Old 14th July 2006, 00:47   #16
airfoil's Avatar
Thanked: 67 Times
Sam, what are those holes drilled (and later filled) for?
airfoil is offline   Reply With Quote
Old 14th July 2006, 06:44   #17
jkdas's Avatar
Thanked: 1,436 Times
Originally Posted by Sam Kapasi
JK, this cannot be done with cars where there is a little lever to adjust the mirror. However in the case of a powered mirror, if the inner panel of the tweeter can be removed and is clear behind (like for example the lancers with power windows) then yes, why not.
sorry boss, forgot the "t" in the can
Old 14th July 2006, 09:46   #18
k36
k36's Avatar
Thanked: 19 Times
Thanks Sam for the idea!
Though I cannot do this in my swift because of the mirror adjustment levers, the idea of using filler+cloth to improve interiors is GREAT.. and opens the door to numerous new possibilities
k36 is offline   Reply With Quote
Old 14th July 2006, 09:52   #19
navin's Avatar
Thanked: 4,286 Times
Nice one Sam. It increases my options for which car to buy. Previously I used to only buy cars which had front tweeter pods and motorised mirrors.
As far as reducing treble is concerned I can see of a even nicer way....add these steps to the procedure where required.
a) cut of most of back of cup before super gluing it to the panel
b) use grill cloth that is a bit less acoustically transparent. you can test this by putting this over the tweeter and listening to it.
c) cover that part of the grill cloth that covers the cup cavaity with paper or tape (to be removed later) to protect it from the loctite and putty.
d) cut hole in mirror panel to mate with the hole made in the cup of tweeter (which is stuck on mirror panel).
e) install tweeter from the rear and use grill cloth (after you remove tape/paper sheild) as filter.
Old 14th July 2006, 11:08   #20
Sam Kapasi's Avatar
Thanked: 1,473 Times
These holes are made so that you can inject the filler into the cavity between the cloth and the panel itself
Like this.
Old 14th July 2006, 19:02   #21
kb100's Avatar
Therefore to make it solid???
kb100 is offline   Reply With Quote
Old 14th July 2006, 19:34   #22
condor's Avatar
Thanked: 4,907 Times
Yes - compare the first and last pics. Using the cloth and the glue with it creates a new shape. Filling the gap inside / below the cloth makes it solid.
Sam - thanks for this.
Old 15th July 2006, 02:03   #23
929RON's Avatar
THANK YOU SAM !
929RON is offline   Reply With Quote
Old 17th July 2006, 16:29   #24
kURETI's Avatar
good oneeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
kURETI is offline   Reply With Quote
Old 18th July 2006, 15:22   #25
esteem_lover's Avatar
Thanked: 451 Times
great sam....could this modification be tried on the door pads also, since i have an internally adjustable mirror ???
Old 18th July 2006, 15:24   #26
Sam Kapasi's Avatar
Yes, I suppose it could. But where will you hide the ends of the cloth used for shape?
Unless, you mount the tweeter cup and then re-mount the upholstery on the door panel.... hmmm.....
Old 17th August 2006, 20:57   #27
Thanked: 27 Times
what car was used for this pictorial Sam? do you know anybody who can do this in Hyderabad with the same professionalism?
wannabelean is offline   Reply With Quote
Old 28th May 2007, 22:22   #28
Sam, a dumb question- can't we flush mount the tweeter behind mirror?
santosh.s is offline   Reply With Quote
Old 31st May 2007, 11:04   #29
gopz's Avatar
Great work Sam, keep posting more such DIY stuff!
gopz is offline   Reply With Quote
Old 31st May 2007, 12:37   #30
headers's Avatar
Thanked: 464 Times
great work sam..I've my tweeters in a similar position on the doors..will post pics soon..!! Infact i've seen this being done by many installers..but did not take pics and i guess i cannot explain as clearly as you've done..
Great JOB!
What's your technique when driving uphill? kapilsharma80 Drive Safe 162 12th March 2018 14:23
Door mounting depth & mounting hole dimensions donarun In-Car Entertainment 5 11th August 2011 18:49
My Driving technique- right or wrong? BUXX Technical Stuff 40 6th October 2007 02:54
Which technique for tubeless tyre punctures? cutdcrap Tyre & Alloy wheel Section 15 4th October 2007 01:53
New technique to fight piracy-Degrade quality. rahul_intlad Shifting gears 5 23rd January 2007 09:51
