Old 8th June 2015, 16:25   #361
Thanked: 222 Times
Default Re: SJ1000 Action / Dash Camera - An extended review(SJM10 update pg.15)
Got my SJ4000 Wifi from the seller link posted by Klub Class (from Puhui Digital). I used SingPost and was delivered within a week.
There is a promotion by Puhui Digital today only.
Links posted by Klub Class are below:
I ordered the following from AliExpress on August 16th : [*]SJ4000 with WiFi (Yellow ) - http://www.aliexpress.com/store/prod...016716076.html[*]Car charger + windshield suction mount - http://www.aliexpress.com/item/Car-h...744161930.html[/list]
Though the cost is on the higher side compared to the listings in DX (and other seller listings in AliExpress) this one comes with an additional battery and the seller - Puhui Digital - has very high rating (the seller had sold close to 2000 non-WiFi and 25 WiFi cameras when I placed the order). Also, the camera comes with SJCAM logo and the seller claims that they're one among the very few who're authorized to sell the camera with the SJCAM logo.
Got this email:
We will have promotion only on 8th June for SJCAM products, including SJ5000plus and SJ4000wifi and more.
The discount is up to 20% ~ 50% off.only one day.
What's more, you can get our store coupons to make the best deal.
Share with your family and friends, you should have one.
Puhui Digital
Authorized seller by SJCAM
Hope someone can get a good discount. (Seems like I paid full price
mvadg is offline   (3) Thanks Reply With Quote
Old 9th June 2015, 10:29   #362
mukeshgoel's Avatar
Thanked: 379 Times
I am not getting a USB extension cable of 3 meter length to route it through A-pillar.
I have tried:
1. BlueRigger SuperSpeed USB 3.0 (Type A Male to Type A Female) Extension / Repeater Cable (10 Feet / 3 Meters)
http://www.amazon.in/gp/product/B00H...ilpage_o00_s01
NO power through this cable.
2. Target TC030EC USB Extension Cable 3m (Black)
http://www.amazon.in/gp/product/B00Q...ilpage_o01_s00
It delivers just 300mA power on a 2A charger (read my review with pic on Amazon)
Fellow member "Dry Ice" tried
3. Storite USB 3.0 Male A To Female A Extension Cable SuperSpeed 5GBps For Laptop/PC/Mac/Printers (300cm - 9 Foot - 3M)
http://www.amazon.in/gp/product/B00GGMKKC4
Quoting Dry Ice
Measured the current and it seems to halve the output. When connected directly to charging port I observed around ~940 mA. Through the extension cable it was reduced to ~460 mA.
Camera works fine but if I turn it on without connecting to the charger it gives a low battery warning.
Maybe due to low amps it is just able to maintain the battery juice but doesn't really charge the cam.
Someone please suggest me a cable of 3 meter, either USB extension cable or USB to Micro USB cable which can deliver at least 1A power.
mukeshgoel is offline   Reply With Quote
Old 9th June 2015, 14:03   #363
Thanked: 89 Times
I'm also looking for USB extension cable for routing it thro' A-pillar. If you get hold of it, please update here.
TheIndian is offline   Reply With Quote
Old 9th June 2015, 16:43   #364
::CMS::'s Avatar
Thanked: 464 Times
I would suggest its pretty difficult to find a compatible usb cable. Instead get the 12v power near the camera and use a 5v DC-DC converter + a normal usb cable.
::CMS:: is offline   (1) Thanks Reply With Quote
Old 9th June 2015, 17:46   #365
mukeshgoel's Avatar
Thanked: 379 Times
Thanks. This looks good?
http://www.aliexpress.com/item/Car-C...113564924.html
But it takes 3-4 weeks normally and 6-7 times out of 10, I don't get the product from ebay.com and aliexpress (they refund the money though, but waste of time)
Also, is it safe having joints in 12v wire near IRVM ?
Any other suggestion ?
Old 10th June 2015, 01:54   #366
Thad E Ginathom's Avatar
Thanked: 7,481 Times
Can you make the cable yourself? If it is not possible (is it?) to get the USB plugs as home-solderable pieces, then just chop ends to match the relevant sockets each end, add extension cable to suit, twist, insulate --- and you're done!
I don't know if the internal conductors are standard colour-coded. When I had to replace a hard-wired USB A on something, recently, the colour coding in the cable that I chopped was the same --- but careful checking of pinouts in theory on the net, and in practice with a meter, would be necessary. You are only talking about the two power carrying conductors, right?
