Old 9th August 2006, 17:10   #46
Thanked: 26 Times
Originally Posted by luvjascha
Again, with regard to the amplifier, the Pioneer GM-6200F is about 7K while the Sony XM-554ZR is about 6K. What do you guys recommend?
Originally Posted by low_bass_makker
sorry yaar i left out that part
if u buy the dvc u can wire it parllel to get 2 ohms so that u can extract max from your amp but if u buy 306c it is 4 ohms and this will not extract full of the amp.....
I think this must add more confusion but this is the way....
Hey LBM, the amps he had mentioned there are 4ohms stable in bridged mode...
I think its safer to go for 306c if he is going for amps mentioned above...
I would recommend... go for GM-6200F and bridge it to TS-306c (Single Voice Coil)
regards,
ant.
anToNIcHeN is offline   Reply With Quote
Old 9th August 2006, 22:07   #47
Thanked: 294 Times
regards,
ant.
oops sorry i took that a pionner amp can take this but it cannot....
I assumed this as eariler i had pioneer 944 it is 1 ohms stable in 4 ch mode and 2 ohms stable in 2 channel mode....thats why I thought it can run 2ohms sub.....
Old 9th August 2006, 22:44   #48
Well, what should it be then : The Pioneer TS-W306C or TS-W306DVC?
luvjascha is offline   Reply With Quote
Old 9th August 2006, 22:46   #49
Thanked: 294 Times
if u buy pioneer 6200 then it should be 306c........
ya man the below combo is correct.....
Old 9th August 2006, 22:52   #50
Amplifier : Pioneer GM-6200F
Subwoofer: Pioneer TS-W306C
Right combo, correct?
Old 9th August 2006, 23:11   #51
Thanked: 294 Times
Hey LBM,
For the front comps, I have decided to go with
6 1/2 inch JBL GTO606Ce; however, the Indica doors have provisions for a 5.25".
What do you suggest?
u can use them... u have to add spacers to mount them .....there is a info about this on this forum.....
Old 10th August 2006, 19:17   #52
Since the Indica doors have a provision for a 5 1/4" speaker, is it then not advisable to go for the GTO507 rather than the GTO607/606Ce?
Old 10th August 2006, 20:15   #53
rsjaurr's Avatar
Thanked: 27 Times
luv,
Door should ideally get biggest size possible.Its true that stock size is 5 1/4" but with slight modication,u can fit in 6.5" as well.
My experience tells me that bigger door spk will produce more bass and that will also be punchy & tight.
Have a look at thread called 'largest size speaker for indica' started by panky.
rsjaurr is offline   Reply With Quote
Confused !!..Cool Sounding Car Audio on Budget advice needed quake6 In-Car Entertainment 77 18th July 2006 11:30
Audio Config For My Bro's New Swift.... freakrz In-Car Entertainment 36 10th March 2006 22:25
Needed: Best Audio config for a tata Indica msk_kapoor In-Car Entertainment 52 24th February 2006 09:44
Proposed Audio Config.. allajunaki In-Car Entertainment 38 31st August 2005 23:44
