Old 12th January 2015, 16:53   #241
gearhead_mait's Avatar
Thanked: 1,363 Times
Default Re: SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)
I find excessive vibration in my SJ1000 when using the car mount. The vibration is so bad that i cannot look at the video playback. This is on smooth 6 lane expressway.On bad roads i would rather not look the video at all. I can visually see the car mount vibrating even on butter smooth roads. I have tightened all the screws on the mount.
Any suggestions on how to get a vibration free dash footage? My SJ1000 will be a dead investment since i wanted to use it primarily as a dashcam during long drives
I myself faced this issue. At first I tried various paper chips here and there, but it didn't help. I found that my dashcam vibrates mainly near the joint of the two pieces of dash mount. So, I have completely wrapped the two parts (near the joint) tightly with brown colored one sided tape (not the SJ1000, but the mounts). Now, it works like charm. Hope this helps.
gearhead_mait is offline   Reply With Quote
Old 12th January 2015, 22:14   #242
sagarpadaki's Avatar
Thanked: 1,271 Times
Can you post a few pics of how you have applied the tape? Would be helpful
Tighten the mount screws.
Secondly, check if there is play between camera and mount, if so, insert a small paper piece for tight fit. Usually takes care of all but the most serious vibrations
The vibration is in the last part which holds the camera. It is the L shaped attachment where one leg of the L is fixed to the suction mount and the other leg holds the camera with 3 locking pins. It is this part which holds the camera that vibrates
Old 13th January 2015, 14:18   #243
rav11stars's Avatar
Thanked: 547 Times
Originally Posted by datvichrox2 View Post
Of late, I've been using a software called lightworks. It has a free version - the only downside of the free version is you can export the final video only at a max of 720p resolution.
A few clips that I made using SJ1000 and lightworks.
Thanks,
Vimal
I'm a big fan of time-lapse and the Kolar-blr ride is really nice. What's that pocket rocket that gave you company after the toll gate? Is it due to the time-lapse that it's tail lamps looked as if the brake is always pressed?
rav11stars is offline   (1) Thanks Reply With Quote
Old 18th January 2015, 11:25   #244
datvichrox2's Avatar
Thanked: 290 Times
Thanks! You mean the Ford Figo ? That is KiloAlpha.
Originally Posted by KiloAlpha View Post
KiloAlpha
Interesting observation. It does look like the brake light was always on. It can't be because of the timelapse because there are other cars in the clip where you can see the light turning on and off...
-Vimal
datvichrox2 is offline   (1) Thanks Reply With Quote
Old 21st January 2015, 13:34   #245
deky's Avatar
Thanked: 1,029 Times
I have ordered SJ1000 via aliexpress through this seller. Second time I am ordering something through a Chinese seller. First time was an inexpensive battery (dx) that I never received. Lets hope I receive this one though. Hoping Indian Customs doesnt make me cry much. Keeping fingers crossed!!
Would like to thank Tanveer for the wonderfull review. Though I was tempted to order the 4000, but I had already gone over my budget so did not want to stretch it too much.
EDIT 2 : Also wouldlike to know how does Aliexpress work? As per the email, the item has been shipped but as of yet no money has been deducted from my bank, I used a debit card?
deky is offline   Reply With Quote
Old 27th January 2015, 23:03   #246
Hi Sagar,
Apologies for the late reply. Hope this helps!
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-img_20150127_225300.jpg
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-img_20150127_225344.jpg
gearhead_mait is offline   (1) Thanks Reply With Quote
Old 28th January 2015, 00:36   #247
Thanked: 188 Times
How long will the battery last for sj4000/m10 in 20s time lapse mode?
Will the camera/screen stay on for the entire duration of time lapse?
I am a big fan of time lapse and my Panasonic point n shoot switches off and switch on for each shot of 30sec or more time lapse. Would like to know if SJ has similar feature.
Holyghost is offline   Reply With Quote
Old 31st January 2015, 15:37   #248
John's Avatar
Thanked: 166 Times
OK. So many of us are happy with the SJ1000 camera itself (including me), but the car mount is terribly designed and quite flimsy. While browsing for better mounts, I came across Thingiverse where someone had designed and built this cool holder which seems to solve all the problems. The guy had uploaded pictures of the finished product as well as the .STL file.
