Old 3rd August 2006, 23:26   #61
Thanked: 294 Times
why import when u can buy every thing locally ......
anyway what is ur mood in speakers which one u wanna buy.....
Old 4th August 2006, 07:05   #62
nrajeshkumar's Avatar
There are really many good Bhpians who really help other Bhpians. There where some people give useless comments and hurt people, i really dont know what there intention all about. If they stay away from this good forums would be good, make this forum real successful. This is really have no intention of hurting anyone. if it would have hurt someone, really feel sorry for that.
nrajeshkumar is offline   Reply With Quote
Old 4th August 2006, 10:43   #63
rsjaurr's Avatar
Thanked: 27 Times
$300 just for speakers is indeed very good budget.
Go for focal,infinty kappa series or polk momo series.
what happened rajesh?I dont think if someone said anything bad to u.
And if someone can bring it for u from states,buy from there only.
There r many other ways we can help our politicians to spend our taxpayers money their way.
Did u buy ur iridium locally.........LBM veer!!!!!!
rsjaurr is offline   Reply With Quote
Old 4th August 2006, 10:59   #64
Thanked: 294 Times
Originally Posted by nrajeshkumar
Alpine SPS-17C2 6-1/2" 2-way Car Speakers
Infinity Reference 6012si 6-1/2"Shallow 2-way Speakers
Pioneer TS-A1681R 6-1/2" 4-Way Speakers
Polk Audio db 650 6-1/2" 2-way Speaker
JBL GTO637 6-1/2" 3-Way Speakers
Infinity Kappa 62.7i 6-1/2" 2-way Speakers
Infinity Kappa 63.7i 6-1/2" 3-way Speakers
rajesh from the post i can see that u have a swift. the speakers above u have listed all are coax. i would prefer that u dont go for them any of them i would say that go for a componet kit in the front with tweeter on the dash. also in the above list there are some 2 ohms model so if u plan to run it from the hu itself it can be a problem becasue the hu are only recommend for 4 ohms .......hope this will clear ur doubts
ur budget is 300 dollars get a 100 dollar for rear and 200 for the front componet kit
and again i will say get the speakers from india it will be cheaper and u can listen to them and decided like navin ji says which one is better......
veer dont ask this question ... leave it a mystery.....
Old 4th August 2006, 11:09   #65
navin's Avatar
Thanked: 4,265 Times
My budget is around 300$. Planning to import only the speakers. HU i will get locally. Though I listen to all kind of music, but mostly soft musics...
Why? I think you might get better value if you do the reverse. Import the HU and get speakers locally. besides 2 pairs of speakers are bulkier than a HU.
Old 4th August 2006, 13:56   #66
Thanked: 161 Times
Folks just another question.. i was browsing thru the JBL and infinity websites and found that the price difference between a 6 channel amp and a 4 channel amp is only about $100 (unfortunately no mention of indian prices anywhere). So I wondering isnt it more economical to buy a 6 channel amp (eg: JBL GTO755.6 II - 560 Watt 6-Channel Power Amplifier ) and use 4 channels to power the front and rear speakers and then use the remaining 2 channels in bridge mode to power the SUB. ??
jinu_joseph is offline   Reply With Quote
Old 4th August 2006, 14:51   #67
Bass&Trouble's Avatar
Thanked: 71 Times
A 5 ch/ 6 ch amp would be good option, I haven't seen the model you describe in stores somehow though.
Old 4th August 2006, 15:41   #68
Thanked: 161 Times
There had to be a catch somewhere.. :-) Availability... forgot about that
Sam i understand that your are the JBL/Infinity man. any ideas if this model is available in India and how much does it cost as compared to JBL GTO75.4 II.
Old 4th August 2006, 16:11   #69
Thanked: 161 Times
hey folks how important is damping ?? The thing is expensive.. I noticed on another thread in this forum the following costs posted by Gunbir:
"I think you will need at least 2 sheets (Rs 1250 each) of the high end Wurth damping for your boot area.
For your doors to do a 3 stage damping you will need around 20 sheets of AZcomp Fonomat (Rs 220 each) per front door!
Say another 10 for each rear door. Add to that FonoGel (Rs 2440 per can) where required.
that works out to 14K
Old 4th August 2006, 16:19   #70
iraghava's Avatar
Thanked: 156 Times
Jinu - LBM's setup is a very freakishly high-end setup dedicated to achieving only one goal - SPL. As a result the car has much more vibrations/body panel rattles than a normal setup like yours & thus it needs to be damped much more extensively.
I doubt you would be needing much damping in your setup if any at all. Gunbir would be able to advise you best about it.
P.S. If you compare the total cost of LBM's setup vis-a-vis the outlined budget for damping it's just a small drop in the ocean!!
Old 4th August 2006, 16:33   #71
Thanked: 161 Times
Thanks IR that is a comforting though and the good news is i have upped my budget to 40K by giving up on some other accessories like Alloy Wheels .. hopefully now i should be able to afford the setup. Just waiting for Sam to get back with the costs.
Old 4th August 2006, 16:42   #72
iraghava's Avatar
Thanked: 156 Times
Can you post your final setup again? I think other people would also be able to give you a fair idea of the prices.
P.S. 40k is a pretty decent budget!
And YAY another increased budget in the ICE section
Old 4th August 2006, 17:06   #73
Thanked: 161 Times
My proposed config is like this
1. JBL GTO607C - 160mm (6-1/2") 2-way component system - 2 ohms - 70 Watts - 55Hz - 21kHz
2. JBL GTO627 - 6-1/2" 2-Way Loudspeaker (2 ohms)
3. JBL GTO1204BP Single 12" Bandpass Enclosure with built-in LED illumination.
4. JBL GTO75.4 II - 520 Watt 4-Channel Power Amplifier
5. JBL CS300.1 Mono Subwoofer Amplifier
OR
JBL GTO755.6 II - 560 Watt 6-Channel Power Amplifier (Instead of 4 and 5)
While this is the configuration I think I will go with, i would have liked to go with the configuration below:
1. Infinity Kappa KAPPA60.7CS - Component
2. Infinity Kappa KAPPA62.7I - Coax
3. GTO1204BP Single 12" Bandpass Enclosure with built-in LED illumination.
4. Infinity Reference REF7541A 520 Watt 4-channel amplifier
5. Infinity Reference REF311A 300 Watt Subwoofer Amplifier
OR
Infinity Reference REF5761A 560 Watt 6-Channel Power Amplifier (instead of 4 and 5)
I still havent decided on a HU too many conflicting opinions.
Old 4th August 2006, 18:36   #74
Navin,
My plan is to get the Alpine HU from Europe. I checked out the prices, Alpine DVA 9861(play DVD) cost 350 Euro. And try to get speakers from US.
-Rajesh
Old 4th August 2006, 19:03   #75
Thanked: 21 Times
Damping is very important in some cars (like the Swift). Speedofreak has decent damping in his Swift. Ask him about the difference in sound before and after...
Usually, if you arent doing a BIG install (multiple amps, woofers) then in all probability you wont need much damping. Example, SK456's car has Rs 440 worth of damping...
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13643 21st June 2018 15:59
Suggestion with my Old Audio System into new car mezereo In-Car Entertainment 4 29th March 2008 01:49
BlueTooth Car Audio System + Security System venky6009 In-Car Entertainment 1 2nd November 2007 04:45
suggestion for octi - car audio ibe In-Car Entertainment 6 18th July 2005 10:22
