Old 3rd August 2006, 00:11   #16
929RON's Avatar
Plan as of now is for Sealed Enclosure, now the no partitions thing I have to Speak to the installer, but the plan is basically to save space and at the same time Have tight bass, this is not an SPL setup, my friend just wanted a midblowing setup which looks really cool too.
Amp and subs already bought and I don think he will invest into another 20001bd now, also that amp has actualy power rating on the chart of nearly 2800 RMS
so, any more than that the Audiobahns will Blow probably with any hitch in tuning.
929RON is offline   Reply With Quote
Old 3rd August 2006, 00:49   #17
Thanked: 295 Times
in which car u r going to install the three subs.
even if the birth sheet says 2800 watts that is at 14.4 volts which is rarelly achived at full volume but any ways this amp can easlily drive 3 subs easily but again not to full extent......
Old 3rd August 2006, 00:51   #18
929RON's Avatar
Yeah you are absolutely right, Car is a Skoda RS
Old 3rd August 2006, 10:48   #19
Audiobahn ALUMs are pretty sensitive...hence one T20001bd is enough for three of them.
Autophile is offline   Reply With Quote
Old 3rd August 2006, 12:07   #20
929RON's Avatar
Yep, you right, and whoever knows Audiobahn well will say that,
RF BD amps are coil burners, they produce some brute power, Pure SPL.
Amps like Punch and Type RF are more on the SQ side, Especially Type RF.
Old 28th October 2006, 20:08   #21
Default Amp issues
I have a kenwood kdc5029 hu with 6" JBL cs series speakers in front and the rear speakers are JBLgto937 2ohm speakers. The sound quality was horrible at first so i fixed a sony 2 channel xm-552zr amp for the rear speakers. The sound quality is awesome now but the amp blew in 1 hr of installation so i got it replaced imm. After a month it again blew. What could be the problem...the service guy says that 2ohm speakers should not be used . BUt the amp manual says that it supports 2ohm speakers. Now i also have a 12" pioneer sub which is 4ohms and 300w nominal rating . The amp is still in the serviced centre and it will take a week for it to be ready. Now can i fit the subwoofer also to the amp or will it again blow? Please Help!!
tharunjd is offline   Reply With Quote
Old 29th October 2006, 11:26   #22
blueraven316's Avatar
The amp should not blow, you need to get your wiring checked, mostly the problem might be blowing mosfets, the amp can support 2 Ohm speakers but how were they connected ?
If it was bridged, since this is a 2 channel amp , and when bridged the resulting impedance is 4 Ohms, so if the speakers / sub are at 2 Ohms it's overloading the amp. (bridging is only to use subs, not speakers)
If the speakers were connected in Stereo, then there has to be something with the wiring, find yourself someone who can carry out a full wiring checkup who knows his work.
Cheers.
blueraven316 is offline   Reply With Quote
Old 29th October 2006, 13:09   #23
jCube's Avatar
What price did you pay for the Amp? Was it purchased in India? if so from where?
jCube is offline   Reply With Quote
Old 29th October 2006, 22:58   #24
Since Ron is not around I will pitch in,
20001bds are not avilable easily here, with B&W it would cost about Rs 85k +
without B&W it's not avialable,
Similar power Hifonics BXi2006d amp available for Rs 35k with B&W.
JBL also has a monster amp, the A3000GTi, contact Sam for pricing.
Old 29th October 2006, 23:27   #25
Sam Kapasi's Avatar
Thanked: 1,490 Times
The A3000GTi costs Rs.2.5lacs. One sold in India.
The A6000GTi costs Rs. 4.5lacs. None sold in India. LBM is planning to buy one
Both come with a 7 year warranty.
Old 29th October 2006, 23:32   #26
Thanked: 11 Times
Wow..
When he planned ?
LBM where are you ?
Cheers,
Mugen_Power.
Mugen_Power is offline   Reply With Quote
Old 30th October 2006, 02:18   #27
OUCH ! Thats a lot, but the 7 years make up for it to quite some extent
Old 30th October 2006, 14:48   #28
hydrashok's Avatar
Holy ....! You're joking, right?
Old 30th October 2006, 18:25   #29
Thanked: 295 Times
may be maybe not..............
Old 31st October 2006, 14:10   #30
ankitahuja's Avatar
Thanked: 46 Times
Arrow
One of my friends is fitting a pair of dual 4 Ohms Kicker L5s with a 2 Channel Audiobahn A8002T , the bridged power @ 4 Ohms is 800 RMS, now how should we wire this to get the final Impedance as 4 Ohms, as If we wire S1(C1=C2)||S2(C1=C2) the impedance is 4||4 = 2 Ohms, how do we achieve 4 Ohms, any Ideas ? Can the two subs be wired in series to other ?
Experts, If my calculations were wrong tell me what is right ?
I'd like to add to this one, the Audiobahn A8002T is -
2 x 200W RMS @ 4 Ohm
2 x 400W RMS @ 2 Ohm
1 x 800W RMS @ 4 Ohm
To power a dual 4 Ohms sub, then you will want to wire them in "Series Parallel". Basically you create 2, 8-ohm subwoofers, and run them parallel bridged to the amplifier. This will give you a 4 ohm bridged load at the amplifier, and deliver 400 watts RMS to each subwoofer. This is the only way to power dual 4 Ohm subs from the Audiobahn A8002T as I have done for my pair of Pioneer 306 DVC.
Speaker combination for existing HU & amp CLYDE In-Car Entertainment 11 29th May 2012 11:13
Zen MPFI wiring manual/wiring diagram IndrojitSircar Technical Stuff 1 27th February 2012 00:21
Speed & Gear combination for Chevrolet UVA arunnn Technical Stuff 6 10th December 2007 23:01
OH NO!! Another Ferrari Enzo crashed.. and another... and another (w/ video) GTO The International Automotive Scene 72 26th May 2007 14:09
Another crash, another fire, another death in Delhi suman Street Experiences 7 15th December 2006 15:30
