Old 30th July 2006, 12:29   #16
Thanked: 21 Times
Originally Posted by lamborghini
Hey Gunbir,
went through the thread. Quite alot of useful information. Everyone mostly gets it cut through the Din plate but i'll remember to tell him to open the console and unscrew the plate and put it.
Also Autophile says that for Getz one should get a component set in the front and Co-ax in the back.
Would it be a better bet then the Co-ax all around?
We wouldn't be putting an amp or a Sub.
Of course, a component set is always better. As you may know, higher frequencies are highly directional... The tweeters need to be somewhere your ears can see them.
In most cars with stock door locations, coaxials would just 'fire' into your feet, giving your shins great sound... problem is, your ears would appreciate those frequencies better... So get components for the front. The midbass would go into the door and the tweeter on the dash, next to the A pillar. While a component costs more than the coaxial from the same series of product, It is worth the extra $$$
Old 30th July 2006, 13:12   #17
rsjaurr's Avatar
Thanked: 27 Times
As u will not be installing amplifier & subw,i would recommend 6x9 at rear with components at front for better sound.
Pio HU 6000
front 6.5" components 6000
Rear 6x9" on tray 7000 or coax for abt 3000 if cant increase ur budget.
wiring+install 500.
Go for JBL,alpine or Hertz brand for speakers.
Some HU wont be able to play spkears rated at 2ohm like alpine HU.So u can buy HU with more internal amp power like pioneer.
I would prefer speakers rated at 2ohm but then power them using amplifier rather than from HU.
rsjaurr is offline   Reply With Quote
Old 30th July 2006, 18:22   #18
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by anToNIcHeN
you may want to keep in mind that GTO 637 are rated at 2ohms impedence...
make sure that HU's internal amp is stable at 2 ohms.... (most cases HU's internal amps are 4ohm stable...)
by fitting 2ohm speakers to HU, might damage the HU on long run....
regards,
ant.
You'll run into trouble with 2 ohm speakers if you're doing a tri-mode connection on a 2-channel amplifier stable down to 2 ohms in stereo, and connecting a 4ohm sub.
Most HU manufacturers also rate the internal power amp to be stable upwards of 4 ohms, I'm not really sure how they manage the 2 ohm load, especially if it's on all 4 channels. But if Sam says they do just fine, I'll buy that.
Sam, are you sure the midbass driver of the speakers in concern are 2 ohms, or just maybe a tweeter or mid? Well, nominal impedance is usually with reference to the woofer, but just confirming. If it's just the mid/ hf section, it shouldnt be too much of a problem, but if the woofer has a 2 ohm v/c then i'm pleasantly surprised.
Old 30th July 2006, 23:22   #19
Sam Kapasi's Avatar
Thanked: 1,473 Times
You are right B&T, no big surprises here lol, the effective impedance is around 3.2 ohms.
Old 31st July 2006, 11:52   #20
Thanked: 26 Times
hey sam,
are you sure that 2ohm rating is not the effective ohm rating?
or its just the woofer impedence?
regards,
ant.
anToNIcHeN is offline   Reply With Quote
Old 31st July 2006, 14:07   #21
Thanked: 294 Times
One thing for sure this 2 ohms rating speakers are taking full sweat out of those fake alpine......
Old 31st July 2006, 17:29   #22
navin's Avatar
Thanked: 4,286 Times
not really LBM these speakers are effectively 3.2 ohms!
Old 31st July 2006, 17:34   #23
Thanked: 294 Times
navin ji i have heard a setup with jbl 2 ohms ovals plus one subs connected to a 4 ch fake alpine. the amp was begging for mercy as it was getting very hot and start trippin when play at a moderate volume also....
Old 1st August 2006, 11:17   #24
navin's Avatar
You are more egalitarian than me LBM!
Old 1st August 2006, 11:24   #25
Thanked: 294 Times
oh ho navin ji i am just telling my comments about my experiances.......
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13667 19th July 2018 16:52
Audio in TV less costlier than car audio? LNG In-Car Entertainment 4 2nd August 2010 12:11
Car Audio set up for Palio 1.2 bangboy In-Car Entertainment 25 12th July 2006 11:28
