Old 6th July 2006, 01:59   #1
929RON's Avatar
Default More Impedance Doubts
Now here comes another situation
Suppose I have 2 amps each 800 RMS @ 2 Ohms,
If I take the subwoofer +,- output wire from each and connect it to same +,_ speaker pins, then does the output become 1600 RMS @ 2 ohms or what is it if what i am saying is not correct,
If I am right and I add a same third amp then it increases to 2400 RMS @ 2 Ohms?
If I had 2 subs 800 RMS each Dual 4 Ohms, then ideal way to have the subs connected is,
Sub1(Coil1=Coil2)||Sub2(Coil1=Coil2) ??
Glossary :
= (series)
|| (parallel) (all of our gurus will know this, but I have specified for those who don't )
929RON is offline   Reply With Quote
Old 6th July 2006, 02:20   #2
Thanked: 21 Times
This should help you...
http://www.team-bhp.com/forum/124461-post1.html
there are already a few threads on this subject, including one that you started recently. Please use the search feature befor posting new threads.
Re your amp question... that called 'Strapping' multiple amps. No thats not possible unless your amps support strapping... which mostly really high end ones do.
Old 6th July 2006, 10:51   #3
navin's Avatar
Thanked: 4,284 Times
Glossary :
= (series)
why? do your subs need that much power?
Old 6th July 2006, 11:54   #4
kb100's Avatar
yeah Ron... This way we can go aroundin circles endlesly... If you can be clear what is it you exactly want... as in what kind of sound you are looking for.... SQ .. SPL ... and a budget... then the maybe the suggestions will be more forthcoming... equipment is ALWAYS Goal Oriented!!
kb100 is offline   Reply With Quote
Old 6th July 2006, 12:01   #5
Thanked: 21 Times
ahhhhahahahayayahahahahahyayaahahahaha FOMCROTFL
Old 6th July 2006, 12:17   #6
Thanked: 21 Times
Navinji nowdays this has become the formula:
small enclosure + low bass capabilities + low sensitivity = high excursion design + high power handling + cheaper powerful class D amps = bass sounds like a cow mooing away trapped in a well.
Old 6th July 2006, 12:22   #7
kb100's Avatar
Originally Posted by gunbir
FOMCROTFL
... yeah... sheer hard fought experience that !!..
... expand that pls...
AND come and help install ... everyday a new dream.. I have turned into a gargoyle!!
Old 6th July 2006, 12:37   #8
Thanked: 21 Times
FOMCROTFL = Fell off my chair, rolling on the floor laughing...
Old 6th July 2006, 14:01   #9
navin's Avatar
After all the advnaces in Materials, measuring techniques (like FFT) and Computer Aided Design I would think speakers would get better.
A question about impedance adityamunshi In-Car Entertainment 3 13th October 2007 13:36
Impedance of Subwoofers 929RON In-Car Entertainment 36 31st August 2006 14:28
Subwoofer Impedance 929RON In-Car Entertainment 11 29th July 2006 20:05
Doubts qqplus Technical Stuff 15 10th February 2006 23:20
Doubts abt airbags speedsatya The Indian Car Scene 4 5th September 2004 13:20
