Old 6th August 2006, 12:30   #91
Thanked: 161 Times
Also jkd i notice you recommended the GTO amp for the sub instead of CS series.. is it so much better than the CS series ??
jinu_joseph is offline   Reply With Quote
Old 6th August 2006, 12:34   #92
jkdas's Avatar
Thanked: 1,436 Times
1) more powerful
2) better tech in it and hence better quality
CS are VFM. I am not good at Infinity pricing. Check the site I gave. I havent heard Infinity and would haev bought it but was short of $$$. Your choice of Infinity looks good.
Whatver you get, do get it done frm a good installer and use good RCA cables and sort.
Old 6th August 2006, 13:12   #93
Thanked: 294 Times
Originally Posted by nrajeshkumar
I'm not sure how the damping is done
first what is damping ?
when a sound system mainly the subs are installed in a car the door rattles the boot rattles to reduce this rattle and extra noise comning out of the vehicle . to reduce and elminte this rattle we damp the car...
here is a link of a international company who make damping products....
http://www.dynamat.com/faqs_faqs.html
hope this help.....
Old 6th August 2006, 13:33   #94
Thanked: 161 Times
While we are on damping.. who does the damping... is it done by the ICE installer or do we have to take the vehicle to a special dealer or something like that.
Old 6th August 2006, 13:36   #95
jkdas's Avatar
installer dude, he will recommend it if he is a good one. lbm can help you too
Old 6th August 2006, 13:47   #96
rsjaurr's Avatar
Thanked: 27 Times
not always JK.....when i got my my system istalled,i did install dynamat extreme myself as my installer had never seen/heard about it before.
Luckily Dy.Extreme was very-2 easy to install and i used my palm instaed of roller.Infact i also thought about using 'belan'[chapati roller] but it was too big for door panels's obstructions.
rsjaurr is offline   Reply With Quote
Old 6th August 2006, 14:05   #97
kb100's Avatar
one can try and use that rubber thingy that the sunfilm guys use too I guess... except the access bit of course..
kb100 is offline   Reply With Quote
Old 6th August 2006, 15:39   #98
Thanked: 294 Times
Yes all the ways can be used it is up to the person who`s car it is .last night I worked till 4 am in the morning to install the iridium.....
jk i would not be of such help as i myself is going for damping and unsure which product to use. so till i have done by my install i am silent till ..... but B&T has given good cheap stuff to go in for damping.....
Old 6th August 2006, 17:44   #99
Thanked: 161 Times
hey cant i replace the Subwoofer and Amp with an Infinity BassLink. ?? how expensive is that ??
Old 6th August 2006, 20:28   #100
rsjaurr's Avatar
Thanked: 27 Times
why not,it all depends on ur budget,availability and ur passion for music.
Have a look at this.....
http://www.crutchfield.com/S-hEtfJxq...k&i=700BASS4CH
BTW,is this a better option [for better SQ] than amp+subw or it is just a space saving alternative like amplified tubes.???
@kb1000000-------- Whats the latest news man,abt ur dream ICW set-up????
Old 6th August 2006, 21:30   #101
Thanked: 161 Times
I am working on the assumption that AMP and Woofer as separate units will be more expensive than a Infinity Basslink and the second thing being that the basslinks driver and amplifier will be better tuned to each other.
Hey is Basslink II available in India ?
Old 6th August 2006, 23:05   #102
Thanked: 294 Times
jinu sahib i would say that first listen to the stuff which ur going to install in ur car. secondly the basslink II is having a 250 watts rms amp for the sub. and the sub is 10 inch square and with passive radiator on the other side. this setup would not be loud enough to please u when compared with a separate amp and sub combination....so do listen before going in this setup also compare the cost also.....
Old 6th August 2006, 23:15   #103
Thanked: 161 Times
LBT.. I intend to.. but I need to get my demo list also finalized.. Currently these are on my to be heard and then decided list:
1. Difference between Infinity Kappa and JBL GTO comps.. Is it really worth twice the price.
2. Difference between Amp and Sub as separate units versus Infinifty Basslink II.
3. With replace 2 way coax with 3 way Coax powered by an amp and see if the sub can be avoided completely.
Old 6th August 2006, 23:37   #104
Thanked: 294 Times
LBT..
this is million dollar question it all depends on ur pocket and ears. I would recommend both of them. because when I got addicted to ICE 15-20 years back i used a 80 rupees local woofer and put it inside a plastic bucket played through a hand made amp based on a TDA4440 ic which costed 250 bucks and used a philips discman to play it and I really enjoyed it a lots but now i have nearly 400k worth of equipment in my car and still not satisfied.....
u will hear the diff when u will hear a amp & sub setup
sub cannot be avoided in any condition if u want a low end touch in ur setup rest the decision is ur as it is ur money ....
Old 7th August 2006, 00:02   #105
Thanked: 161 Times
Wow LBM.. that is a school project kind of setup.. you must have been really proud of it... actually you still must be.. well anyways planning to go for the demo next weekend... the rains ruined my plan this weekend
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13663 18th July 2018 15:51
Suggestion with my Old Audio System into new car mezereo In-Car Entertainment 4 29th March 2008 01:49
BlueTooth Car Audio System + Security System venky6009 In-Car Entertainment 1 2nd November 2007 04:45
suggestion for octi - car audio ibe In-Car Entertainment 6 18th July 2005 10:22
