Old 8th August 2006, 17:21   #16
Thanked: 17 Times
Originally Posted by luvjascha
It'll just be me ! I very seldom drive with pax in the rear seat.
So, I have 2 suggestions:
1. Eliminate the amp+sub, keeping the front comps. and rear coaxials.
2. Eliminate the amp +rear coaxials, keeping the front comps. and sub.
Option 1 sounds better for me.
Old 8th August 2006, 17:27   #17
OK...how would clearer and crisper sound effects be accomplished - Option 1 or 2?
Like I said, if need be, I could stretch my budget to 25K.
luvjascha is offline   Reply With Quote
Old 8th August 2006, 17:29   #18
jkdas's Avatar
Thanked: 1,436 Times
25k
9k hu + 6.5k compo +4k rear + 4 channel amp+ install
also, cheaper compo @4-5k
if i remember right , u wanted teh 6850 and hence 9k. and compos frm JBL, 606Ce can be bought at less tahn 6k as 607 is out
Old 8th August 2006, 17:33   #19
Thanked: 21 Times
Since you drive alone, get a decent comp pair for the front (8k or so), a Sony 504 amp, and a 10" sub in sealed enclosure. Including install this should be manageable in your budget. And this will sound great in your Indica.
Worry about the rear pasengers when they start contributing to the ICE systems cost... Ask SK456, he used to have rear fill, now that he has front comps and a sub, he wants to sell his 6x9s cuz he doesnt use them anymore. So use the rear fill money for better components in the front.
Old 8th August 2006, 17:35   #20
Thanked: 167 Times
In second option if you remove the amp how are u gonna drive your sub? The sub driven directly from HU will be a waste of money . In my opinion go for the Front comp and the rear coax. You can slowly upgrade later by adding the amp and the sub. Again I think Indica comes prewired for the speakers. So if you are not adding amp you dont need to spend on wires at the moment. you can use the existing wires or you can use the wires that come with the JBL speakers.
malgudi is offline   Reply With Quote
Old 8th August 2006, 18:05   #21
So Gunbir, you're suggesting that I keep the front comps, lose the rear coaxials, go for a Sony 504 amp. instead of the Pioneer 6200, and a sub.
Would I be able to get all of this, including the installation done for 25K?
What sub were you referring to? Is the Sony 504 different from the Sony 554ZR?
Old 8th August 2006, 18:07   #22
Sam Kapasi's Avatar
Thanked: 1,473 Times
No i think the 504 has been replaced by the 554
Old 8th August 2006, 18:11   #23
Sam, how much would I be looking at, for the GTO606Ce, with bill and warranty. I might be considering that, instead of the GTO607. What do you think?
Old 8th August 2006, 18:13   #24
Sam Kapasi's Avatar
You would have to look around. There was a good quantity sold before the 7series launch and some dealers will have stock. Even though the MSRP is 6000/- i expect you can get it for 5500/- or less.
Old 8th August 2006, 18:16   #25
Gotcha! Have you heard of Shreyas Motors at Milan Subway?
I've gotten to hear that the guy does a decent number of JBL installs and even has some on the demo board.
BTW, what is your suggestion on my set-up? Where can I possibly cut corners?
Old 8th August 2006, 18:19   #26
Sam Kapasi's Avatar
Yes, Shreyas is an authorised re-seller. There is a nice kid there called Hirav. Tell him you're my friend.
Old 8th August 2006, 18:25   #27
Kool man! Yeah, I was told to contact Hirav. Hell, it's good to know Sam Kapasi :-)
There are other places in the Santacruz-Milan Subway vicinity: Suraj Motors, Choksi Motors, FM Drive, DK Electronics.
What do you think about them guys?
Old 8th August 2006, 19:51   #28
That's one thing about this site, that there is never one definite answer to any question. You receive a multitude of suggestions from various fellow BHP'ians, leaving you in a totally confused state of mind, sort of where you initially started out :-)
According to Gunbir, there is no point in having rear coaxials fitted, since I drive alone, which makes total sense.
Then, on the other hand, there are suggestions to go with the front comps and rear coaxials for the present moment, and have the amp+sub fitted at a later date, which is also a thinker.
Old 8th August 2006, 22:10   #29
Thanked: 294 Times
I think the gunbir has suggest the best option go for front componets and a sub in the boot as it will nearly complete ur system............but do add a amp to it.......
Old 8th August 2006, 22:20   #30
jkdas's Avatar
ok . get compos + sub + 4 channel amp + hu for now
later get the rear co-ax. simple. sony is cheaper, but pio is powerful i guess. If you can get the Pio. And spend some money for a good install + RCA.
Confused !!..Cool Sounding Car Audio on Budget advice needed quake6 In-Car Entertainment 77 18th July 2006 11:30
Audio Config For My Bro's New Swift.... freakrz In-Car Entertainment 36 10th March 2006 22:25
Needed: Best Audio config for a tata Indica msk_kapoor In-Car Entertainment 52 24th February 2006 09:44
Proposed Audio Config.. allajunaki In-Car Entertainment 38 31st August 2005 23:44
