In-Car Entertainment 171 16th June 2018 09:40
In-car Camera mounts - Attaching a video camera to the Car im_srini Modifications & Accessories 75 18th October 2017 21:37
Mobius Action / Dash Cam - An extended review tsk1979 In-Car Entertainment 10 27th April 2015 12:38
Chevy Cruze - Front Camera, Rear Camera, and Stronger White Headlamps? darthvader Modifications & Accessories 31 9th February 2014 21:18
Get Well Soon Yatharth(YC.BALENO.CHD) Update: Back in Action :) akshay4587 Shifting gears 205 14th July 2011 12:22
