Old 29th May 2007, 22:16   #31
navin's Avatar
Thanked: 4,266 Times
Gunbir, most Pio subs do have a bit too much overhang.
Old 29th May 2007, 22:52   #32
rishibravo's Avatar
very informative thread indeed....
rishibravo is offline   Reply With Quote
Old 29th May 2007, 23:59   #33
Thanked: 21 Times
Smile
Yes Navinji, thats what I was getting at... the characteristics he is looking for are found in better subs which are also more expensive.
Old 30th May 2007, 11:48   #34
headers's Avatar
Thanked: 464 Times
Hi, The Pio Sub is a 12" model 305F - If it is a Free air sub..How do i fix in in a Gypsy..
Also, is it true that Pio HUs, Amps and Subs are inferior in Sound Q than other brands..Just Curious!!
Old 30th May 2007, 14:03   #35
clipto333's Avatar
hi,
what enclosure are you using for the sub? sealed, ported? i suggest you install it in a ported(a.k.a. vented) enclosure as it would be difficult to have free air( infinite baffle) install in a gypsy. well this is my opinion and i may be wrong. so lets see what the gurus have to say.
Like sam says, no brand is better than the other. its up to the listener what what kind of sound he likes or the budget he has. so i would advise you listen before you buy. like navin says, USE YOUR EARS. lol
cheers
clip
clipto333 is offline   Reply With Quote
Old 30th May 2007, 14:26   #36
headers's Avatar
Thanked: 464 Times
Originally Posted by clipto333 View Post
hi,
cheers
clip
Hi thanks for your inputs.. The enclosure is a sealed one..not ported and now am wondering how to port the sealed enclosure..Also how can we listen to a sub before we purchase it..??
Old 30th May 2007, 14:34   #37
Thanked: 294 Times
one cannot stay away drill a hole in a sealed box and make it ported...there are lots of other parameters involved....and what are the sizes of the sealed box...
Old 30th May 2007, 23:45   #38
navin's Avatar
1. a free air sub would have a higher Qts than a closed box version. hence a lossy box (high QL say about 15) would be best. Needless to say the regualar here would now know the type of box I am refering to. It starts with Ap.....:-)
2. Did Sam say that. I think you mean that "at any price point there are often multiple options and it pays it listen before you buy".
Old 31st May 2007, 10:20   #39
DerAlte's Avatar
Thanked: 2,879 Times
Yes, Navin-ji, we definitely recognize that one. I even found your postings (you know where!) dating back to 2002 on that subject!
Question: where do I get something like a Variovent? There must be a more elegant solution than having to jerry-rig wire mesh and glass-wool.
I was thinking of making an ultra-small Ap... box (WDH 12"x14"x4-6") with a 10" woofer (haven't found a suitable one yet; is F3 less than 35Hz unachievable in this size?) to keep below the passenger seat in my Safari DICOR.
Old 31st May 2007, 12:16   #40
headers's Avatar
Thanked: 464 Times
Well Navin..I think i lost it here..can you tell me in simple words..the dimensions of the sub box..and the port size..
I do not understand QL..lossy box etc..pardon my ignorance.
Old 31st May 2007, 12:35   #41
Thanked: 294 Times
you have a 305F ....firstly it should be installed in a free air application that is like a rear deck of a honda city or baleno....but since you have a gypsy put it in a sealed box of 1 - 1.3 cuft box it will give you some boom boom for your needs....size would be like ....height 15 inch x width 15 inch x depth 12 inch with 0.75 inch mdf will give you a net internal volume of 1.1 cuft....
Old 31st May 2007, 12:37   #42
Thanked: 294 Times
how can this possible....Team Bhp was created on 12th Feb 2004 how can Navin Ji post the info in 2002.....
Old 31st May 2007, 13:06   #43
clipto333's Avatar
yes navinji everyone knows what you saying. :-)
yes i meant that navinji. thanks
cheers
clip
Old 31st May 2007, 14:01   #44
Thanked: 294 Times
cheers
clip
clip what do you wanna say here I did not understand a thing ....
replying to the post below...
ya thank you clip
Old 31st May 2007, 14:13   #45
clipto333's Avatar
ill explain.
i replied to both the points. ok here it goes again.
1. yes navinji everyone knows what you saying. :-)i meant to say that everyone knows you are reffering to aperiodic vent enclosure.
2. yes i meant that navinji. thanks
. this was the reply to navinjis 2nd point.
hope things are clear now.
clip
A/C blower 1 and 2 setting not working Dippy Technical Stuff 13 13th November 2009 15:36
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
