Old 8th April 2015, 01:53   #286
Thanked: 561 Times
Default Re: SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)
was wanting to buy a dash-cam since a long time, and this thread was just adding fuel to fire!
after a lot of mental deliberations, just ordered M10-Wifi (Black, full kit) and windshield mount, total $ 105.08 from Banggood.com. hopefully, I get the items in few days, and without any customs mess.
http://www.banggood.com/SJcam-M10-WI...-p-954162.html
http://www.banggood.com/Windshield-S...d-p-80420.html
@DryIce : thanks for the ready link of windshield mount, and btw - that coupon code didnt work. additionally, did many futile attempts for searching a discount code!
now the wait starts
pcpranav is offline   Reply With Quote
Old 8th April 2015, 03:08   #287
Thad E Ginathom's Avatar
Thanked: 7,458 Times
I never thought about it, but then I came across this thread
A couple of questions for users of that little M10 cube...
I see recording time given as about 90 minutes. Is that with a 32Gb card? Can it loop and overwrite earlier records?
Are people using this on battery, or USB power?
Sorry if this is all old stuff, it's a case of newbie on a long thread!
Old 8th April 2015, 07:20   #288
Rajeevraj's Avatar
Thanked: 8,207 Times
90 min does not seem right for 32gb. It could be the recording time on battery. I have another version with similar specs (sjcam 4000). With a 32gb card it can record ~4hrs of footage in 1080p HD. It records in 3 min clips and will automatically start overwriting the oldest segment once full.
In a car, this is typically connected to the 12v point with a regular car charger.
Rajeevraj is offline   (1) Thanks Reply With Quote
Old 8th April 2015, 07:29   #289
Thanked: 561 Times
though I have not used it, based on my reading of this thread:
- loop & overwrite recording is possible
- max 32GB card supported, which may give ~4hrs of continuous FHD recording
- on-board battery takes ~3hours to fully charge, and can provide you ~70-90 min of recording
- using a USB power, you can extend the operating time; eg. use a USB 1A+ power bank while you are on a hike; running will depend on the size of your power bank!
- in car, use the usb charging - device even supports "car" mode, which means starts/stops automatically based on car's start/stop.
found two good reviews:
http://sjcamguides.com/complete-revi...ni-action-cam/
http://sjcamguides.com/sjcam-sj4000-...camera-review/
pcpranav is offline   (1) Thanks Reply With Quote
Old 8th April 2015, 19:17   #290
mukeshgoel's Avatar
Thanked: 379 Times
What length micro USB cable do I need to route it like this ?
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-howtoconnectadashboardcameraspoweradapter.jpg
mukeshgoel is offline   Reply With Quote
Old 8th April 2015, 19:33   #291
Thanked: 93 Times
3 metres should suffice.
PreethamB is offline   (1) Thanks Reply With Quote
Old 8th April 2015, 19:45   #292
mukeshgoel's Avatar
Thanked: 379 Times
Thanks.
Anyone bought such cable which gives at least 1A output ?
Old 8th April 2015, 22:22   #293
Thanked: 2,388 Times
I think your questions have been answered already by Rajeev and pranav, I just want to add a few things.
It keeps on recording and overwriting older videos. You have to select 'loop recording' in settings first though, along with the length of videos - minimum is 3 mins. 3 min videos in 1080p occupy about 360MB each, so you have past 4 hours of footage at any time.
Another helpful setting is the car mode. If you switch it on, cam will start recording as soon as it gets power and stops recording when power is removed. Basically, you don't have to turn it on/off everytime.
EDIT:
Thanks.
I bought the longest one I could find on Amazon - http://www.amazon.in/gp/product/B00GGMKKC4
Quality is good, and seems to charge the cam fine. Yet to test thoroughly and install it though, will do it over the weekend.
Dry Ice is offline   (2) Thanks Reply With Quote
Old 8th April 2015, 23:00   #294
kamal.sn's Avatar
Thanked: 81 Times
Thanks.
