Old 16th September 2006, 09:59   #181
navin's Avatar
Thanked: 4,282 Times
JB, I think I have seen crutchfield selling adapters for the Honda dash.
Old 16th September 2006, 10:25   #182
Thanked: 294 Times
Originally Posted by navin
It is just hat the sub's T/S specs have to suit IB
which factor in T/S spec does make the effect....
Old 16th September 2006, 10:57   #183
Autophile's Avatar
I have used OEM adapters for Accord and Merc C Class in the past. I don't think any manufacturer has come up with OEM adapter for new civic.
Autophile is offline   Reply With Quote
Old 16th September 2006, 11:27   #184
navin's Avatar
maybe these can help...
http://www.crutchfield.com/S-EeWqLn0...0&I=003HONK809
http://www.crutchfield.com/S-EeWqLn0...52&I=003UPK750
Old 16th September 2006, 11:54   #185
Thanked: 21 Times
Navinji, those are for old gen Civics. As far as we knowm there are no dash adapters for the new Civic.
Old 16th September 2006, 12:01   #186
ST7677's Avatar
Thanked: 45 Times
a) I agree with Autophile. IB subs can be as tight as sealed. It is just hat the sub's T/S specs have to suit IB. I assume the sub used in the Accord does. The factors that also dictate the subs performance is sealing of the baffle as well as the trunk. I had a heck of job doing this in the poorly designed contessa (ended up going for TL) but with a car like the Accord or Superb it can be QED.
How does one ensure that the baffle and trunk is completely sealed?
I know about Dynamat and it's general application (thanks to t-bhp). I wanted to know that in this/similar case what all is damped and how.
JB, do you have pics of any similar install?
Finally what is TL (as mentioned by Navinji). Hope the explanation will not end up being like butterworth
ST7677 is offline   Reply With Quote
Old 16th September 2006, 12:17   #187
Thanked: 230 Times
I think I mentioned it in another post, but here it is again: http://www.8thcivic.com/forums/showthread.php?t=3534
It seems very hassly, but maybe worth it in the long term.
ST7677, the easiest solution in the short term may be to simply change the rear speakers to better 6x9 co-axials. Then once all these parts and stuff start becoming available, you can upgrade as budget/time permits. No point in letting your car be guinea pig.
Second, EX models in US come with sub in parcel tray as OEM, with same HU. So somewhere there should be a line out in the OEM unit.
sandeep108 is offline   Reply With Quote
Old 16th September 2006, 12:23   #188
Bass&Trouble's Avatar
Thanked: 71 Times
Nope, the Indian civic head unit does not have a line-out. I have opened up a civic head-unit (trust me it's plain painful), only to realize that the effort was quite futile.
In most cars that have a OE sub, there are no pre-outs in the head units. The subs are usually efficient and light DVC subs powered with two channels of the head unit itself, and not an external power amplifier. I don't know about the EX Civic in the US.
Old 16th September 2006, 12:40   #189
Thanked: 294 Times
I am asking again....which T/S spec makes the difference........
Old 16th September 2006, 12:48   #190
Thanked: 71 Times
Vas... Vas... Vas.
20 Charachters
Old 16th September 2006, 12:56   #191
Thanked: 294 Times
Originally Posted by Bass&Trouble
Vas
what would be the ideal value to make the sub capable for IB.....may be above 125 liters.....(4.41 cuft).....
Old 16th September 2006, 13:06   #192
Thanked: 71 Times
You haven't specified the subwoofer size. If you take a 12" for instance, it's good to have it between 30-50 liters so that the sub does not suffer mechanically.
Old 16th September 2006, 13:14   #193
Thanked: 294 Times
Ok if the size taken 12 inches then the vas confidering 30-50 liters would do a nice job.....but if the vas is more than 100 then it is better.......
Old 16th September 2006, 13:41   #194
Thanked: 71 Times
Ok if the size taken 12 inches then the vas confidering 30-50 liters would do a nice job.....but if the vas is more than 100 then is it better?.......
Well, not really. That's very high for a free air sub. Although some guys do have it that high, it's going to have lower power handling for sure.
Old 16th September 2006, 15:22   #195
Autophile's Avatar
Hertz Air Mille series subwoofers were designed to use in Free Air / IB application.
Vas of Air Mille subs are mention below :
ML2500 : 17.3 L
ML3000 : 44 L
ML3800 : 131.9 L
ML5400 : 613 L
All these subwoofers offers phenomenol perfomance and excellent SQ in free-air / IB install.
Honda City Vs Honda Civic E Vs Honda Civic V (pre-owned) drkunaldas Sedans 4 31st October 2010 18:07
Active Subwoofer vs Free Air/Enclosed Subwoofer Epic In-Car Entertainment 2 2nd December 2009 10:59
Advice for Engine enhancements/ mods - 5 Speed MPFI M800 gopz Modifications & Accessories 10 11th September 2007 12:55
Audio enhancements needed for Safari Dicor. Dragonov In-Car Entertainment 14 7th October 2006 14:41
