Old 29th July 2006, 18:40   #1
lamborghini's Avatar
Thanked: 1,695 Times
Default Car Audio Set up for Getz
Hey guys,
My cousin is buying a Passion Red Getz soon and is intrested in getting an Audio Set up for the car.
Budget is 15K.
What do you guys suggest?
A plain and simple system with a good HU, good speakers.
He doesn't want any amps or Sub as there isn't enough space.
Please advise Audio Gurus.
Thanks.
lamborghini is offline   Reply With Quote
Old 29th July 2006, 19:50   #2
jkdas's Avatar
Thanked: 1,437 Times
Think Getz takes 6 inches all around. Stay with Co-ax and a decent HU for 15k limit.
Old 29th July 2006, 20:00   #3
I read somewhere that the Getz can take upto 6.5 inches.
Does JBL make co-ax and would they come in the budget?
How are the GTO637 and how much would they cost?
Old 29th July 2006, 20:09   #4
jkdas's Avatar
6.5 maybe. Lazy to search around
JBL makes co-ax.
for the rest of your queries
http://www.team-bhp.com/forum/car-en...m-scorpio.html (Music Sytem for Scorpio)
edit:
@6k; decent Pio HU @ grey prices. or Blau HU @ B&W
Old 29th July 2006, 20:10   #5
Sam Kapasi's Avatar
Thanked: 1,490 Times
GTO637 costs Rs.3990/- per pair.
Old 29th July 2006, 20:14   #6
Thanks Jk and Sam,
This is what i was thinking of suggesting to him.
2 pairs of the GTO637 for around 8K, a good HU for aroung 5.5K and then the remaining on wiring and installing.
How is the JBL in terms of bass and clarity?
Any good HU that you guys suggest?
Old 29th July 2006, 20:39   #7
Thanked: 26 Times
you may want to keep in mind that GTO 637 are rated at 2ohms impedence...
make sure that HU's internal amp is stable at 2 ohms.... (most cases HU's internal amps are 4ohm stable...)
by fitting 2ohm speakers to HU, might damage the HU on long run....
regards,
ant.
anToNIcHeN is offline   Reply With Quote
Old 29th July 2006, 20:58   #8
Thanks anToNIcHeN ,
will remember that when i go and look for a new HU.
Old 29th July 2006, 21:27   #9
jkdas's Avatar
regards,
ant.
Sam, can you confirm taht?
Old 29th July 2006, 23:22   #10
Sam Kapasi's Avatar
I don't want to start any techie debate, but i'll say this.
Whenever any company makes ONLY speakers and no HU, they will make sure it's compatible to all commercially available head units. Think about it, what other choice do they have?
If anyone would like a white paper on this and would like to study this further, PM me your email addy
cheers
Old 29th July 2006, 23:28   #11
So you are saying that i do not have anything to worry about?
How is the CS series?
Old 29th July 2006, 23:37   #12
Sam Kapasi's Avatar
Yes I'm telling you that using your HU, one pair 637 in the front and one pair in the rear is no problems at all.
I explained about the GTO and CS series here
Old 29th July 2006, 23:44   #13
Thanks alot Sam.
Think we'll go with this set up.
Is there any good HU that you guys would recommend?
And would there be any difference in quality if we put the same speakers in the rear and front?
Old 30th July 2006, 00:34   #14
gunbir's Avatar
Thanked: 25 Times
Hey guys,
My cousin is buying a Passion Red Getz soon and is intrested in getting an Audio Set up for the car.Please advise Audio Gurus.
Thanks.
This should be of use to you... http://www.team-bhp.com/forum/car-en...highlight=getz (Hyundai Getz - Install Help)
Old 30th July 2006, 11:20   #15
Hey Gunbir,
went through the thread. Quite alot of useful information. Everyone mostly gets it cut through the Din plate but i'll remember to tell him to open the console and unscrew the plate and put it.
Also Autophile says that for Getz one should get a component set in the front and Co-ax in the back.
Would it be a better bet then the Co-ax all around?
We wouldn't be putting an amp or a Sub.
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13689 14th August 2018 19:19
Audio in TV less costlier than car audio? LNG In-Car Entertainment 4 2nd August 2010 12:11
Car Audio set up for Palio 1.2 bangboy In-Car Entertainment 25 12th July 2006 11:28
