Old 4th August 2006, 17:54   #1
panky12345's Avatar
Thanked: 149 Times
Default Which is better - Bass tube or s/w?
gyz....which combo is better?
1. alpine mrd-m605 with a pair of pioneer 306C in bandbass
or
2. jabl 300.1 mated to a jbl cs1200T bass tube?
reqt : SPL, but minimal rattling.....
Old 4th August 2006, 19:31   #2
Thanked: 294 Times
Panky bhai u drop down to fbd once i will show u the car with these setup and u can clearly judge which one u want....
but from where are u making the bandpass with pair of subs......
Old 5th August 2006, 08:24   #3
panky12345's Avatar
Thanked: 149 Times
not yet decided, listened to JBL in demo set-up....must say its class!
the guy told me to go for JBL 301.1 mated to bass tube (a new concept for me altogether - SAM bhaiya would be in a better position to explain)
all I heard is subwoofers and thats it!
so the idea behind opening this thread was to get a fair idea from guru logs that what is better, a tube or subwoofer?? and if its tube, why i havent seen many people using it?
Old 5th August 2006, 10:56   #4
navin's Avatar
Thanked: 4,282 Times
Panky not haveing specs at hand I would suggest you compare the 306C to the 306F. It might be that the 306F works better in a bandpass box.
Old 5th August 2006, 10:57   #5
amit_sound's Avatar
uld prefer the second setup i.e. JBL 301.1 with JBL bass tube. Also you have the advantage of using two JBL CS1200T bass tubes with one single 301.1.
The
amit_sound is offline   Reply With Quote
Old 5th August 2006, 11:33   #6
panky12345's Avatar
Thanked: 149 Times
amit: is the tube called CS1200? wont it be better to mate 2 of them with 601.1?
but question is,
1. which one to prefer 1 or 2 in above?
2. which is better in JBL, subwoofers alone in a ported box or bass tube as a whole?
SAM bhaiya, where r u??
Old 5th August 2006, 11:41   #7
Thanked: 294 Times
Ok then the bass tube is for who want a neat and clean install with all brand products and without getting in to the mess for making the enclousre....but the sub in a well desiged enclousre will any day perform better than the bass tube..........
Old 5th August 2006, 11:47   #8
panky12345's Avatar
Thanked: 149 Times
thanks LBM. the guy i went to, told me that Indica has a lot of problem with rattling. It'll rattle like anything if you put in a pair of 306C with alpine 605. [sirdard free of cost] he wanted me to take a JBL CS1200 and JBL 301.1. guy seemed to be good, sachin of Car Man (courtsey Sam bhai). i just wanted to be sure before i go ahead.
Old 5th August 2006, 11:47   #9
Sam Kapasi's Avatar
Thanked: 1,473 Times
I is here only. Reading from hyderabad.
Are you asking me which is betterm Tube or box?
If one was better than the other, we would not be making both! We would just make the better one.
2 different sounds. I use a bass tube in my lancer and I am satisfied with it. If I had a hatchback, i would have preferred a box, it's tight and nice. Hear both ad decide, simple. Sit in your car, wire a monoblock in, take the speaker wires out. Plug it into a box. Sit inside, liste. Plug in a tube then. Sit inside, listen to the same song.
What excites you more is the one you should buy.
Old 5th August 2006, 11:49   #10
Thanked: 294 Times
So do tell us which one excites you more...... box or tube
But do make a program to drop down to fbd so that I can show u some of the installs and u would like them also.....
Old 5th August 2006, 13:07   #11
navin's Avatar
IWhat excites you more is the one you should buy.
Tight and Nice scores over Loose and Woolly. A tight and nice tube however would be best of both worlds as most tubes are lighter than boxes and hence easier to move in and out of the car.
Old 6th August 2006, 13:17   #12
panky12345's Avatar
Thanked: 149 Times
sure LBM, i wd definitely look fwd to coming to FBD. IMO, you are one of the few actual audio enthusiasts in this forum, not associated with any brand, whatsoever. I respect your (and others as well) knowledge about car audio, which is purely aimed at helping others.
Old 6th August 2006, 21:56   #13
navin's Avatar
panky, there are very few who are associated.
Old 6th August 2006, 22:52   #14
jkdas's Avatar
Thanked: 1,436 Times
what i got frm my observations
tubes are boomy and help in "show off"
and boxes take less space
Old 6th August 2006, 23:09   #15
Thanked: 294 Times
I consider the tubes give punchy output with no low_bass in them. but the box can go low when compared with a tube....I will consider a box anyday when compared with a tube.....
installing a bass tube bmdesai1987 In-Car Entertainment 21 11th October 2007 00:33
Bass Tube for Pioneer DEH-P5550MP nilu_baba In-Car Entertainment 77 1st October 2007 15:50
Wanted: Bass Tube & Amp lordofgondor Shifting gears 0 13th August 2007 12:06
For Sale - JBL Bass Tube Revvhead Shifting gears 8 18th July 2007 08:32
DDIY - Bass Tube gunbir In-Car Entertainment 11 1st April 2007 13:30
