Old 20th May 2015, 11:12   #331
tsk1979's Avatar
Thanked: 15,683 Times
Default Re: SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)
Originally Posted by TheIndian View Post
Today 5.27 pm, the status changed and for the worse. The details are as below. Why restrictions import??
2015-05-19 17:27 India, MUMBAI FOREIGN POST OFFICE, Return item from customs (Inb), Air, CHENNAI AIRPORT SORTING OFFICE
2015-05-19 17:27 India, MUMBAI FOREIGN POST OFFICE, Record item customs information (Inb), Air, CHENNAI AIRPORT SORTING OFFICE, Retention reason : Articles importation subject to restrictions import- license
2015-04-29 13:39 India, MUMBAI AIR, Send item to customs (Inb), Air, MUMBAI FOREIGN POST OFFICE
What is the value declared. I hope its not something like 5$ or something. Anyways, you have to go to foreign post office. You do not need import license for personal imports.
Old 20th May 2015, 12:41   #332
Thanked: 89 Times
Thanks. I went to foreign post office today morning. They asked me to ignore those remarks & said that those remarks mean that the customs has cleared the item and it'll be delivered thro' nearest post office to me since foreign post office can't deliver it directly.
The seller is a reference taken from this thread - Puhui Electronics, Aliexpress and while he has not mentioned the value declared, I guess it should be $19-$20 because that's what we discussed while ordering
TheIndian is offline   Reply With Quote
Old 20th May 2015, 16:29   #333
m.shekhar's Avatar
Thanked: 57 Times
Ordered the SJCAM SJ5000 of the 8th of May and even mine is showing the same status right now.
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-sjcam.jpg
m.shekhar is offline   Reply With Quote
Old 20th May 2015, 16:49   #334
akshay4587's Avatar
Thanked: 1,629 Times
What website did you order it from?
And which website are you using to track the shipment?
akshay4587 is online now   Reply With Quote
Old 20th May 2015, 16:53   #335
m.shekhar's Avatar
Thanked: 57 Times
Ordered it from Aliexpress and am using the IPS Portal to track the shipment.
m.shekhar is offline   (1) Thanks Reply With Quote
Old 20th May 2015, 17:46   #336
Thanked: 89 Times
Attachment 1372632
Join the party!
In my case, it remained in that same status since 29th April till 19th May. They say that they have a huge backlog to clear :(
Old 21st May 2015, 20:18   #337
Thanked: 89 Times
It's coming tomorrow
Seller has declared $19 as value. Still, I'm told the duty will be Rs. 1275/-. Let's see.
TheIndian is offline   (2) Thanks Reply With Quote
Old 22nd May 2015, 10:56   #338
Thanked: 2,388 Times
M10 with complete mount is kind of screaming out to onlookers - look at me! Today I tried to mount it just behind the IRVM - removed the mount completely and stuck it on with just 2 rubber bands. The coverage area is pretty good - with the IRVM adjusted for me (not the cam).
This kind of makes it stealth looking and it is hardly visible from the outside. Sorry couldn't take a pic this morning, will do this evening. Here is the coverage though -
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-dash.png
Now to find an elegant way of doing this without the rubber bands.
On another note, anyone tried fitting a CPL to reduce the dashboard glare?
Dry Ice is offline   (1) Thanks Reply With Quote
Old 22nd May 2015, 12:38   #339
Twiny's Avatar
Thanked: 47 Times
Originally Posted by Dry Ice View Post
I bought the longest one I could find on Amazon - http://www.amazon.in/gp/product/B00GGMKKC4
Quality is good, and seems to charge the cam fine. Yet to test thoroughly and install it though, will do it over the weekend.
Hi, could you share the feedback on this cable. I am planning to buy a 3m cable. Can we get 3m, USB Male-A to Male-B cable?
I have also ordered M10 on April 7th (banggood) and luckily got it on 10th May without any customs charges.
Twiny is online now   Reply With Quote
Old 22nd May 2015, 12:43   #340
It does the job, keeps the cam working but sadly the output is almost halved by the time it reaches the cam. End result is the cam doesn't get charged. As soon as you remove it from the power and try to switch it on, it dies.
I have tested it by connecting with the regular cable and that seems to charge the cam as well. On the lookout for a better cable or better routing option.
The amazon seller did have a 3m version as well, not sure if that will be any better.
Dry Ice is offline   Reply With Quote
Old 22nd May 2015, 15:32   #341
m.shekhar's Avatar
Thanked: 57 Times
Where did you get the info on exactly when is it coming?
My seller seems to have put ~$40 as the value. Cons of not instructing him beforehand.
Old 22nd May 2015, 15:48   #342
mukeshgoel's Avatar
Thanked: 379 Times
Can you click a pic of the M10 from inside and outside. That will make it more clear how you mounted it.
mukeshgoel is online now   Reply With Quote
Old 22nd May 2015, 19:15   #343
Here are the pics -
Inside view
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-img_20150522_172043.jpg
As seen from outside -
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-img_20150522_172259.jpg
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-img_20150522_183226.jpg
SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)-img_20150522_183231.jpg
Dry Ice is offline   (4) Thanks Reply With Quote
Old 22nd May 2015, 20:18   #344
Thanked: 89 Times
I'm in continuous touch with Mumbai Foreign Post Office, calling them regularly. Even went there personally day before. I was told that customs has cleared it on 19th May and I should get it in 1-2 days. Then Y'day I was told that I'll get it today and the duty could be Rs. 1,275/-.
However, I've not received it today. Though the status on ipswebtracking got updated today afternoon that it's now being sent to the post office in my area. Hopefully, I should get it tomorrow or on Monday
Old 23rd May 2015, 23:31   #345
Thanked: 89 Times
Got my SJ4000 WiFi today morning. Local Post Office is fast, they received it today morning itself and delivered to me by 11 am.
Though the seller declared it as a gift with a value of $19, customs has considered value as Rs. 3000 and applied 41.xxx% duty amounting to Rs. 1275/-
In-car Camera mounts - Attaching a video camera to the Car im_srini Modifications & Accessories 75 18th October 2017 21:37
Transcend DrivePro 200 Review - Dash Cam / DVR SirAlec In-Car Entertainment 166 7th September 2017 15:30
Mobius Action / Dash Cam - An extended review tsk1979 In-Car Entertainment 10 27th April 2015 12:38
Chevy Cruze - Front Camera, Rear Camera, and Stronger White Headlamps? darthvader Modifications & Accessories 31 9th February 2014 21:18
Get Well Soon Yatharth(YC.BALENO.CHD) Update: Back in Action :) akshay4587 Shifting gears 205 14th July 2011 12:22