A 3M USB cable will not be able to drive the device as there will be a voltage drop due to the length of the cable. I had tried a similar setup with a 1.5 meter cable and it worked however i later changed the setup to a 12V to multi-port USB charging station as i wanted to power-up multiple devices with the same. Check the following link for information on the product :
http://www.amazon.com/ORICO-MPU-5S-P.../dp/B00K7W4UY8
kamal.sn is offline   (1) Thanks Reply With Quote
Old 13th April 2015, 13:41   #295
Thanked: 89 Times
Why not to buy from SJCAM.com website itself? Better offers on other sites or any other advantages / reasons?
http://www.sjcam.com/home/27-sjcam-s...sport-dvr.html
Originally Posted by Klub Class View Post
I ordered the following from AliExpress on August 16th :
Thanks. Liked both these links. Its $95.39 + $3 shipping thro' China post, offer includes 1 additional battery & desktop charger thrown it with the cam.
Another link at aliexpress of the same seller but without additional battery & desktop charger-->> http://www.aliexpress.com/item/1080P...684922889.html
Few more links...
http://www.dx.com/s/sjcam%2bsj4000%2...Sort=AvgRating
http://www.banggood.com/buy/Sjcam-sj4000-wifi.html
http://www.gearbest.com/sjcam-sj4000-wifi-_gear/
Better to order from these links or SJCAM.com company site? The difference in price ranges from Rs. 500 - 1000
Just did a quick search on Google and came across a post in a FoxOffer.com's Facebook page where someone remarked that the SJ4000 WiFi lens is 170 while the SJCAM SJ4000 WiFi lens is 153.6 only. FoxOffer.com denied it saying both have 170 FOV
Also, the AliExpress page mentions the viewing angle of SJCAM SJ4000 WiFi as 153.67 (I've shared the link above)
EDIT : SJCAM website mentions the FOV as 153.6
SJCAM.com site now mentions FOV(D) as 170 degree
TheIndian is offline   Reply With Quote
Old 13th April 2015, 14:27   #296
Thanked: 89 Times
EDIT:
Just saw another "Pack" offer on SJCAM.com site - Cam + 1 additional Battery + 1 battery charger + Transcend 32GB card (I think it is Class 10 or UHS1)...Total $119.90. The additional items are for $20 difference. Free shipping (dunno is they ship to India)
http://www.sjcam.com/packs/128-sjcam...32gb-card.html
Is it a good deal?
Comparatively, aliexpress combo deal is for $95.39 + $3 shipping = $98.39 plus I'll have to buy 32 GB class 6 or above memory card separately. So, the difference between aliexpress deal & SJCAM.com offer is about $10 only
Old 13th April 2015, 14:39   #297
rkg
Thanked: 543 Times
Originally Posted by TheIndian View Post
EDIT:
Is it a good deal?
Transcend 32GB class 10 card costs just 890/- in Flipkart.
rkg is offline   (1) Thanks Reply With Quote
Old 13th April 2015, 14:55   #298
naveen.raju's Avatar
Thanked: 3,251 Times
3m would be more than enough. I have a similar setup running through the roof line, A pillar, door beading, passenger side footwell, side of the center console and finally onto the power output point. I bought an extension cable which is coupled to the shorter USB cable which is connected to a Belkin USB adapter. I have one picture of it.
http://www.team-bhp.com/forum/offici...ml#post3669870 (Ford EcoSport : Official Review)
naveen.raju is offline   (1) Thanks Reply With Quote
Old 13th April 2015, 15:24   #299
Thanked: 89 Times
Yes. But in $20 i.e. for about Rs. 1200, it's giving 1 additional battery + 1 additional charger + 32 GB Transcend class 10 card...not a bad deal
However, I just realised one other factor which might prove costly - aliexpress and those sites can declare it as gift tagging price to be <$20 but SJCAM.com might not do it and might just ship it with a price of $120 which will attract higher duties.
Old 13th April 2015, 16:42   #300
Thanked: 89 Times
The WiFi version of SJ4000, what exactly does it do in WiFi? I mean what all can be done using WiFi?
In-car Camera mounts - Attaching a video camera to the Car im_srini Modifications & Accessories 75 18th October 2017 21:37
Transcend DrivePro 200 Review - Dash Cam / DVR SirAlec In-Car Entertainment 166 7th September 2017 15:30
Mobius Action / Dash Cam - An extended review tsk1979 In-Car Entertainment 10 27th April 2015 12:38
Chevy Cruze - Front Camera, Rear Camera, and Stronger White Headlamps? darthvader Modifications & Accessories 31 9th February 2014 21:18
Get Well Soon Yatharth(YC.BALENO.CHD) Update: Back in Action :) akshay4587 Shifting gears 205 14th July 2011 12:22