Mind you, although it is not hard with the USB-A end, you'd need a needle-fine meter probe* for a USB Micro plug, and even then it wouldn't be easy.
*Tape on a needle-fine needle!
Old 10th June 2015, 09:41   #367
::CMS::'s Avatar
Thanked: 464 Times
This should be good. Take the power out either directly from the fuse box using a coupler or from the 12v out. Depending on the length you can go for a fuse just before the dc-dc converter. Make sure the joints are proper and covered with heatshrink and use thermal insulation for any roof cabling.
::CMS:: is offline   Reply With Quote
Old 10th June 2015, 14:26   #368
Thanked: 2,390 Times
Another alternative which I have been trying for the past few weeks.
I used my older chinese dash cam's charging wire and bought a mini to micro usb adapter off ebay.
Charger is something like this - http://www.aliexpress.com/item/New-5...227622671.html
Mini to micro USB adapter - http://www.ebay.in/itm/Micro-USB-Mal...item2a5246583b
Haven't really measured the current output with this arrangement but seems to do the job. My guess is it might be a little higher than 500mA at max.
Dry Ice is offline   Reply With Quote
Old 15th June 2015, 10:56   #369
Thanked: 222 Times
A small suggestion:
If you dont have one already, add a micro-HDMI to HDMI cable to your order. (I have plenty of USB cables, but no micro-HDMI - have to search in the camera bag, maybe I have one). I found that this is not part of the package from Puhui Digital.
mvadg is offline   Reply With Quote
Old 16th June 2015, 13:07   #370
BANDHAV's Avatar
Thanked: 263 Times
Originally Posted by BANDHAV View Post
I bought mine directly from Sjcam site, costed me 99 dollars. Shot a lots of video and photos on my recent trip to HK. The battery lasted me a full day with extensive usage. I used a class 10 32 gb memory card of sandisk, at full HD recording the card is good enough of 4.30 hrs of recording. I am glad I picked this up over a go-pro. A superb VFM.
One of the video I shot with SJ4000 during my HK Disneyland visit, request you to ignore the audio, few words needs to be beeped but I have absolutely no idea how to. Sorry.
BANDHAV is offline   Reply With Quote
Old 17th June 2015, 20:04   #371
.. request you to ignore the audio, few words needs to be beeped but I have absolutely no idea how to. Sorry.
It's pretty simple actually in VLC.
1. File tab
2. Convert/Stream >
2.1. Open media - choose your file here
2.2. Choose profile > customize > Audio codec tab > Uncheck audio
2.3. Choose destination > enter location to save the audioless video
3. Go
That's it!
Dry Ice is offline   (1) Thanks Reply With Quote
Old 17th June 2015, 23:23   #372
tsk1979's Avatar
Thanked: 15,685 Times
Open video in "Audacity" audio editor.
The audio will open. You can delete parts you do not want from the audio then save audio as a separate mp3. Then in youtube, you can give this mp3 under replace audio option.
Last edited by benbsb29 : 18th June 2015 at 05:16. Reason: Removed embedded video from quoted post.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 17th June 2015, 23:55   #373
Klub Class's Avatar
Thanked: 956 Times
The video you shared is private
May be you should change the privacy settings or upload the video after making edits suggested by Dry Ice and tsk1979
Klub Class is online now   Reply With Quote
Old 25th June 2015, 11:56   #374
Thanked: 141 Times
Bought SJCAM Sj4000 WIFI during the sale some time ago from puhui digital. Received it yesterday. Finished watching about it here
http://www.techmoan.com/blog/2014/9/...fi-review.html
Time to hook up and observe the results.
etrast75 is offline   Reply With Quote
Old 28th June 2015, 18:39   #375
Thanked: 89 Times
Guys,
A basic query. Any idea how to lock/ protect a video clip in SJCAM4000 so that it won't get overwritten? There were a few clips I accidentally locked but don't know how I did it
In-car Camera mounts - Attaching a video camera to the Car im_srini Modifications & Accessories 75 18th October 2017 21:37
Transcend DrivePro 200 Review - Dash Cam / DVR SirAlec In-Car Entertainment 166 7th September 2017 15:30
Mobius Action / Dash Cam - An extended review tsk1979 In-Car Entertainment 10 27th April 2015 12:38
Chevy Cruze - Front Camera, Rear Camera, and Stronger White Headlamps? darthvader Modifications & Accessories 31 9th February 2014 21:18
Get Well Soon Yatharth(YC.BALENO.CHD) Update: Back in Action :) akshay4587 Shifting gears 205 14th July 2011 12:22