So I decided to give it a try. Located a 3D printer and got them to print it up using ABS.Will be picking it up today. I'll post pictures as soon as I get back.
Will post all the details too.
John is offline   Reply With Quote
Old 2nd February 2015, 12:37   #249
John's Avatar
Thanked: 166 Times
So this is what the printed part looks like.
Name:  20150202 12.20.02.jpg
Name:  20150202 12.20.15.jpg
Name:  20150202 12.20.42.jpg
Since it was printed at medium resolution, the surfaces are rough. However a bit of sanding before spraying with a matt black paint should give a good finish. I've also attached a picture of what the final assembly will look like.
Will post pictures of the finished component and the final assembly once I've finished it.
John is offline   (3) Thanks Reply With Quote
Old 2nd February 2015, 12:57   #250
tsk1979's Avatar
Thanked: 15,684 Times
Originally Posted by John View Post
So this is what the printed part looks like..
Excellent. I thought 3D printers were extremely rare here. Typically whats the cost of getting such a mount printed?
Old 2nd February 2015, 13:08   #251
John's Avatar
Thanked: 166 Times
That's what even I thought! But if you go to a site called 3D Hubs and search, it will throw up the names of all 3D printers in a 10 km radius of your location. I found about 8 printers close to my location. I chose the nearest guy who prints using ABS. Since it was the first time, I placed the order through 3D Hubs, so there were some additional charges. Later when I contacted the printer he said the next time I could contact him directly. It cost me Rs.1020, but it can be done for far less now that I'm in direct touch with the printer.
Old 7th February 2015, 12:00   #252
John's Avatar
Thanked: 166 Times
Completed the painting and assembly. Extremely happy with the set up. No vibrations and more importantly the LCD display is clearly visible due to the hood shading it from ambient light. Also all the buttons are easily accessible. Here are some pics.
John is offline   (1) Thanks Reply With Quote
Old 24th February 2015, 07:23   #253
PVS
Thanked: 119 Times
I have ordered Sj4000 + Car Dash Mount via DX.com;
296552 Universal 360 Degrees Rotation Suction Cup + Tripod Mount for
Gopro Hero 4/ 2 / 3 / 3+ - Black 1 4.29
288812 SJCAM SJ4000 1.5" TFT 12.0 MP 2/3" CMOS 1080P Full HD
Outdoor Sports Digital Video Camera - Black 1 76.63
Total is USD 80.92.
Yesterday I get a "collect your order" note from Postal department, with the full value as Rs 8000, rate of duty as 41.492 and amount of custom duty assessed as Rs 3319 + Rs 30 = Rs 3349/- . I will be going to the post office today to check up, but I understand I have to pay additional Rs 3349/- customs duty. Isn't that way too much?
Can anyone share a link which displays the amount of custom duty that can be levied. Also, as per the current RBI conversion rate of INR 62.13, the total should work out to Rs 5027.56, so am not quite sure how the figure of Rs 8000/- came up.
PVS is offline   Reply With Quote
Old 24th February 2015, 12:37   #254
tsk1979's Avatar
Total is USD 80.92.
You have to contest the duty claim. They have put cost as 120$. You have to go with proof of payment, and contest the claim. This is the oldest trick in customs book. Ask for more duty.
According to the law, you can contest duty claimed, and the onus is on customs department to prove that you paid more.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 25th February 2015, 09:10   #255
PVS
Thanked: 119 Times
Thanks TSK.. and how do I contest a claim? Is there any form that i need to download, or anything that I need to do?
In-car Camera mounts - Attaching a video camera to the Car im_srini Modifications & Accessories 75 18th October 2017 21:37
Transcend DrivePro 200 Review - Dash Cam / DVR SirAlec In-Car Entertainment 166 7th September 2017 15:30
Mobius Action / Dash Cam - An extended review tsk1979 In-Car Entertainment 10 27th April 2015 12:38
Chevy Cruze - Front Camera, Rear Camera, and Stronger White Headlamps? darthvader Modifications & Accessories 31 9th February 2014 21:18
Get Well Soon Yatharth(YC.BALENO.CHD) Update: Back in Action :) akshay4587 Shifting gears 205 14th July 2011 12:22
