Old 24th March 2015, 12:36   #271
tsk1979's Avatar
Thanked: 15,854 Times
Default Re: SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)
Originally Posted by sumeshmani View Post
Has anyone tried to run a dash camera or action camera off a portable power bank?
If yes, please share details.
Yes, mine does run of the portable power bank capable of supplying 1A+ current. I have an Anker power bank which does so.
Old 24th March 2015, 17:30   #272
sumeshmani's Avatar
Thanked: 105 Times
How many minutes does the camera run on the power bank and what kind of capacity does you power bank have?
I am just looking at alternatives to powering the dash camera.
sumeshmani is offline   Reply With Quote
Old 24th March 2015, 17:45   #273
tsk1979's Avatar
Never needed to go full capacity. I used it for just 20 minutes. That said the powerbank is 13000mah, and can charge my "Note 2" 3 times
Theoretically speaking if you camera pulls 1.5A of current, it means you can use it for 8 hours
tsk1979 is offline   (1) Thanks Reply With Quote
Old 27th March 2015, 20:20   #274
Thanked: 2,505 Times
Originally Posted by Dry Ice View Post
Based on the recommendations, I placed an order at banggood today for the M10+mount. Now the wait begins.
Got the cam delivered today. Pretty fast! I was expecting it to take a few more weeks. Few pictures from the unpacking. Build quality and test videos look good. Will post test videos soon. Landed cost was ~$67 net.
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-img_20150327_182149.jpg
Outer packing
Box - ignore the wifi logo
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-img_20150327_182616.jpg
Stuff included
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-img_20150327_182650.jpg
Windshield mount (separate)
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-img_20150327_192236.jpg
Custom declaration
Dry Ice is offline   (1) Thanks Reply With Quote
Old 1st April 2015, 00:12   #275
PVS
Thanked: 119 Times
Dry Ice, you had to pay anything extra towards custom duty?
PVS is offline   Reply With Quote
Old 1st April 2015, 10:10   #276
rkg
Thanked: 543 Times
Default Garmin VIRB Elite Sports & Action Camera
Flipkart is selling this model from Garmin with one year manufacturer warranty at a huge discount. Costs Rs 11397 as against MRP of 37990/- It has GPS, Barometer, Altimeter and accelerometer with 2000 mAH battery. It can take time lapse videos also
Can this be used as car dash cam. From the reviews on the net it seems it comes with a very short proprietary micro USB cable. So the chances of charging it from USB port on the car audio system is difficult. 5 meter cable is sold separately by Garmin.
Is it worth buying as Dash cam
http://www.flipkart.com/garmin-virb-...c-38254b12fd34
rkg is offline   Reply With Quote
Old 1st April 2015, 10:32   #277
Thanked: 94 Times
Default Re: Garmin VIRB Elite Sports & Action Camera
From the specs it seems to be one terrific action cam. It has some decent reviews too from what I could google out. It could just be me, but I find the price at 11397 too good to be true!
Even if the port on the camera is proprietary, the other end of the cable should be the standard A type USB connector. So you can always use a USB extension cable to connect it to your Audio system or to a 12V USB charger. You just need to make sure that the current supplied is sufficient for the camera (I believe around 1A should be sufficient).
But to use it as a dash cam effectively, you need to find out if it can automatically start and stop the recording based on the power events on the USB cable.
PreethamB is offline   (1) Thanks Reply With Quote
Old 1st April 2015, 10:40   #278
rkg
Thanked: 543 Times
USB cable port end of the camera is proprietary. The audio system end is ok, but the camera end is not, hence ordinary Micro USB does not work.
The reviews does not mention any thing about cycle recording/continuous recording
Old 1st April 2015, 10:47   #279
Thanked: 94 Times
A USB extension cable at one end has a Female A type connector similar to the USB port found on a laptop/PC while at the other end has a regular USB A type male connector.
Found one on Flipkart - http://www.flipkart.com/jinali-usb-a...0-a20617c7a9ad
Connect the short proprietary cable supplied by Garmin to the camera's port. Connect the other end of the short cable to the USB port end of the extension cable. Now connect the other end of the extension cable to the audio system and you are good to go.
Old 1st April 2015, 14:07   #280
No, thanks to the value declaration by the seller I guess - less than $25.
Dry Ice is offline   Reply With Quote
Old 2nd April 2015, 22:13   #281
mukeshgoel's Avatar
Thanked: 381 Times
That's awesome purchase.
Please share link of the product (and mount) you bought. I want to buy asap.
Is it same as mentioned at http://www.team-bhp.com/forum/produc...ml#post3662519 ?
Also, did you use any discount coupon at banggood website ?
mukeshgoel is online now   Reply With Quote
Old 3rd April 2015, 00:48   #282
Both of the following are same ?
AND
http://www.flipkart.com/garmin-virb-...MDYGHBKZH29RMF
VMehta is offline   Reply With Quote
Old 3rd April 2015, 13:11   #283
Rahulk76's Avatar
Thanked: 204 Times
Whats the difference then between this and HTC RE camera ?
HTC RE -> http://www.snapdeal.com/product/htc-...mera/296462536
They both cost approximately the same, function same, IPx certified.
(ofcourse it depends of the usage pattern. I am contemplating between now HTC and Garmin. If not then ill get that SJ4k dash cam.)
Looking forward to members view on this.
Rahulk76 is offline   Reply With Quote
Old 3rd April 2015, 19:10   #284
So here are a few videos I shot over the past few days.
Yet to shoot a proper night time video though - will post that soon.
I wanted a black one initially but sadly it was out of stock so ordered a white one. Had some CF wrap lying around - which I put to good use today.
Now it's a much less obvious that it's a camera when viewed head on.
Is it same as mentioned at ... ?
Yes, those are the correct links - I have also put them in video descriptions. You can use the coupon '6e6e0b' for extra 5% off.
Dry Ice is offline   (3) Thanks Reply With Quote
Old 3rd April 2015, 20:24   #285
mukeshgoel's Avatar
Thanked: 381 Times
Thanks. I was getting impatient and bought it last night. It has been shipped today.
That's nice CF wrap you have done. I ordered a black one and was thinking to put just a black electricity insulation tape on "HP1080P SJCAM" to make it less visible.
mukeshgoel is online now   (2) Thanks Reply With Quote
Transcend DrivePro 200 Review - Dash Cam / DVR SirAlec In-Car Entertainment 168 25th May 2018 20:44
In-car Camera mounts - Attaching a video camera to the Car im_srini Modifications & Accessories 75 18th October 2017 21:37
Mobius Action / Dash Cam - An extended review tsk1979 In-Car Entertainment 10 27th April 2015 12:38
Chevy Cruze - Front Camera, Rear Camera, and Stronger White Headlamps? darthvader Modifications & Accessories 31 9th February 2014 21:18
Get Well Soon Yatharth(YC.BALENO.CHD) Update: Back in Action :) akshay4587 Shifting gears 205 14th July 2011 12:22
