Old 23rd July 2006, 23:14   #46
kb100's Avatar
What are those on the trunk lid... Crossovers??... if so for which speakers???
What kind of damping mat is that white thing you have used...?? .. and how much did it cost you??
How is the amp treatment??
kb100 is offline   Reply With Quote
Old 23rd July 2006, 23:23   #47
karthik247's Avatar
Thanked: 16 Times
Amps are neatly installed in those custom made plywood enclosures. Crossovers are on the boot door. Damping is done using that foam, waste cloth and sheet. Plywood is also used in some places like on the boot door and is covered with carpet.
Better pix will be up 2moro....
So hows the install?? Any changes or anytin to be made???
karthik247 is offline   Reply With Quote
Old 23rd July 2006, 23:23   #48
Thanked: 295 Times
KB yaar I guess the white stuff is looking like the foam used in sofa cushion thats why I am asking what is that ???????
Yaar what is this "amp treatment" ?????????????
Old 23rd July 2006, 23:29   #49
karthik247's Avatar
Thanked: 16 Times
Yea that is the normal cushion type foam used. Over it there is a sheet, over it the amp. A lot of waste cloth was used on the boot door that it cannot stay up. It closes automatically . Planning to use Dynamat on it, or do sumtin elz like a stand or a hydraulic setup
Old 23rd July 2006, 23:34   #50
Thanked: 295 Times
Off the Topic -> you are refering to hydraulics twice in ur posts do you know about it are related to hydraulic in any way...
Old 23rd July 2006, 23:36   #51
karthik247's Avatar
Thanked: 16 Times
The boot door is heavy, and it'll close unless someone holds it up (its not THAT heavy). So the last thing i want is it falling on mine/someones head
If u have any ideas, share them.
Old 23rd July 2006, 23:41   #52
kb100's Avatar
Does look very well done Karthik.... I give you that!
I honestly dont know about he materials used... Would Wurth not been an equally cheap and cost effective option - Yet neater?
The amps look well done!... But hope they have not seated it on foam... bad news viz cooling.. hey has that amp heating problem been resolved?
Old 23rd July 2006, 23:43   #53
kb100's Avatar
LBM... I was asking how were the amps positioned and installed.. any neons... pexiglass...etc etc... in other words how the 'Treatment" was..
Old 23rd July 2006, 23:44   #54
Thanked: 17 Times
Zuhemi's car got the same problem. And He made a small peice of metal pipe with a hook and it is used to hold the door up when open.
Old 23rd July 2006, 23:46   #55
karthik247's Avatar
Thanked: 16 Times
No no no...amps arn't done in foam. See post #43, first pic. A carpet is pasted inside that box and the amp is fitted on it.
Yea amp heating issiue solved now. Works just fine at the moment. Only thing is the spoiler still rattlers a wee-bit.
Whole setup, including damping, installing, cables, fuses, everyting is arnd 6k.
Old 23rd July 2006, 23:51   #56
kb100's Avatar
Heating solved??... how... what was the issue ... ??
Old 23rd July 2006, 23:58   #57
Thanked: 295 Times
Have u changed some thing to boot door or some like that it has become heavy.
In a normal case there are two twisted rods attached on both the ends of the boot levers so that the boot can stay in position and would be easy to lift because of the spring action of the rods. (hope u would understand)
Have u removed them kya. which makes the boot heavy.
Old 24th July 2006, 00:09   #58
kb100's Avatar
Yeah.. I suppose one could always try to retrofit some hydraulic arms - like the ones used in hatches..
Old 24th July 2006, 10:47   #59
karthik247's Avatar
Thanked: 16 Times
Nope..its become heavy cuz we used waste cloth to damp it and then used plywood to fit the crossovers. Nutin has been done to the levers. Its just that the weight is a bit too much for the springs to handle. It will stay up, only if someone holds it like that.
Old 24th July 2006, 10:52   #60
Thanked: 295 Times
Kb they are not hydraulic type of cylinder. They are spring loaded with some liquid filled them, when the boot is opened the liqiuid starts to follow from a slow oriffice which make the spring to open slowly which in turn allows the spring to open smoothly without any jerk thats all.....
For lancer he would have to do some thing else.
When I have esteem I had installed two 12 inch rear shelf and I had to remove that two spring rods which i was taking in the earlier post which also made the boot very heavy, it could not be lifted with one hand. so when i used to open the boot I made a drive in the supporting bars in the complete open position and put a rod in between so that it does not fall down.... will try to put some pics If i have....but this is again a desi juggar.....lol
karthik So i think leave it as it is, if u do change some thing it will lead to some other complication.....
JBL vs Audiobahn Woofer - What is Better? libre sito In-Car Entertainment 29 8th September 2008 13:30
Audiobahn 6X9 (3 way) speakers for sale.... panky12345 Shifting gears 6 23rd October 2007 18:43
Kicker AMP with MB Quart Comp and Audiobahn madbullram In-Car Entertainment 15 20th August 2007 01:31
Audiobahn Special Edition Woofer buzzin_hornets In-Car Entertainment 2 23rd March 2006 14:11
