Old 20th July 2006, 18:39   #31
karthik247's Avatar
Thanked: 16 Times
Will post a pic of the sub 2moro when i remove it to check the wiring done. I'm sure the sub has four input connections.
They are working fine now. Issiue with the amp is no longer there. Anyways, its better i get it checked.
karthik247 is offline   Reply With Quote
Old 20th July 2006, 18:40   #32
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by jkdas
guys, its not the AW122N sub for sure. Its a dual coil sub.
p.s.: amps not overheating now after I tuned the amp last eve. This info was conveyed to me my karthik just now. I had to rush back last eve after I tuned teh amp.
B&T; what sub would it be frm pix? i wasnt with him during install and hence need info abt sub.
and if I am right the amp is stable at 800W @ 2ohm and 400W @ 4ohm
Wow, if it isn't the AW122N, then it sure as hell has to be the AW1200N. That's the only other sub from the various lines which is a 12" and has a basket as seen in the pic, and a paper cone. And that guy is a dual 4-ohm sub.
So, if you connected all 4 voice coils (since you have 2 subs) in parallel to the 8000s output, that amp is prolly calling 911 right now. If you connected only one coil each from the subs to the amp, it's operating at rated output at 2 ohms i.e. 800W rms, but all of the brunt is being borne by just half of each subwoofer (since the rated power handling of the sub is 700Wrms, it is safe to assume that each coil is designed to handle a max of 350W rms thermally, so you're 50 watts over rated power per operational coil). Besides these two, the only load you could get using 4 coils will be 4 ohms, and the amp wouldn't have any hassle driving the subs, except that that's too little power for two big guys like that, i.e. 200 watts per sub. You guys have some figuring out to do.
Old 20th July 2006, 18:46   #33
karthik247's Avatar
Thanked: 16 Times
Just got it cleared....
SUBS Aw-122N
4ohms, 550W RMS, Single Coil but 4inputs.
AMP A8000T
Max output at 2ohms.
Hope i got it right, spoke to the guy from whom i got the stuff!
Old 20th July 2006, 18:51   #34
karthik247's Avatar
Thanked: 16 Times
This helps???
Old 20th July 2006, 18:59   #35
Thanked: 71 Times
Originally Posted by karthik247
Just got it clears....
SUBS
AMP
Lol, that's not 4 inputs. There are 2 input lugs each for the positive and the negative.
The two terminals on the right are both positive and connect to the same coil internally. Likewise for the two terminal on the left, which are the negatives. This option is offered if you want to wire the sub with 2 smaller gauge speaker wires rather than one of a larger gauge, that's it. If you take them to be seperate voice coils and connect them to different channels of amplifiers, that'll be like off-season Diwali. You're lucky you have a mono amp, so you can't try that option.
Old 20th July 2006, 19:00   #36
Thanked: 71 Times
My sub looks better than yours .lol
Old 20th July 2006, 19:49   #37
kb100's Avatar
SEXY looking Sub!.... All that chrome!!
kb100 is offline   Reply With Quote
Old 21st July 2006, 07:33   #38
jkdas's Avatar
Thanked: 1,389 Times
it sure is sexy! have to flaunt it and use some neons too.
And hope the amps seeing a 2ohm load rather than a 8ohm load. I am afraid of all installer unless I am with them when they do it or I get to got the wiring part.
Old 22nd July 2006, 01:57   #39
Tool's Avatar
heheh yep.. SEXYYYY looking sub... that i will give it
nice functional install bro.. many many congratulations... Flaunt those looks baby... congrats again bro...
Tool is offline   Reply With Quote
Old 22nd July 2006, 18:39   #40
karthik247's Avatar
Thanked: 16 Times
I'm getting the damping and the rest of the work done 2moro. So any suggestions/advices???
Old 22nd July 2006, 18:46   #41
Thanked: 16 Times
Get a strap-on for the boot so that it does'nt fly away with bass!
Damp each part as needed. Use your ears, fingers and whatsoever (I am not being obscene here) to feel the unwanted sounds and Just eliminate it. Also seal your boot door insides.
And after you're done with the damping check the weight increase it does to the car and get some extra engine mods to solve all the performance loss. LOL!!!
Old 22nd July 2006, 18:54   #42
karthik247's Avatar
Thanked: 16 Times
I've got that covered
Hope the boot doesn't become too heavy, if so i'll think about hydraulics
Old 23rd July 2006, 23:03   #43
karthik247's Avatar
Thanked: 16 Times
Whew! Just got home after getting 90% of the install done today. Looks very neat, never expected someone in TVM do so sumtin like this. All the vibrations are gone. Have some more finishing touches to do 2moro, till then here are the pix...
Old 23rd July 2006, 23:08   #44
karthik247's Avatar
Thanked: 16 Times
Old 23rd July 2006, 23:12   #45
Thanked: 294 Times
waiting for the complete install pics man,
what is that stuff with holes in it.....
JBL vs Audiobahn Woofer - What is Better? libre sito In-Car Entertainment 29 8th September 2008 13:30
Audiobahn 6X9 (3 way) speakers for sale.... panky12345 Shifting gears 6 23rd October 2007 18:43
Kicker AMP with MB Quart Comp and Audiobahn madbullram In-Car Entertainment 15 20th August 2007 01:31
Audiobahn Special Edition Woofer buzzin_hornets In-Car Entertainment 2 23rd March 2006 14:11
