Old 10th August 2006, 16:09   #16
esteem_lover's Avatar
Thanked: 451 Times
Originally Posted by panky12345
yup phaaji, its an SVC 4 ohm 12" (eqv to Pio TSW306C)....ground cables and power wire are perfect. i used entire new lot (externally) to power the amp, but it still doesnt work! it took me more than 4+ hrs to do the entire permutation and combination lot!
as for full gain, if its capable of producing 120 X 2 RMS, am allowing it to do that!! (at least for couple of minutes)
as for FBD, u need to PM me your #/ call at my #, so that we may carry it fwd!!
hey panky, did u try giving it some of the stuff u been having on the days that end with 'y' ?? did u ? did u ???
Old 10th August 2006, 17:48   #17
Thanked: 17 Times
Great!!!!!!
Old 10th August 2006, 21:53   #18
Thanked: 295 Times
i dont think so ... because if the battery was bad the indica could not have started even once.........lol
Old 11th August 2006, 12:15   #19
panky12345's Avatar
Thanked: 151 Times
gyz gyz....thanx for suggestions! i got the amp fixed for 500 Rs. (mosfets changed)....its working perfect now!
Old 11th August 2006, 13:21   #20
Thanked: 26 Times
can you just be more specific?... what did you change where?
RS. 500.... did you change any chip?... I think the dealer has taken you for a ride...
regards,
ant.
anToNIcHeN is offline   Reply With Quote
Old 11th August 2006, 14:39   #21
sk456's Avatar
Thanked: 7 Times
thanx gunman, do u think turning gain to 65-70% would solve this problem? (irrespective of the volume at HU)
Hye dude,
I have the 6100F too ..im runnign a IDQ 10 inch sub bridged from two of the channels with it.....I have the gains set at less than 40%..( and I run it absolutely Flat from the HU ) and it rocks... if you have gains at 100%..then im not surprised you had problems...
sk456 is offline   Reply With Quote
Old 11th August 2006, 14:50   #22
gunbir's Avatar
Thanked: 25 Times
Panky did they actually change any parts? is this a second hand amp?
Mostly, I think you've been had...
Old 11th August 2006, 16:09   #23
panky12345's Avatar
Thanked: 151 Times
as the dealer told me, he changed mosfets in the amp.... dunno what he has done, but it works perfect now.
if you guys are telling me that I'd been taken for a ride, how??
gunman: its very genuine 1st hand amp!
Old 11th August 2006, 17:33   #24
gunbir's Avatar
Thanked: 25 Times
Panky, first of all, you should not need any repairs on a brand new amp. Secondly, can you please tell us where the amp gain is at now? I mean after the dealer "changed the mosfets".
In all probability, the dealer took off the amp, put it back in, reduced the gain, and took a crisp green Gandhiji from you. After six months on TBHP ICE, I am shocked you let this happend to you... and even though we told you to turn down your gains...
Old 11th August 2006, 17:34   #25
Thanked: 26 Times
which amp is this?...
gurus correct me here.... if your dealer has done, what he has said... he is tampering with the amp... thereby voiding the warrenty....I dont think this is what he has done....or else he has given you a brand new amp....
did you happen to see what the dealer did? did you leave your car with him?...
where is your amp placed?... (i guess it would be under your front seat!..) try seeing (by urself) what is the gain setting now?...(its normally a knob which can be adjusted only with something sharp like a screw driver)... there will be a reading something like 0.2V (min setting) to 8V (max setting)...
Pls note that "(min setting)" and "(max settings)" will not be there.. its just for your understanding... also 0.2 V and 8V volts are just indicative figures, may be different in ur amp.
regards,
ant.
Old 12th August 2006, 08:59   #26
jkdas's Avatar
Thanked: 1,437 Times
very funny. mosfets at 500? and dont these amps have these mosfets IC and not transistor type thingies that can be soldered out and put in?
sk456! #^& u envy me can u shh!
Old 12th August 2006, 10:35   #27
navin's Avatar
Thanked: 4,351 Times
gunbir if the dealer was devious enough he would add a small resistor in series with the gain pot and set the gain pot to max and panky would not have any external evidence.
Old 12th August 2006, 15:48   #28
panky12345's Avatar
Thanked: 151 Times
true navin....if i wdn't have stood on his head, i wd've accepted everything.
the guy opened the amp, changed couple of identical green colored small thingies. (dont know whass that); and thats it. he shut the amp.
amp's gain is FULL now, but yes, i wd admit this the sound quality has deteorated.
Old 12th August 2006, 17:09   #29
kb100's Avatar
Panky... Lose your fetish full the "FULL" gain setting... Not advisable under any circumstance!!.. Has nothing to do with ability to put out rated output!
kb100 is offline   Reply With Quote
Old 12th August 2006, 17:35   #30
rsjaurr's Avatar
Thanked: 27 Times
I agree with Kb that panky should forget about setting the gain to maximum.I cant beleive that even after yesterday gunbir advised him not to set it that way,he still has it at maximum.
@Gunbir.....what have u done to ur self man!!!!!!!!!!!!!!
rsjaurr is offline   Reply With Quote
Watch movie trailers and Imax clips in 720p and 1080p resolution!!! Shan2nu Shifting gears 21 25th September 2007 22:40
Low volume high pitched squealing noise in Siena 1.6 ece2k2 Technical Stuff 3 18th August 2007 20:53
Some Clips of Indians Driving eflanker Street Experiences 2 23rd July 2007 23:21
why sound is harsh at high volume overdose14 In-Car Entertainment 21 25th July 2006 23:36
Video clips ? khaadu75 Shifting gears 9 25th October 2005 09:29
