Old 8th August 2006, 22:55   #31
Since that seems to be the unanimous suggestion, I think I will go for the comps + amp + sub for now and perhaps, have the rear coaxials fitted later, if I need 'em.
With regard to the HU, I'm thinking either Sony Xplod CDX-GT 350S or the Pioneer DEH-P6850MP, both of which cost approximately 9K.
Following are the technical specifications for each:
Flip-Down with Front Auxillary
Power Outout :- 52Wx4
• Playback : CD-R/RW/MP3/ATRAC3/WMA
• Pre Out : Fornt+ Rear/Sub Switchable
• FM18/AM12
• BTM/DSO/EQ3
Pioneer DEH-P6850MP
* Pure blue dot-matrix OEL (Organic EL) display
* iTunes® AAC playback
* WAV file playback
* iPod® adaptor ready
* BMX (Bitmetric qualizer)
* EEQ
- 5-mode preset equalizer
- 2-mode custom preset equalizer
- 7-band digital graphic equalizer
- Bass Boost
- 2-way crossover: HPF/LPF
- 3-mode selectable loudness
* Rotary Commander
* Direct Sub Drive
* 3 RCA preout: selectable (front + rear + subwoofer)
* Level indicator
* Multi-language display (English/Spanish/Portuguese)
Which of the two should I go for?
Again, with regard to the amplifier, the Pioneer GM-6200F is about 7K while the Sony XM-554ZR is about 6K. What do you guys recommend?
The Pioneer Sub TS-W306C/DVC comes for about 4K.
So, costwise, I am looking at:
HU : 9K
Front Comps : 5.5K(JBL GTO606Ce, if I'm able to get it for this price)
Amplifier : 6K or 7K (depending on Sony or Pioneer)
Sub : 4K
Wiring and Install : 2K
I might be slightly over my 'stretched out' budget.
luvjascha is offline   Reply With Quote
Old 8th August 2006, 23:17   #32
Thanked: 294 Times
HU : 9K
Sub : 4K
Hu ->6850
from comps -> 606 ( u can check out if avalable in grey around 4k or even less)
amp -> pioneer
sub -> pioneer 306dvc no to 306c (3.6k not 4k)
it depends which wiring ur going to install 2k is ok....
Old 8th August 2006, 23:21   #33
Thanks for the revised set-up, LBM.
But what's the difference between the Pioneer 306C and 306DVC?
Old 8th August 2006, 23:23   #34
Sam Kapasi's Avatar
Thanked: 1,473 Times
The DVC is a dual voice coil subwoofer.
Old 8th August 2006, 23:26   #35
Thanked: 294 Times
sorry yaar i left out that part
if u buy the dvc u can wire it parllel to get 2 ohms so that u can extract max from your amp but if u buy 306c it is 4 ohms and this will not extract full of the amp.....
I think this must add more confusion but this is the way....
Old 8th August 2006, 23:29   #36
So basically, choose the Pioneer 306DVC over the 306C, correct?
Old 8th August 2006, 23:33   #37
Thanked: 294 Times
in ur case yes
but if one is add a power mono amp then two 306 c will suit him better.....
Old 8th August 2006, 23:35   #38
Just curious, what's the price difference between the two anyway.
Old 8th August 2006, 23:39   #39
I am looking at Interlink Jr. by Monster, what say?
Old 8th August 2006, 23:54   #40
Thanked: 294 Times
I think there are priced the same ......
monster is a over priced stuff and the interlink jr is not approrite for its price u can find a JBL amp kit if u can find it original go for it and dont ask about BOSS kit it is complete waste of money....
Old 8th August 2006, 23:58   #41
LBM, could you be more specific about JBL's wiring kit?
What is the name for it.
Old 9th August 2006, 00:03   #42
Sam Kapasi's Avatar
http://www.team-bhp.com/forum/car-en...ing-kit-2.html (Fake Wiring kit)
Old 9th August 2006, 00:07   #43
Thanked: 294 Times
as suggested by our sam bhai this jbl kit also has a amp wiring kit with speaker wires and all the stuff for a single amp setup like urs. so i will recommend go for this kit.......it is priced a bit low 3k but it is worth investing.....
Old 9th August 2006, 00:20   #44
Great! I can almost see my set-up complete :-)
Thanks you guys!
Old 9th August 2006, 00:46   #45
Thanked: 294 Times
an do remember to post some pics of the same......enjoy......
Confused !!..Cool Sounding Car Audio on Budget advice needed quake6 In-Car Entertainment 77 18th July 2006 11:30
Audio Config For My Bro's New Swift.... freakrz In-Car Entertainment 36 10th March 2006 22:25
Needed: Best Audio config for a tata Indica msk_kapoor In-Car Entertainment 52 24th February 2006 09:44
Proposed Audio Config.. allajunaki In-Car Entertainment 38 31st August 2005 23:44
