Old 11th September 2006, 10:44   #316
jkdas's Avatar
Thanked: 1,436 Times
Get a good co-ax or compos for frnt. 4-7k
get a 4 channel amp and power all. 4-6k
rca .75k
Your HU has two preamp outs.
emm, maybe a 4 channel, but , just powering frnt OR rear + sub in bridged mode.
Sub in IB setup is cheap.
Old 11th September 2006, 12:24   #317
navin's Avatar
Thanked: 4,286 Times
Originally Posted by maxbhp
[left]...right now I have A pair of Alpine 6 *9 co-axials (50 rms), a pair of Alpine tweeter ...
So you have a pair of 6x9 in the rear and a pair fo tweeters (nothing else) up front. any idea on the model numbers.
Ok..
a) get some nice components upfront. budget 6K for Alpine Type R or JBL GTO
b) move those tweeters to the rear (we'll get to this later).
c) get a Sony 554 amp Budget 5K
d) get a Pio 306C i a box Budgte 4K.
e) get 2 pairs of Monster interlink Jr. Budget 2.5K
Total about 20K incl. installation and labour should see you with a very acceptable system based on the Alpine HU.
Old 11th September 2006, 12:59   #318
maxbhp's Avatar
Thanked: 65 Times
A L P I N E SPS-690A
A L P I N E SPS-1005
I dont want to spend more than 12 K on the set up coz this itself had cost me 13000 and I want to limit the total cost to 25K . I listen to Country / Light rock / Pop /Reggae / Trance (not frequently)
maxbhp is offline   Reply With Quote
Old 11th September 2006, 13:24   #319
jkdas's Avatar
Ok..
navin, connection audison rca would cost just 1.5k for two and I would recommend it.
why not that jbl cs60.2 at 6k or so? and if he can save 3-4k if he get co-ax and if one's on a tight budget.
Old 11th September 2006, 13:52   #320
navin's Avatar
You cant afford good front speakers as well as a sub for 12K.
Since you have the Alpine SPS 690A in the rear consider Alpines for the front. To save cost can get a pair of Coax Alpine SPS 17 for the front and supplement the HF with the 1005 tweeters. The Alpines should cost you about 4K.
Drive the front speakers with a JBL 60.2 amp which runs about 6K.
JK says the Audisson are only Rs 750 per pair. you will need only one pair.
4K+6K+1.5K=11.5K. Does this work?
Old 11th September 2006, 14:52   #321
maxbhp's Avatar
Thanked: 65 Times
can I drive two components( Alpine SPS 17 ) + sub using a 4 channel amp ? coz a used sub over here wont cost much
Alpine SPS = 4K
4 Channel Amp = 5 K
RCA = 1500 ?
Used sub = 2000 ?
Is it recommendable ? And If I do it , can u jus throw somelight on its pros /cons ?
Old 11th September 2006, 15:05   #322
Thanked: 17 Times
What about getting a 4channel amp, 5.25 components and Pioneer Sub in sealed box?
4channel amp = 4.5K
5.25" compos = 4.5k
Sub = 3k
Old 11th September 2006, 15:12   #323
jkdas's Avatar
Alpine SPS = 4K
4 Channel Amp = 5 K
RCA = 1500 ?
Used sub = 2000 ?
those are c0-ax right?
yes you can run a pair of co-ax/compo + a sub.
Old 11th September 2006, 17:14   #324
maxbhp's Avatar
Thanked: 65 Times
IS there any amp where /i can individually control each channels , and one more thing JK....How do you suggest I connect it from HU ?
Old 11th September 2006, 21:07   #325
jkdas's Avatar
simple yaar, 4 channel amp should haev 2 seperate gain control and filter switch.
get 2 rca and get 4 channel amp.
Old 12th September 2006, 11:11   #326
navin's Avatar
some 4 ch. amps have 4 gain controls. one for each channel.
Old 14th September 2006, 02:22   #327
Planning on a new audio system for my swift VXi just delievered... Window shopped a few installers & i came across for a budget of 12k - 15k max.
1) HU > Pioneer DEH-P4800MP
2) Front > JBL GTO637 - 6 1/2" co-axials on front door
3) Rear > JBL GTO937 - 6" x 9" co-axials - 100 RMS
or
> Boston Acoustics - 6" x 9" co-axials - 140 RMS
I need suggestions from BHP gurus regarding the above config!!!
i was also suggested some other ones like Kicker, MT, and so on...
U need to also understand my budget, as i would progreessing to upgrade later... Need suggestions really soon...
nura666 is offline   Reply With Quote
Old 14th September 2006, 07:05   #328
jkdas's Avatar
or
What would be teh upgrade be? Amp? Sub? Better HU?
Pioneer 5XXX (or 6XXX) series would be a better buy if you wnna add a 4 channel amp and a sub later.
If you are gonna get a sub later, dont buy the 6x9. Moreover for 6x9 you need a MDF tray at rear. If you use 6inch co-ax for rear, you will save money and get a neat install.
Check this in btw
http://www.team-bhp.com/forum/car-en...k-25k-30k.html (basic ICE - systems at various budgets -10K, 15K, 20K, 25K & 30K)
Old 14th September 2006, 11:24   #329
navin's Avatar
or
If I ahd only 12-15K and was looking to upgrade later i'd spend 9-10K on a HU with 3 preouts and 4-6K on a pair of 6" coax or components (depending on how you want to install the tweeters) for the front. add amp(s), rears and sub(s) later.
Old 15th September 2006, 00:22   #330
Well i need a bit of a boom setup too, thats why i thought of a co-axials in the rear to start with instead of 6 1/2" in the rear door. boston / jbl should do a good job for atleast 3-4 months before i can upgrade to amps & subs. This suggested setup would be around 13k including the MDF tray and installation.
My incremental upgrade could be something like: -
>> 3 months later - Add component in the front door later and move the then front door's 6 1/2" into the rear door. i might need an amp for this.
>> 6 months later - Put a sub in the boot & install another amp to drive them.
What do you think jk??? But for this upgrade competely i would need to wait for maybe 6 months atleast due to budget constrains. So the initial setup stays till i reach this.
I'm not really sure of this audigy, cause i'm a newbie in car audio tech. So guide me gurus... awaiting reply soon cause i need to finalize my initial setup towards a journey to blast...
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13667 19th July 2018 16:52
Suggestion with my Old Audio System into new car mezereo In-Car Entertainment 4 29th March 2008 01:49
BlueTooth Car Audio System + Security System venky6009 In-Car Entertainment 1 2nd November 2007 04:45
suggestion for octi - car audio ibe In-Car Entertainment 6 18th July 2005 10:22
